Author Topic: Help me identify this Keyboard  (Read 1254 times)
Offline Myk!
« on: Mon, 09 November 2015, 19:38:32 »
Any possibility is it a buckling or alps? My friend unable to remove a single keycap to check. Or it is just a rubberdome even it is a DIN plug?
Google gives no exact result for this.
Offline E TwentyNine
    • Some of My Keyboards
Re: Help me identify this Keyboard
« Reply #1 on: Mon, 09 November 2015, 21:10:04 »
FCC ID indicates Tai-Ho.
http://deskthority.net/wiki/Tai-Hao_APC_semi-mechanical_keyboard
Could be an alps clone, maybe not. Details at the link above.
Definitely not a buckling spring.
With these kinds of keyboards a good picture of the entire back is often worthwhile, you can sometimes match the construction to another board with similar part numbers.
Offline Myk!
« Reply #2 on: Mon, 09 November 2015, 21:52:49 »
Thanks for the reply
