Author Topic: PS/2 Adapter for ABS M1?  (Read 4701 times)
Offline twokatmew
    • http://twokatmew.smugmug.com
« on: Thu, 12 November 2009, 19:22:54 »
Hello, I just got an ABS M1 keyboard and would like to pick up a PS/2 adapter for it.  The couple adapters I have lying around don't work.  (Keyboard doesn't work, and num-caps-scroll lights flash.)
Can anyone recommend a source for and/or a specific USB-PS2 adapter that will work with the ABS M1 keyboard?
TIA!
Filco Blue Cherry NKRO, Unicomp SpaceSaver, Filco Brown Cherry NKRO, Rocketfish Wireless Numeric Keypad, MS Comfort Mouse 4500, Wacom Bamboo Pen & Touch, MS Wireless Mobile Mouse 6000, 1960s Olympia SM 3.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Thu, 12 November 2009, 19:49:49 »
How much do Blue Cubes cost? I might consider getting one to make my keyboard work more reliably (the PS/2 ports do not supply enough power all the time).
Offline Viett
« Reply #2 on: Thu, 12 November 2009, 20:02:31 »
I think he means USB to PS/2, as the ABS M1 is USB. The blue cube is PS/2 to USB. I'm pretty sure if the keyboard does not support PS/2, there is no real way plug it into PS/2.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline twokatmew
« Reply #3 on: Thu, 12 November 2009, 20:04:36 »
Quote from: ripster;132040
Welcome to Geekhack.
See the wiki (home page link) for PS/2 to USB adapters.   I recommend the one nicknamed the Blue Cube.
Thanks for the welcome and speedy response, ripster!  :smile:
I checked out the wiki thread on PS/2 adapters.  Problem is, they're all for plugging PS/2 keyboards into USB.  The M1 is a USB keyboard, and I want to plug it into PS/2....  I'd preferrably like an adapter that will work with my PS/2 KVM, but I'd settle for an adapter that works connected to a PC....
I checked over at Elite keyboards seeing as all their keyboards come with USB to PS/2 adapters, but they don't sell the adapters separately.  :ohwell:
Sorry I wasn't more specific!  :smile:
Offline twokatmew
« Reply #4 on: Thu, 12 November 2009, 20:12:38 »
Quote from: Viett;132050
Yes, Viett.  I posted my previous response before seeing your post.
Hmm, I'd thought it was simpler to get a USB keyboard to work as PS/2 than it was to get a PS/2 keyboard to work as USB.  I guess it's complicated either way....  :frusty:
I'd been reading up on keyboards and saw that Costar OEM keyboards based on CST-104 include the ABS M1 and a Filco board (don't remember model number).  When I saw that Filco's over at Elite Keyboards come with USB-to-PS/2 adapters, I assumed one of those adapters would work with my M1.
Unfortunately ABS' web site has dead links, so I can't get any more info on the M1.  But ... if it's unlikely to support PS/2, I'll just use my M1 as USB and plug in a PS/2 keyboard for those times when I really need it.  :ohwell:
Offline twokatmew
« Reply #5 on: Thu, 12 November 2009, 20:13:31 »
Thanks for your speedy and helpful responses, ripster and Viett.  Now I can give up the search!
Offline Rajagra
« Reply #6 on: Thu, 12 November 2009, 20:33:55 »
Might be a silly question, but did you turn the PC off before plugging in the keyboard via the adapters that you had? You need to.
Offline twokatmew
« Reply #7 on: Thu, 12 November 2009, 20:39:57 »
Yep, I powered down the PC completely.  I guess the M1 just doesn't support PS/2.  Not the end of the world though.  It gives me an excuse to buy a Filco when I get some spare $$. :wink:
Offline skriefal
« Reply #8 on: Thu, 12 November 2009, 23:16:55 »
That's correct... the ABS M1 will not work with a PS/2 adapter.
Offline ch_123
« Reply #9 on: Fri, 13 November 2009, 03:53:15 »
Why do you need a PS/2 keyboard?
