Author Topic: Topre Hi-Pro on hhkb  (Read 3883 times)
Offline phoxxii
« on: Fri, 13 November 2015, 16:23:18 »
I was wondering if there is anyways to take realforce Hi profile keys and put them onto an HHKB? I've heard that they are not compatible but currently can't find any sources on this.
Offline raymogi
Re: Topre Hi-Pro on hhkb
« Reply #1 on: Fri, 13 November 2015, 16:32:38 »
You have to take the hipro sliders as well and replace the sliders on the HHKB.
Please feed my addiction.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #2 on: Fri, 13 November 2015, 16:42:22 »
I don't think you can do this. The hhkb can only have its sliders replaced. The actual mounts that hold the sliders are built into the case.
The hipro requires those special mounts to accommodate the keys.
I don't see this working.
Offline phoxxii
« Reply #3 on: Fri, 13 November 2015, 16:45:58 »
Do you mean the portion surrounding the stem that the keycaps click into? If yes I understand how this problem becomes unavoidable.
Thanks
Offline Kudos
  • Godspeed
  • GAF
« Reply #4 on: Fri, 13 November 2015, 17:22:15 »
I've put Hi-Pro caps on my HHKB. The different housing helps to stabilize the downstroke. Without it, there's a slight wobble. Aside from that, if you don't mind, it's viable.
Offline Bromono
  • Wanabe Cicerone
« Reply #5 on: Fri, 13 November 2015, 17:25:37 »
You rebel o.o
Offline phoxxii
« Reply #6 on: Sat, 14 November 2015, 13:44:12 »
That's awesome to hear!
Offline Ryu
    • GitHub
« Reply #7 on: Tue, 17 November 2015, 21:31:38 »
As the other guys said, you can put Hi-Pro caps on HHKB, but not the converse.
