Author Topic: What paint should I use for painting a mouse?  (Read 1755 times)
Offline cryptokey
  • [°°▄°] luser-friendly
« on: Sun, 15 November 2015, 20:10:55 »
Hello GH!  I recently purchased an ergonomic mouse, however the only gripe I have with it is its appearance.  Yeah... It's ugly.  So I was hoping that I could make it look a little bit better by painting the non-grippy part of the mouse (of course).  Except, I am unsure of which paint would be best for this.  I need something that will last after daily use, yet is not too toxic that it might be unhealthy in the long run.  Any ideas for what I should use?
« Last Edit: Sun, 15 November 2015, 20:49:38 by cryptokey »
[WTB] HHKB Black
Offline 0100010
  • Not Sure
Re: What paint should I use for painting a mouse?
« Reply #1 on: Mon, 16 November 2015, 08:52:32 »
Likely Krylon Fusion for Plastic would work.
Offline jaffers
« Reply #2 on: Mon, 16 November 2015, 10:59:05 »
You could try out cerakote, they have a very wide range of colours, expensive but for such a small area you could use a sampler.
http://www.cerakoteguncoatings.com/
Alternatively you could rough up the surface with a high grit sand paper and use a self etching primer
