Author Topic: Clueboard 66% PCB - Pre-soldered Underlight Available!  (Read 470996 times)
Offline skullydazed
  • * Moderator
  • Had to turn PM's off. Email info@clueboard.co!
    • Clueboard
« on: Sun, 15 November 2015, 23:13:38 »
The Clueboard 66% PCB started as my project to create a custom PCB for the fc660m. It fits perfectly into both the fc660m case and the aluminum case from massdrop. However, it supports so much more than the fc660m. It is available now! Order here:
https://clueboard.co/parts/clueboard-66-pcb
https://clueboard.co/parts/clueboard-66-pcb-version-20
Here's an overview of all the layouts it currently supports:
The PCB is fully programmable with QMK and it is officially part of the main QMK branch:
https://github.com/jackhumbert/qmk_firmware
New Feature: Underlighting!
Now you can make your keyboard glow with the fury of 14 suns. Simply solder on 14 WS2812B LED's and you can light up your desk.
Please feel free to ask any questions or provide any feedback you may have in this thread.
« Last Edit: Thu, 09 March 2017, 13:04:52 by skullydazed »
Offline potatowire
Re: Clueboard 66% PCB
« Reply #1 on: Thu, 19 November 2015, 20:52:23 »
This looks like a very cool project. I'm looking forward to seeing how you plan to sell it.
Offline njbair
    • nickbair.net
« Reply #2 on: Thu, 19 November 2015, 21:17:05 »
Black PCB best PCB
My boards:
« Reply #3 on: Thu, 19 November 2015, 21:30:13 »
What about plates?
Offline neverused
« Reply #4 on: Thu, 19 November 2015, 22:40:36 »
I think I saw this on Instagram, I really would like at least one or two. Nice work
Offline Acknown3
  • Not a keyboard addict
« Reply #5 on: Fri, 20 November 2015, 00:11:42 »
What about plates?
Skully posted this on Reddit 11 days ago, but I'm not sure if it's still valid;
I'm still working out pricing. Parts for my 66% board will start at around $150 for acrylic plate, acrylic case, pcb, zealios switches and costar stabilizers (everything except for caps and a USB cable) and then assembly will be an additional charge on top of that I have yet to determine, but I want to make it affordable.
I'll have aluminum plates too but acrylic will be the cheapest way to get one.
FC660C gray dyesub, gummyrot clack
FC660M cherry reds, Triumph Adler, blue aluminum case
Filco TKL cherry reds, white side-printed PBT
IBM Model F XT
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #6 on: Fri, 20 November 2015, 00:33:13 »
What about plates?
That's exactly right. I got my first samples back today:
Still waiting on the Alps plates, and I just finished designing the plates that fit the standard fc660m case. Tomorrow I'll laser cut some acrylic to test fit and then submit my order for those plates. I'll also be dropping the plates you see off at the finishing shop where they'll doing the following:
* 5 bead blasted + black anodizing
* 2 polished + blue anodizing
* 2 polished + red anodizing
* 1 polished to a mirror finish
Besides my prototype plates I've been talking to LeandreN about a larger run of plates, which should mean a significant price break.
Offline Jokrik
« Reply #7 on: Sat, 21 November 2015, 18:35:29 »
Very interesting!
Will be following this very closely
Offline njbair
    • nickbair.net
« Reply #8 on: Sat, 21 November 2015, 18:45:03 »
I don't have an acrylic board yet. This might be a good first one.
What does MX keycap compatibility look like for this layout? Pretty much any set?
My boards:
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #9 on: Sun, 22 November 2015, 08:15:20 »
It will depend on the layout you build. For a standard ANSI build pretty much any set with two 2.25u shifts will work. For ISO or JIS it's actually slightly easier because your shifts can be 1.25/2.25.
Offline vivalarevolución
« Reply #10 on: Sat, 28 November 2015, 14:09:13 »
This will be a great product.  We have seen this layout before, but not Alps-Compatible or completely programmable.
Offline njbair
    • nickbair.net
« Reply #11 on: Sat, 28 November 2015, 14:14:45 »
Do we know for sure when/if Massdrop will be running that alu case again? Or is it available elsewhere?
My boards:
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #12 on: Sat, 28 November 2015, 15:42:29 »
I have a few on hand but I'm hoping to track down the manufacturer.
Offline wakko
« Reply #13 on: Sat, 28 November 2015, 16:14:08 »
Will different versions of the plate be cut for different layout options?
NOOB
KUL ES-87
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #14 on: Sat, 28 November 2015, 17:12:51 »
The MX plate is universal with PCB mount stabs:
The Alps plate will be ANSI only for now, but if I find some good ISO keysets I'll offer that in an ANSI ISO layout.
« Last Edit: Sat, 28 November 2015, 23:48:15 by skullydazed »
Offline trenzafeeds
  • **** off
« Reply #15 on: Sat, 28 November 2015, 21:29:58 »
Wow, it took me forever to figure out that layout diagram. It'll be really awesome to have an alps-compatible fc660, really glad you took alps into account, because that's a really big selling point imo. Also will be super nice to have this layout on a fully programmable pcb, because honestly I feel that that little right hand key cluster could be used a bit better (at least in terms of what I use on a daily basis).
demik will never leave.
Unless he gets banned.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #16 on: Sat, 28 November 2015, 23:51:23 »
I've been trying to figure out a better way to explain the possible layouts. Soon I should have physical examples which I think helps, at least for some people.
I'm glad the alps compatibility is getting so much love. Part of what's driving me here is the idea of having an AEKII-like board with the fc660 layout. I have an AEKII with salmon alps that's going to be turned into a clueboard once I have metal alps plates in hand.
Offline Cods
  • Penumbra SA Mark II please?
« Reply #17 on: Tue, 01 December 2015, 04:22:04 »
Nice work. Lovely to see this form factor get some creative love.
Alps... now that's interesting.
Model M Industrial, SSK, Unicomp 104, Code TKL MX Green, FC660M MX Green + Clear + White + Grey, FC660C Topre 45g, MagicForce 68 USB and Bluetooth, Whitefox, some optical switch 65% Bluetooth split spacebar thing ... wait, I think I need an intervention. Too late, there’s a couple of new Model Fs on the way.
Too much SA is never enough.
Offline kinglukas38
  • Do you even tactile?
« Reply #18 on: Tue, 01 December 2015, 15:14:38 »
If this had full led support it would be my endgame
I've never done it before, but I'm pretty sure I'm good at it
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #19 on: Tue, 01 December 2015, 18:17:57 »
I actually started with fully controllable LED support, but the problem I ran into was too many traces, so I couldn't support PCB mount stabs. I'm working on a version that solves that, but it'll be a few months before that one is ready.   :cool:
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #20 on: Tue, 01 December 2015, 18:35:49 »
I spent some quality time with the laser cutter today, and finalized the plate design to fit fc660m cases. It took me 7 iterations to get everything aligned just right:
Here's a picture of the 6th iteration, just before I got it right:
The version 1.0 PCB fits into the aluminum case perfectly with very little room for movement. It's actually a little tricky (and kinda scary) to get the PCB seated properly in the case, but once you do it fits very firmly and there is no rattle at all. I have made that hole just a tiny bit bigger for version 1.1.
Now it's time to send these designs off to LeandreN so he can make plates!
Offline kinglukas38
« Reply #21 on: Wed, 02 December 2015, 00:20:41 »
Thank you for saving my wallet for a few months  :p. God knows it needs a break
Offline iss
« Reply #22 on: Sat, 05 December 2015, 15:35:41 »
Will you be selling 4u stabilizers separately? They're almost impossible to find.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #23 on: Sat, 05 December 2015, 18:06:16 »
On my todo list is building a jig to bend 6.25u stabs. Once I have that going doing 4u stabs as well should be possible.
« Reply #24 on: Fri, 25 December 2015, 18:06:06 »
Didn't notice you got your own vendor forum!
Just have to give props to SkullY - these boards are great (I have one) though do to my poor planning I had to take it apart and haven't put it back together yet. That being said. SkullY has amazing QC and customer service. EVERYONE SHOULD BE SNAGGING THIS PCB!
Offline Zorberema
  • IG: @ZorbCaps
« Reply #25 on: Mon, 25 January 2016, 11:47:07 »
Are all these layouts available for alps boards as well? I'll be using orange alps + caps taken from an Apple Extended Keyboard, and the spacebar is 6,5u on that one. The alps plates does not look like they features multiple layouts!
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #26 on: Mon, 25 January 2016, 15:59:22 »
Thanks for your support! I hope you get that put back together soon so you can show it off. Let me know if you need anything when you're ready to put it back together.
The PCB supports all layouts for both alps and MX, but unfortunately the plate is another matter. Due to the way alps/matias stabilizers work you can't make a plate that supports multiple combinations easily if you need to stabilize keys. I'm working on a way around that problem but it will be a while, if ever, before that gets solved.
However, if you're OK with an acrylic plate I can cut one with any layout you want.
Offline Zorberema
  • IG: @ZorbCaps
« Reply #27 on: Mon, 25 January 2016, 17:12:51 »
I'd definitelly be down for an acrylic plate if that allows for a custom layout! Now when I think about it... You don't happen to have any left-over monarch pcb's lying around? ;)
Is it looking like the store is coming up soon? I've heard about the troubles around the launch; I hope you'll be able to sort everything out soon!
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #28 on: Mon, 25 January 2016, 17:57:03 »
Any spares go to koalapear, so you'll have to bug him.  ;)
I have the store all configured, I just need to take about 30 more pictures and finish describing everything. I'd like to think that wouldn't take long, but you'd be surprised.
Offline Zorberema
  • IG: @ZorbCaps
« Reply #29 on: Tue, 26 January 2016, 04:44:16 »
Oh... :(
Good luck finish it all up! :) Will you stock alps/ Mx stabs?
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #30 on: Tue, 26 January 2016, 08:36:44 »
Yes, I have both pcb and plate mounted cherry stabs, and a bunch of matias stabs.
Offline Zorberema
  • IG: @ZorbCaps
« Reply #31 on: Tue, 26 January 2016, 09:35:04 »
Awesome! Will pick up both Alps/ MX stabs for various builds! :) Looking forward to the release!
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #32 on: Wed, 10 February 2016, 01:51:45 »
The Clueboard store is now open and you can buy a Clueboard PCB!
https://shop.clueboard.co/Clueboard-66-PCB.html
Inventory is going faster than I anticipated. I have around a dozen left and because of the spring festival my next shipment won't get here until 3/3 or later.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #33 on: Thu, 11 February 2016, 13:28:02 »
Sold Out
I'm blown away. These sold out much faster than I thought they would. My second batch of PCB's has been order for a week now, but if you'd like to pre-order you can do so:
https://shop.clueboard.co/Clueboard-66-PCB-Accepting-Pre-orders.html
The first 45 pre-orders get their PCB from the first batch in early March. After that you can expect to receive your board sometime in April. Regular ordering and shipments will continue until I can maintain an inventory level.
People who pre-order will receive a version 2.0 PCB. This PCB supports everything the Clueboard 1.0 PCB supports, with the following new features:
  • New bottom row footprints to enable a wider variety of layouts.
  • LED support for the escape key, so you can light up your artisan esc
  • Improve split shift support, you can do 1.25u/1u or 1u/1.25u on BOTH sides
  • Hacker Friendly! The TWC/i2c pins have been exposed to allow you to interface with custom hardware
  • LKTK or RHTK options- pair this with the coming Cluepad PCB to put a numpad on the left or right of your Clueboard, and connect them with a single USB cable.
Offline Wannabe
  • Independent Adjudicator
« Reply #34 on: Thu, 11 February 2016, 14:00:49 »
Glad I got my order in before they sold out. Love the layout and options available for the keyboard, especially having stabs and keysets. Website was nice to use too!
I liek keyboards
Offline faxe
« Reply #35 on: Thu, 11 February 2016, 14:26:04 »
Somehow I am very happy right now that I decided to wait. Do you have an image of the new possible layouts?
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
« Reply #36 on: Thu, 11 February 2016, 14:26:55 »
Perfect PCB for my dip into the world of Alps.
Offline Tuntematon
« Reply #37 on: Thu, 11 February 2016, 15:15:43 »
This is exciting. This PCB allows me to achieve a layout fairly close to my ideal, with a split backspace and split space bar. I'm curious to see the new bottom row options for 2.0  :)
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #38 on: Thu, 11 February 2016, 15:17:36 »
Not yet, I need to put that together. Here's an image of the PCB layout:
http://i.imgur.com/QGucYGA.png
Offline faxe
« Reply #39 on: Thu, 11 February 2016, 15:24:49 »
Thank you! And does the Aluminium case include feet?
Offline xondat
  • i'm not a star
« Reply #40 on: Thu, 11 February 2016, 15:30:22 »
This is really interesting, can't wait for this to come into fruition with proper pictures!
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #41 on: Thu, 11 February 2016, 16:16:46 »
No but I have a couple sets I could let go of. Can't guarantee to match the case color. :)
Offline derezzed
« Reply #42 on: Sun, 14 February 2016, 19:24:13 »
Will the 2.0 PCB use SMD or through-hole components.  If it uses SMD, will they come pre-soldered?  Will the 2.0 PCB be compatible with the Cherry MX plates you're currently selling?  I was planning to build my own custom 60% but this comes so close to my ideal layout and will look so much nicer than a hand-wired skeleton case, that I think this will be my next keyboard.  I bought several child sets of Carbon just to get the few keys I would need for my custom layout, but seeing the titanium gray case you have, I find myself wondering what sets I would need to put Nantucket Selectric on this board.
Offline joey
« Reply #43 on: Sun, 14 February 2016, 19:25:58 »
All the components, apart from switches are pre-soldered.
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #44 on: Sun, 14 February 2016, 19:33:40 »
As joey said all the smd components are pre-soldered. The 2.0 PCB is compatible, but there will be new plates coming that support the additional layout options as well. Some of them are already supported by the current plate (like the split shift) but some of the bottom row configurations are not currently supported in the plate.
If you want one of those titanium grey cases you better order soon, there are only 2 left in stock. :)
Offline derezzed
« Reply #45 on: Sun, 14 February 2016, 20:11:56 »
That is unfortunate.  Will you have more cases in stock by the time the 2.0 PCBs become available?  The Nantucket Selectric group buy ends this week.  If I don't buy the case, I won't have anything to put my keyboard in.  If I don't buy the caps, I may have to suffer with the awful stock Ducky Shine keycaps on my home board for 6 months or more.
edit:
And does the split spacebar layout support both PCB-mount and plate mount stabs?
« Last Edit: Sun, 14 February 2016, 20:28:22 by derezzed »
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #46 on: Sun, 14 February 2016, 21:30:17 »
edit:
If I can track down the manufacturer, or massdrop does another run, I will get more.
Split spacebar does support PCB mount stabs.
« Reply #47 on: Mon, 15 February 2016, 08:19:53 »
The aluminum case is up on Massdrop again, if anyone is interested.
Offline faxe
« Reply #48 on: Mon, 15 February 2016, 09:32:26 »
Will the new plate be available with the release of the new pcb? If I place an order to reserve the new pcb, could you switch me to new new plate before dispatching the order?
Offline skullydazed
  • * Moderator
    • Clueboard
« Reply #49 on: Mon, 15 February 2016, 10:26:21 »
I'll need some time to develop and have the new plate made. In the meantime if you PM me with the layout you want I can check to see if the current plate supports it, and we can talk about options if it doesn't.
