Author Topic: wasd blue o rings  (Read 1821 times)
Offline Harms
wasd blue o rings
« on: Mon, 16 November 2015, 14:33:22 »
Hey guys, what's what's thickness of the wasd blue o rings? On the site it only shows the amount of travel reduced.
I ask because I want to buy ones with the same thickness off mass drop.
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
Re: wasd blue o rings
« Reply #1 on: Mon, 16 November 2015, 14:48:50 »
Just measured mine, about 1.5mm thick. Hard to tell with a ruler. I think you want the black, though, assuming those are the Max Keyboard o-rings.
« Last Edit: Mon, 16 November 2015, 14:56:41 by MajorMajor »
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
Offline Harms
« Reply #2 on: Mon, 16 November 2015, 15:18:30 »
there these ones https://www.massdrop.com/buy/cherry-mx-rubber-o-rings. I think there the same thickness as the blue ones then, thanks a lot bro :).
Offline ddot
  • Master of Suspense
« Reply #3 on: Mon, 16 November 2015, 17:02:52 »
I picked up this set of o-rings off ebay a little while ago.
The best thing I have to compare them to are these o-rings I got of massdrop a year or 2 ago.
Size wise, they're the same at 1.5mm thick.  No clue on the hardness of the ebay ones.  The massdrop ones were listed at a hardness of 50A.  By comparison, the ebay ones are definitely squishier when compressed lengthwise, so maybe they're softer (someone smarter than me may be able to chime in if those properties have a correlation).
I don't know what all your requirements are, but you may be able to get something similar off ebay for a little cheaper.
Offline Harms
« Reply #4 on: Mon, 16 November 2015, 18:28:53 »
I found some on amazon.ca, as im Canadian :D. There like the same ones you posted, there also much cheaper than the ones on Mass Drop.
http://www.amazon.ca/ELEGIANT-150pcs-Keycap-Dampeners-Replace/dp/B00Z9ZSB2U/ref=sr_1_2?ie=UTF8&qid=1447720033&sr=8-2&keywords=o+rings
