Author Topic: How to label keys in replacable way  (Read 4521 times)
Offline User
« on: Thu, 19 November 2015, 10:44:04 »
Hi,
I've finally decided to try ErgoDox EZ. However I'm still tore between blank caps and labelled one. I'd like to experiment with alternative layouts and I'm unfamiliar with ErgoDox for which labelled would be nice. OTOH the unlabelled seems more ergonomic.
Is there an easy way to label keys in temporary way if I would go with unlabelled?
Offline Dernubenfrieken
Re: How to label keys in replacable way
« Reply #1 on: Thu, 19 November 2015, 11:01:23 »
Relegendables. Alternatively you can do front print stickers.
Offline dan002
« Reply #2 on: Thu, 19 November 2015, 11:14:50 »
Print a a blueprint with the legends so you can refers to them when needed  ;)
Peace, love and keyboards.
Offline User
« Reply #3 on: Mon, 23 November 2015, 22:48:01 »
Dan's idea seems to be good for me. Especially that it allows me not to look down (too much).
« Reply #4 on: Tue, 24 November 2015, 03:54:04 »
Or just go with DSA keycaps, which are uniform profile and many sets include Ergo Dox-like compatibility.
When you have a layout you like, simply swap them for blank DSA keycaps.
Offline qwack
« Reply #5 on: Wed, 09 December 2015, 17:02:32 »
Graphite pencil. Write the legends in front of the caps, wipe them off with a moist rag (or your finger) when you don't need them anymore. Kinda ghetto but it works.
Also the blueprint idea is great.
Pure Pro w/MX Red - [review]
Offline 1swt2gs
  • DOGE
« Reply #6 on: Thu, 10 December 2015, 14:01:46 »
If you are crafty, you can create a storage box out of a stencil knife and a few pieces of cardboard.
Glue the outside border of 2 cardboard pieces together. Print out a blueprint and trace over it and then cut out the holes with stencils!
Such artisan, many caps, very keyboard.
Always searching for Bro caps!
1swt2gs classifieds!
Offline Poplicola
« Reply #7 on: Thu, 10 December 2015, 23:03:42 »
I find the US International keyboard layout to be useful to me.
On a Dolch keyset, I put Scotch tape on the front of the keycaps and mark the legends with a white gel pen used with dark paper, specifically Gelly Roll 08 from Sakura. The "ink" dries like a kind of paint.  These seem to hold up pretty well as the front of cap doesn't get a lot of wear.  However note, gel pens in other colors don't mark the tape anywhere near as well.
On a Biege keyset, I do same and mark the tape with a 2B pencil, then place a second piece of tape over the pencil to protect it.
« Last Edit: Thu, 10 December 2015, 23:35:25 by Poplicola »
Offline sumail1234
« Reply #8 on: Fri, 11 December 2015, 21:42:38 »
wow . thank you all . for secret
Offline XMIT
  • formerly jsoltren
« Reply #9 on: Fri, 11 December 2015, 21:50:25 »
I do printable P Touch labels on the front side of the key cap.
« Reply #10 on: Fri, 11 December 2015, 22:28:49 »
Welcome to Geekhack!
And you're most welcome, although I have no idea what for :p
Offline User
« Reply #11 on: Sat, 23 January 2016, 16:14:31 »
I think I'm going with a legend. Thanks for all replies.
