Author Topic: Looking for router  (Read 13785 times)
Offline jamster
Re: Looking for router
« Reply #50 on: Thu, 26 November 2015, 06:32:48 »
WRT-54GL + DDWRT.  Set and forget.  Been using this for years.
Great combo, but I think not really up to fast internet connections.
Do they still sell that model? Mine lasted 7 years before it started going flaky.
Offline SamirD
« Reply #51 on: Fri, 27 November 2015, 12:51:44 »
The three possible scenarios you seem to be facing are hardware failure on your existing router, channel crowding, or some sort of incompatibility between your device and routers.  The quickest and easiest way to confirm which one of these it is, is by setting up a stand-alone access point right next to your router with a different SSID and try connecting to it.
If your device connects, it is definitely not channel crowding, and could be hardware failure on your existing router or some sort of incompatibility.
If your device doesn't connect, it's definitely not hardware failure on your existing router and could be channel crowding or some sort of incompatibility caused by something software related on your device.
Either way, it will start to help you narrow things down before you invest in a whole new setup which may or may not solve the issue.
