Author Topic: HolyOops Keys with HHKB  (Read 21459 times)
Offline Vimto
« on: Sat, 28 November 2015, 05:14:21 »
Hi guys, If i got a HolyOops key, would it fit a HHKB if I got a Topre to MX slider as well?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline raymogi
Re: HolyOops Keys with HHKB
« Reply #1 on: Sat, 28 November 2015, 05:17:03 »
If it has circle stem, for sure.
The only thing that doesn't fit those sliders are Bro Caps cause they have square stem.
Please feed my addiction.
Offline Vimto
« Reply #2 on: Sat, 28 November 2015, 06:36:32 »
Looks like it's circular, that's awesome, now i just need to find some sliders.
Thanks for your help.
