Author Topic: POM Rainbow blank keycaps installation  (Read 3625 times)
Offline Sarabethq
« on: Thu, 03 December 2015, 12:12:26 »
Hello! I have read multiple threads about installing blank keycaps but Im just stumped. I have these rainbow pom ones and for the life of me I can't figure out where they go. Well, I have a general idea where to put them according to colors but some are smaller than the other and I have no idea what row to put them on. If someone is kind enough to help me I would appreciate it.
Offline bcredbottle
Re: POM Rainbow blank keycaps installation
« Reply #1 on: Thu, 03 December 2015, 12:19:00 »
The caps get taller as you go up the board (so the F1-F12 keys are the tallest). They should be the same width as the caps they're replacing, so start matching them and replacing them.
Offline Delirious
« Reply #2 on: Thu, 03 December 2015, 13:21:51 »
The best way is to flip them over and line them up. That way you can tell right the way the caps' alignments. Once you have them all group up according, use the modifiers such as Cap, Enter, Shift, Space bar to determine where should they go.
Offline Oobly
« Reply #3 on: Mon, 07 December 2015, 06:37:42 »
Well, not really, bottom row caps are taller than home row caps in general. It's the angle that changes as you go up that should be used as an indicator for the main area of the board with top rows being both "flatter" and taller.
You can also reference this image to see which should go where:
Use the OEM row.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Mon, 07 December 2015, 12:22:20 »
Look under the keycaps usually they label the rows.  R1, R2, R3...... etc.
Offline bcredbottle
« Reply #5 on: Mon, 07 December 2015, 12:31:13 »
sarahbethq got what she wanted and now she's out. rip sarahbethq.
Offline Sarabethq
« Reply #6 on: Tue, 22 December 2015, 09:27:57 »
Sarabethq gave up and has still not installed the keycaps. 911
Offline FLFisherman
  • I'd rather be fishing.
« Reply #7 on: Tue, 22 December 2015, 10:00:10 »
Hey there, fellow Miamian!
If you're still having trouble why don't you start with this:
 - Separate the keycaps into piles according to their slope (as shown by Delirious).
 - Take a picture of the piles and post it up here.
 - I (or someone else here) will identify them for you and let you know which cap goes on which row.
Easy as pie!
Offline bcredbottle
« Reply #8 on: Tue, 22 December 2015, 10:13:29 »
Easy as pie!
I don't think it's lack of instruction that's stopping her.
Offline Sarabethq
« Reply #9 on: Sat, 02 January 2016, 12:19:13 »
Okay so I was telling myself I'll do it after Christmas. So either today or tomorrow I will put them in piles and try not to cry telling myself I cant do this. And  hopefully I'll have installed my keycaps! *throws confetti
Offline bcredbottle
« Reply #10 on: Sat, 02 January 2016, 12:29:11 »
We've posted plenty of guidance on how to install these, and you haven't told us why the steps that we offered haven't worked, or whether you've even attempted to follow the instructions we've provided. No one can or will help you if you don't at least try and explain what went wrong.
