Author Topic: HHP2 slides on my table what should I do?  (Read 2291 times)
Offline slenderman1
« on: Sun, 06 December 2015, 12:55:16 »
my keyboard slides when I'm using it.
How do I prevent it from sliding?
« Last Edit: Sun, 06 December 2015, 12:58:39 by slenderman1 »
Re: HHP2 slides on my table what should I do?
« Reply #1 on: Sun, 06 December 2015, 12:59:27 »
You can cut a piece of drawer liner about the same size as your keyboard and put it underneath.
119301-0
^^ This is what I'm using.
There are also some rubber bumpers you can get I forget the exact recommended ones for the HHKB.
« Last Edit: Sun, 06 December 2015, 13:06:04 by SpAmRaY »
Offline slenderman1
« Reply #2 on: Sun, 06 December 2015, 13:09:22 »
Hey we have the same keyboard :P That's not a bad idea! But I found another solution. If you look at the back of your keyboard, you see the top area where there are two circles? THE reason why the keyboard is moving is because they didn't include rubber stuff there. That's the only reason why the keyboard moves. I found two rubbery thing and cut them out and placed it in that area and now it's not moving anymore :P
« Last Edit: Sun, 06 December 2015, 13:15:54 by slenderman1 »
« Reply #3 on: Sun, 06 December 2015, 13:21:43 »
- D Trump 2026-10-24
« Reply #4 on: Sun, 06 December 2015, 13:28:00 »
Shameless promotion of my own product:
https://geekhack.org/index.php?topic=59308.msg1863944#msg1863944
I can also vouch for this, I use fohats material under my keyboards at work. :thumb:
Offline slenderman1
« Reply #5 on: Sun, 06 December 2015, 13:29:08 »
Not a shameless promotion if it's a viable solution to the problem! thanks!
« Reply #6 on: Mon, 07 December 2015, 03:48:07 »
I use drawer liner under mine too.  It has the second benefit of dampening the echo from the desk, so I can enjoy the Topre thock more.
Also I was going to link fohat's thread, but he already did :))
Offline Polymer
« Reply #7 on: Tue, 08 December 2015, 05:28:51 »
Are your HHKB's sliding because the front rubber feet have become slick?  Or are you just pushing it really hard in a funny way?
