Author Topic: Best way to use brain wave  (Read 4102 times)
Offline Anon44
« on: Mon, 07 December 2015, 11:27:55 »
Does someone use brain wave to write?
If yes, how? Speech recognition of windows? Or a special device?
Thank you.
Offline dgneo
  • Supervillain
Re: Best way to use brain wave
« Reply #1 on: Mon, 07 December 2015, 12:00:04 »
Thank you.
I've used Dragon NaturallySpeaking in the past, and it works extremely well. Did you have questions about it/other solutions?
Offline Anon44
« Reply #2 on: Mon, 07 December 2015, 12:10:16 »
How do you use brain wave? With your brain wave reader? If yes, how does it works? (I am new into those kind of stuff)
Offline dgneo
  • Supervillain
« Reply #3 on: Mon, 07 December 2015, 12:11:21 »
You mentioned speech recognition, which is what Dragon uses. I didn't use a brain wave device (although it would be amazing to try one, no doubt about it).
Offline Anon44
« Reply #4 on: Mon, 07 December 2015, 12:21:16 »
I mean speech recognition by using cerebral wave.
Offline bcredbottle
« Reply #5 on: Mon, 07 December 2015, 12:40:48 »
Are you disabled? I hate to tell you but I believe this technology is very much in the developmental stages
http://www.kurzweilai.net/brain-to-text-system-converts-speech-brainwave-patterns-to-text
Offline baldgye
  • Will Smith Disciple
« Reply #6 on: Mon, 07 December 2015, 12:41:52 »
Got my hopes up about a vaporwave or dreamwave thread... oh well
