Author Topic: Thoughts on recently installed o-rings  (Read 2199 times)
Offline cryptokey
  • [°°▄°] luser-friendly
« on: Mon, 07 December 2015, 12:58:27 »
So I recently received some black o-rings from Aliexpress which costed me only $5.  They measure 8mm(outside diameter) x 5mm(inside diameter) x 1.5mm(thickness).  Having ordered them cheaply from an Aliexpress vendor and having never used o-rings before, my expectations were low.  After installing them on Cherry MX Browns on a POK3R, here are my thoughts:
- They noticeably reduce travel distance
- They're slightly squishy upon bottoming out compared to hitting the plate, however firm enough to still feel satisfying in my opinion.  I could see some people not liking this feeling though as there is a distinctly satisfying feeling/sound of bottoming out on Cherry MX switches
- They slightly reduce the noise created by the MX Browns by softening the bottoming out sound, but they by no means "silence" them
- They reduce fatigue due to a softer bottoming out and a smaller distance to press the key before bottoming out, provided you adjust and type lighter
In conclusion...
I bought o-rings partially to try them out and partially for ergonomics.  Note that I use proper typing form.  For my purposes, I feel like I am putting less strain on my fingers while typing and although I was most worried about losing the "clack" sound, I enjoy this softer sound as well.  If you are interested in improving ergonomics and don't mind sacrificing the "clack" sound and snappy bottoming-out feeling, then for $5 they're definitely worth it!  However, if you have no issues with ergonomics and/or love the sound and feeling of bottoming out on Cherry MX switches, then o-rings may not be for you.  At the end of the day, if you can find some for cheap like I did, give them a try and see for yourself!
Here's where I found mine, however there are many other sources for higher-quality ones:  http://www.aliexpress.com/item/Free-delivery-with-tracking-number-Black-Color-Bag-of-105pcs-Keycap-O-Ring-Switch-Dampeners-For/1305826637.html
[WTB] HHKB Black
Offline FLFisherman
  • I'd rather be fishing.
Re: Thoughts on recently installed o-rings
« Reply #1 on: Mon, 07 December 2015, 13:06:54 »
You know, $5 for o-rings with shipping included is not bad at all. I'm glad you're liking them. I've tried the o-rings that came with the CODE TKL and I was not a fan, though it does seem to have its merits.
Offline ddot
  • Master of Suspense
« Reply #2 on: Tue, 08 December 2015, 11:31:30 »
Offline ideus
  • Björkö.
« Reply #3 on: Thu, 10 December 2015, 07:55:28 »
O Rings are too mushy for me, I am still waiting for IMSTO's balls to try them and I would love to try some Cherry silencers.
Offline kekman
  • quit life
« Reply #4 on: Thu, 10 December 2015, 16:10:07 »
Would Orings be good for anyone practicing not bottoming out? Seems like if there was a way to consistently reduce the amount you press your keys, this would be the way to do it.
Offline ideus
  • Björkö.
« Reply #5 on: Thu, 10 December 2015, 23:16:52 »
They may have the opposite effect, because the shorter travel and the mushy feeling may move your point of return lower.
« Reply #6 on: Sun, 13 December 2015, 03:48:28 »
That would take some explaining ...
Q: What makes your keyboard feel go great?
A: IMSTO's balls!
