Author Topic: Guys, I need some help to buy Topre keycaps.  (Read 6136 times)
Offline Jaaaaaaaaaaaaaaaaaaaaaaay
« on: Mon, 14 December 2015, 23:12:52 »
Hi,
Now, I'm looking for the keycaps for my Happy hacking pro2.
What I need is the blank modifier keycaps.(tab, ctrl, shift, 2 alts, small shift, enter, backspace, context, and Fn)
Any dark color should be good (dark brown, Pure black, and so on), Different colors for Fn and context key will be fine too.
Where should I go for buying those keycaps......
Any recommendations?
Ibm model M(Grey lable 1992)
GTune MKF20(kailh Blue)
Happy Hacking Professional 2(Black)
Realforce 87UB(Black)
Realforce 87UW45(White)
RC930 - 104 RGB(55g)
Filco Majestouch2 Tenkeyless(MX Brown)
Offline Cicada88
Re: Guys, I need some help to buy Topre keycaps.
« Reply #1 on: Tue, 15 December 2015, 02:34:32 »
pm sent!
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #2 on: Tue, 15 December 2015, 02:40:59 »
if anyone know a place to get black blank tab Id be sooooo happy :/
One of the sets I got when I traded my Realforce for a HHKB had ONE printed cap on a blank set :/
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline Cicada88
« Reply #3 on: Tue, 15 December 2015, 02:53:40 »
I have one but shipping outside the US for a single cap is pretty bad.
« Reply #4 on: Tue, 15 December 2015, 03:39:46 »
To get all those, you'd have to find someone who broke or disassembled an HHKB, or buy a full set yourself and just use the keys you need.
http://www.elitekeyboards.com/products.php?sub=access,toprekeys&pid=pdkb400ktbn
« Reply #5 on: Tue, 15 December 2015, 10:07:06 »
« Reply #6 on: Tue, 15 December 2015, 10:09:38 »
Oh... ok, that sounds like the one that I want is very hard to find :(
« Reply #7 on: Tue, 15 December 2015, 10:10:55 »
I may be able to pay for that if that is just what I want. :D
« Reply #8 on: Tue, 15 December 2015, 10:11:47 »
Thanks for the rink :D
Offline Cicada88
« Reply #9 on: Tue, 15 December 2015, 12:00:05 »
I  sell individual blank HHKB keycaps :)
« Reply #10 on: Tue, 15 December 2015, 12:03:19 »
Rude.
« Reply #11 on: Tue, 15 December 2015, 14:00:13 »
Rude.
OOOOOOOOps.... sorry, I was too sleepy this morning. :(
« Reply #12 on: Tue, 15 December 2015, 14:08:23 »
Offline Cicada88
« Reply #13 on: Tue, 15 December 2015, 15:37:44 »
here's the dark green, you can also check my running topic in the artisan forum
« Reply #14 on: Tue, 15 December 2015, 19:31:06 »
What a cool keycaps :D
I will go check the forum :) thanks a lot.
Offline hammelgammler
« Reply #15 on: Fri, 12 February 2016, 14:33:13 »
PM'd. I got a Realforce a few days ago with one blank Tab key. Every other key is printed though. Coincidence?  :eek:
