Author Topic: Model F key chain testers and other stuff  (Read 4837 times)
« on: Mon, 21 December 2015, 07:19:40 »
Orihalcon has some nifty little switch testers with clear bases so that you can see them in action:
http://www.ebay.com/itm/IBM-Model-F-Buckling-Spring-KEYCHAIN-Clicky-Keyboard-Switch-Tester-AT-XT-M-/272068806420?hash=item3f58908714:g:HRQAAOSw7FRWZMgs
And, as always, he has lots of other great stuff up for sale, including rare IBM keyboards, at fair prices.
- D Trump 2026-10-24
Re: Model F key chain testers and other stuff
« Reply #1 on: Mon, 21 December 2015, 07:48:39 »
Awesome, gotta get one for my keychain collection.
Offline Bucake
« Reply #2 on: Mon, 21 December 2015, 14:17:06 »
shoulda been cool if the cap was clear as well 8)
« Reply #3 on: Mon, 21 December 2015, 18:44:44 »
Both parts of the cap?
Offline 0100010
  • Not Sure
« Reply #4 on: Tue, 22 December 2015, 11:15:45 »
Nice!  Looks like he used glue, where I used screws (forcing the use of Model M hammers on mine).
Offline Bucake
« Reply #5 on: Tue, 22 December 2015, 15:44:40 »
i was thinking single-piece caps (like his chains are using),
but i doubt anyone's up for making clear model F caps
« Reply #6 on: Tue, 22 December 2015, 17:03:51 »
And even if they did, probably too much plastic to see clearly what's happening inside.
Offline orihalcon
« Reply #7 on: Wed, 23 December 2015, 00:12:26 »
If you look really closely, you can see the spring buckle from the underside if you have it upside down when pressing.  It's easier to see it pop back into the normal orientation afterwords though :cool:
Offline 1391406
« Reply #8 on: Wed, 23 December 2015, 01:13:24 »
This would make a nice charm. I'm not sure I understand where you're supposed to attach your keys. There's no keyring.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #9 on: Wed, 23 December 2015, 18:28:58 »
There's a little clip at the end. I use the exact same loops for my Alps and Omron keyring switches.
Offline 1391406
« Reply #10 on: Wed, 23 December 2015, 19:39:03 »
You're referring to the lobster clasp. I have a bag full of them and the clasps are generally made to accommodate the link on a charm bracelet or a zipper pull and are a lot weaker than a key ring. Further, how many keys can a lobster clasp really hold? One or two at best. I think the idea behind the product is great, though I'd strongly recommend a key ring rather than a lobster clasp, and I'd swap the string with a few bracelet links. That would would look great and be far more reliable. You can buy approx. 50 key rings for a few bucks. They're pretty cheap. This is strictly meant as constructive criticism.
Offline SamirD
« Reply #11 on: Thu, 24 December 2015, 07:07:38 »
Pretty neat.  Do they still make the classic sounds of an F?
« Reply #12 on: Thu, 24 December 2015, 08:19:10 »
Semi.
Probably louder, actually, but with a light plastic resonance instead of a heavy metal undertone, since it has no real sounding board.
Offline SamirD
« Reply #13 on: Sun, 27 December 2015, 15:56:52 »
Semi.
Does putting a quarter under it help?  It would be interesting if just adding a 1/8" piece of steel would do the job.
« Reply #14 on: Sun, 27 December 2015, 16:49:48 »
Think of the sounding board of a piano. It is the overall resonance of the entire assembly.
The keychain is a novelty item, not a serious audition.
Offline SamirD
« Reply #15 on: Tue, 29 December 2015, 06:40:47 »
Good point.  At best, it's a showcase of the mechanism.
