Author Topic: Spacebar much louder than other keys  (Read 4846 times)
Offline Geroximo
« on: Mon, 21 December 2015, 15:40:25 »
Hi mates,
Poker 2 with MX Blues
OG Cherry PBT caps, damped case
All the keys make a pretty statisfying deep click, bottoming out makes a deep thock. Everything sounds nice and sophisticated.
But the goddamn spacebar ... this thing sounds just cheap and loud and light and is ratteling like some super cheap china plastic.
I already installed an O ring. But it still sounds cheap.
Is there a way how to silence a spacebar, so that it sounds worthy like all the other keys, and not like a cheap piece of china plastic?
« Last Edit: Mon, 21 December 2015, 16:41:32 by Geroximo »
Offline Reigning Hell
  • Forever Fiending 4 a V2
Re: Spacebar much louder than other keys
« Reply #1 on: Mon, 21 December 2015, 15:52:50 »
I have a poker 2, I know exactly what you mean. Every key sounds fine, even all of the mods; but the spacebar just sounds so clunky.
« Reply #2 on: Mon, 21 December 2015, 19:49:56 »
Maybe try putting small squares of plastic over the stabiliser stems (and/or switch) before you install the space bar.   Might make it a bit tighter.
Offline ideus
  • Björkö.
« Reply #3 on: Tue, 22 December 2015, 10:49:57 »
I silenced mine using an IMSTO ball, you could do the same with a segment of oring, just be sure its diameter goes inside the internal tube of the switch. It works like charm.
