Author Topic: Granite Round 4 design update  (Read 179096 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
Re: Granite Round 4 design update
« Reply #200 on: Thu, 07 January 2016, 03:04:33 »
hi   matt3o
please   add  the  cat  to  bouns pack
cat key was a limited edition done for my wife :) never gonna happen again
Offline abyx
« Reply #201 on: Thu, 07 January 2016, 04:21:45 »
How about the hacker emblem?
Offline pomk
« Reply #202 on: Thu, 07 January 2016, 12:19:06 »
Any chance of adding the pipe/slash key to the elven set? Seems a bit silly to buy the base set for just one key and spacebar (and the function keys if you go full size), which you can buy separately anyway. Or is it supposed to go with the HHKB backspace :) ?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #203 on: Thu, 07 January 2016, 12:34:42 »
have to check with massdrop on that.
Offline ideus
  • Björkö.
« Reply #204 on: Thu, 07 January 2016, 16:48:17 »
Is there a final design defined already? Are you gonna share it here, or we should wait for MD to post the drop?
Offline dohbot
« Reply #205 on: Thu, 07 January 2016, 16:49:45 »
What about a red backspace key in icon and text extra packs?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #206 on: Fri, 08 January 2016, 01:39:15 »
I'm still waiting for the quote from SP. With that we will make some adjustments and publish the final design.
Offline ideus
  • Björkö.
« Reply #207 on: Fri, 08 January 2016, 07:35:15 »
Awesome, thank you for the answer.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #208 on: Fri, 08 January 2016, 08:15:07 »
If you don't want to go with the number row on the original 'secondary' mock up:
Can you consider making the number row the same style as these? Centred lower legend with split upper legends:
The design from the imgur album, with the empty space on the top right quarter, makes my skin itch  :p
In my opinion on this style of number row:
It will look strange if you wanted to mix them with any of the international number row keys (which have centred primary legends and secondary legends off to the side).
If will look strange if you wanted to mix them the included numpad secondary legends.
There is no 'offset' version of the backslash key, so it would look strange with a split backspace layout (on the HHKB layout backslash has a secondary function on insert, tilde has the function of delete).
Basically, style wise they are not mix and match like all the other secondary legend keys  :(
The ability to use a mix of kits to fill out any keyboard, due to the uniform profile and aesthetics, is one of the biggest achievements of the granite set  :)
Just my 2 cents  :thumb:
« Last Edit: Fri, 08 January 2016, 08:20:37 by nathanrosspowell »
Offline Jedi
« Reply #209 on: Fri, 08 January 2016, 08:43:20 »
That is beautiful, may I ask what keyboard you used for those awesome keys.
« Reply #210 on: Fri, 08 January 2016, 09:55:57 »
That's one of Matt3o's personal custom builds.
Offline Latin00032
« Reply #211 on: Fri, 08 January 2016, 11:26:30 »
If I already have a granite set, if I just get some add on sets, will they still match?
I don't know if a slightly different pbt color is being used.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #212 on: Fri, 08 January 2016, 11:41:52 »
They'll match.
Offline ddot
  • Master of Suspense
« Reply #213 on: Fri, 08 January 2016, 11:43:47 »
Will there be any changes to the Ergodoxian kit?  Have you given any thought about rotating the legends 90 degrees on the = and - keys?
I second some additional 1.5u keys being rotated 90 degrees.  With 4 of those rotated 1.5u spots and only 4 keys with rotated legends, your options are limited.  Everyone is going to have different layouts, but the =+ and -_ are probably as good a candidates as any.
While I'm dreaming, including the 1.5u backspace key may be useful for those that don't map the backspace into their thumb cluster.
Also, any chance on the cut/copy/paste keys making a return?
Offline OneDudeWolfPack
« Reply #214 on: Fri, 08 January 2016, 13:36:25 »
I like the undo/cut/copy/paste keys as well on my blank Ergodox.  Kinda wanted to add some color to them this round.
@Matt3o: was there any reason why the Text RGB kit doesn't have a Green Shift in 1.5u/1u and Red Control in 1u?  Not trying to get overboard, but just noticed that when I pulled out my baggies from Round 2 or 3.  With the new Planck (Grid type) keyboards have any of  those users asked for those keys in RGB?
« Last Edit: Fri, 08 January 2016, 15:09:17 by OneDudeWolfPack »
WASD V2 Blue MX 87-key Granite R2 | WASD Code Clear MX 104-key w/ Granite R1 | Ergodox #1 - Full with Green MX & Granite R3 keycaps | Ergodox #2 - Full with Blue MX Granite R2
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #215 on: Fri, 08 January 2016, 16:09:20 »
if it were for me I would put every possible key combination. I think that if you can spend $150-200 in a keyset you can spend $200-250 and have it perfect.
That being said I understand that we have to keep the price down as much as possible, so adding an infinite number of combinations is not actually possible.
Offline Arcoril
« Reply #216 on: Fri, 08 January 2016, 18:39:09 »
Looking good! But would it be possible to add 1u modifiers to the RGB pack (or maybe a separate pack) for us color coordinated WhiteFox/Planck/JD40/Ergodox users?
Offline UTEster750
« Reply #217 on: Sun, 10 January 2016, 00:18:55 »
Will SP do single order sets?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #218 on: Sun, 10 January 2016, 01:09:15 »
we've got pricing! Now few updates and I'll post the final version.
Offline Zapheo
  • There's nothing that I wouldn't do.
« Reply #219 on: Sun, 10 January 2016, 02:51:49 »
Hey Matt3o when is the gb going live?
I need more keyboards to hold all of these keycaps.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #220 on: Sun, 10 January 2016, 04:27:18 »
as soon as the MD page is ready, this week for sure
Offline Zorberema
  • IG: @ZorbCaps
« Reply #221 on: Sun, 10 January 2016, 04:36:17 »
This week as before monday or before next sunday? :P
Offline Kibort
« Reply #222 on: Sun, 10 January 2016, 04:56:44 »
can't study properly because i'm watching the massdrop page constantly :p
Offline UTEster750
« Reply #223 on: Sun, 10 January 2016, 04:57:58 »
The drop will be up for a few days so you can relax for a bit  :p
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #224 on: Sun, 10 January 2016, 09:14:05 »
this coming week if your week starts on Monday. This week if it starts the wrong day.
Offline yoobe
  • Yoobe
« Reply #225 on: Sun, 10 January 2016, 10:03:46 »
I personnaly like one color for all F-Keys. What about a pack to have all grey or white F-Keys?
Yoobe
ErgoDox - Mx Brown
Filco Minila Air - Mx Red
RedScarfII+ VerC - Gateron White
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #226 on: Sun, 10 January 2016, 10:51:17 »
YES! that has been included in the bonus pack!
Offline Zapheo
« Reply #227 on: Sun, 10 January 2016, 18:30:02 »
Will it still be live by this coming Friday?
Offline cryptokey
  • [°°▄°] luser-friendly
« Reply #228 on: Sun, 10 January 2016, 19:53:04 »
Will we ever stop asking you when it will be live?  ;)
[WTB] HHKB Black
Offline ideus
  • Björkö.
« Reply #229 on: Sun, 10 January 2016, 19:55:18 »
Of course, it will stop when the drop becomes live.
« Reply #230 on: Sun, 10 January 2016, 23:21:12 »
Wa, wa.
Offline BigDov
« Reply #231 on: Mon, 11 January 2016, 00:34:01 »
How do you feel about this:
The RGB could be something like this, but I have to check on pricing first.
Beautiful!!! My ergodox is screaming for that......great great GREAT combo!
edit: I think a 1.5 backspace key would finish off the ergodox set as well, maybe I'm in the minority in that, but I like my backspace on my pinky :)
« Last Edit: Mon, 11 January 2016, 01:19:41 by BigDov »
ergodox w/ MX Blues & Granite R4 + grifiti wrist rests || CM Storm QFR w/ Reds & black PBT laser-etched caps
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #232 on: Mon, 11 January 2016, 02:19:22 »
in which orientation?
Offline BigDov
« Reply #233 on: Mon, 11 January 2016, 10:17:51 »
Horizontal, so I could place it over at the end of the top or second from the top row. If not possible, not a huge deal, I could always place a blank there.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #234 on: Mon, 11 January 2016, 10:21:21 »
can you show me some pictures or introduce me to some users who use that key in that orientation?
Offline BigDov
« Reply #235 on: Mon, 11 January 2016, 10:40:33 »
:) like I said, I could be a minority! I will see what I can find and post here.... but, a blank pack solves this for me just as well, or I learn a more "standard" ergodox layout.
edit: there are a couple on this page, actually some of the first boards I was tempted by when getting into an ergodox  http://xahlee.info/kbd/ergodox_keyboard.html
edit2: a couple here, too  http://keypuller.com/granite/
« Last Edit: Mon, 11 January 2016, 10:49:27 by BigDov »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #236 on: Mon, 11 January 2016, 10:54:27 »
okay, sold. Let's see if I can fit it...
EDIT: actually... you would need the pro-modifiers anyway for ctrl/alt, so I am not so sure the "back space" is really needed in the ergodox kit
« Last Edit: Mon, 11 January 2016, 12:11:33 by Matt3o »
Offline BigDov
« Reply #237 on: Mon, 11 January 2016, 12:50:35 »
that sounds good to me Matt3o, I can adjust easily... in fact, that has made me go back and evaluate the layout. Another pack to solve this isn't the end of the world to me. Thanks!!
edit: I just went back and looked at the imgur album again, I must have missed the 1.5 backspace in the pro-modifier pack completely! Thanks for bringing it to my attention.
« Last Edit: Mon, 11 January 2016, 13:00:00 by BigDov »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #238 on: Mon, 11 January 2016, 13:00:34 »
few updates.
the ANSI legends on the sindarin kit are way smaller now. The secondary legend kit has a more pleasant number row. The bonus pack has some extras. Monolegend has | and _. Extra homing got a 5.
Offline FLFisherman
  • I'd rather be fishing.
« Reply #239 on: Mon, 11 January 2016, 13:04:50 »
few updates.
Those elves and their fancy alphabets. I'm going to guess it's LotR Elvish, right?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #240 on: Mon, 11 January 2016, 13:05:31 »
it is, yes.
Offline thaddeus
« Reply #241 on: Mon, 11 January 2016, 14:03:03 »
The number row (secondary pack) looks way better like this.  :thumb:
« Reply #242 on: Mon, 11 January 2016, 14:04:23 »
No more complaints from me, I promise ;D I'm now ready to hand over all my money  :thumb:
Offline BigDov
« Reply #243 on: Mon, 11 January 2016, 16:46:33 »
Same here, this is looking pretty amazing.
Offline Delete
« Reply #244 on: Mon, 11 January 2016, 19:04:50 »
this  time ,the   6u  Spacebar  is  dropped,  how  i  should  use  on  cherry G80-  1865,1869&1808 keyboards?
   please
Offline ideus
  • Björkö.
« Reply #245 on: Mon, 11 January 2016, 20:20:19 »
Secondary legend makes it for me.
« Reply #246 on: Mon, 11 January 2016, 20:29:55 »
   please
I think this is what you need
Quote from: Pimp My Keyboard
6 SPACE GRAY (GKK) : http://pimpmykeyboard.com/dsa-spacebars-pack-of-1/
Offline QuickDelat
« Reply #247 on: Tue, 12 January 2016, 06:09:05 »
« Reply #248 on: Tue, 12 January 2016, 07:21:28 »
and it's on Massdrop https://www.massdrop.com/buy/granite-keycap-set?mode=guest_open
Awesome!
Secondary kit and ISO enter ordered
This is the third round of Granite I've spend money on haha.
Offline Brammm87
« Reply #249 on: Tue, 12 January 2016, 07:22:59 »
My first round. The MD order form is a pain if you want to get lots of extras. Anyway... 300$ later... Let's hope my accountant believes the "I need this for work" spiel.
pls gief bbv2
