Author Topic: Custom Keycaps - WASD vs. Max Keyboard  (Read 6410 times)
Offline capnyank
« on: Wed, 30 December 2015, 15:58:59 »
Hi all! I'm looking at getting my first set of custom keycaps to mod my CM Storm Quickfire Rapid and would like to get your thoughts. I'd like to get a custom color full set (87 key) at $50 or less. Both Max and WASD have some good color options but I'm not really sure of the quality. I've read in some of the reviews that Max's keys are somewhat thin ABS so I'm thinking of skipping them for WASD.
Otherwise, do you have any other recommendations for a full set with cool colors at less than $50 that's good quality? I'm not really looking at an all one color set and I don't want to have to piecemeal single keys or smaller sets together.
Offline bcredbottle
Re: Custom Keycaps - WASD vs. Max Keyboard
« Reply #1 on: Wed, 30 December 2015, 16:05:41 »
I would just get Gateron, Leopold, or Vortex. They're going to be way thicker/higher quality.
Offline capnyank
« Reply #2 on: Wed, 30 December 2015, 17:26:56 »
Thanks for the suggestion - any recommendation on where I can purchase these?
Offline bcredbottle
« Reply #3 on: Wed, 30 December 2015, 17:33:01 »
http://www.amazon.com/Vortex-White-Doubleshot-Keycaps-blue-infill/dp/B00XA71BQC/ref=sr_1_2?ie=UTF8&qid=1451518178&sr=8-2&keywords=vortex+pbt
http://www.ebay.com/itm/PBT-Keycap-Set-for-Cherry-MX-based-Leopold-Keyboard-Blank-Non-Printed-Navy-/281664522419?hash=item41948388b3:g:NOEAAOSwh6xTttxK
^   I have both of these  keysets and they're very nice thick PBT.
Gaterons I think you'll need to get secondhand or through a proxy buyer.
I believe the caps labeled "thick" on geekkeys are 1.5mm thick, which is the standard for quality caps, but I've never used them so I can't attest to their feel. http://www.geekkeys.com/keysets/
Offline capnyank
« Reply #4 on: Thu, 31 December 2015, 20:38:41 »
I ended up ordering the Vortex set on Amazon for $34.99. Thanks!
Offline Waateva
« Reply #5 on: Sat, 02 January 2016, 15:34:26 »
They're a good set, I use them on my v2 at work.
