Author Topic: Help with the stabilizer and keycaps  (Read 3811 times)
Offline Abula
« on: Fri, 01 January 2016, 13:18:11 »
Hi,
I have a filco MajesticTouch 104, and i just got my Carbon SA Keycap Set, and its great all fits fine, but the problem that i have is the stabilizers, well maybe not the stabilizer themselves but the white plastic holders, in the removal and installation some fit a little loose, specially the space bar and shift keys, thus pushing from the sides sometimes i get not so fluid motion down of the keys, i blame the plastic holders moving up and down because its not so snug fit.
I wanted to ask you guys, what should i do, or what do you guys do?
1) Plastic stabilizer holders
Should i do something permanent like crazy glue? or should try to do something temporal and not permanent, maybe a silicone to create a gasket?  What do you guys do?
2) Lubricating the Stabilizers
I been searching the forums, and watching some videos on youtube, and seems like a good thing to do now that im swaping keys.  What lube do you guys recommend for the filko stabilizers? the ones that i seen are
- Super Lube 21030 Synthetic Grease (NLGI 2), 3 oz Tube
- DuPont Krytox GPL 205 Grease, Pure PFPE / PTFE No Additives, 0.5 oz Tube
- EliteKeyboards MechLube 2 Premium Keyboard Lubricant w/PTFE
Or do you have anyother that works better?
Thanks for your time and suggestions,
Topre Realforce 87UD 10th Anniversary Edition || Vortex Race 3 || Ducky Shine 5 RGB || Filco Majestouch 104 || Logitech G810
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Help with the stabilizer and keycaps
« Reply #1 on: Fri, 01 January 2016, 13:22:34 »
Do not glue the stab inserts! Just take a piece of tape or even a little square of a plastic bag and put it over the insert before putting the caps on. I do this with several keysets and it works great. I typically use tape.
Offline keshley
    • Blog n stuff
« Reply #2 on: Fri, 01 January 2016, 13:49:38 »
I use tiny scraps of paper, same principal. Works great.
HHKB Pro 2       Pok3r
Offline Abula
« Reply #3 on: Fri, 01 January 2016, 19:10:39 »
Thanks for the replies,
The square of bag did the trick, now all fit snug like the originial and the Carbon set works like OEM,
Thanks again,
