Author Topic: Hello Clackers  (Read 2182 times)
Offline r00tbox
Hello Clackers
« on: Sat, 02 January 2016, 06:09:38 »
Hi,
i'm r00tbox (27, male) from Germany and i love Mechs at work i'm the weird keyboard Guy, but i guess you also know that :-D
I currently own only Noppoo Choc Mini with MX Brown (prevously Pok3r with Clears and Novatouch) and i do a detachable USB Calble as soon as the parts arrive.
Also i'm building a Atreus and an a Planck as soon as the parts arrive and didn't decided know which switches i will use (Mathis Quiet Click  (Linear for Mods), MX Clears (Gateron Blacks for Mods), Gateron Blue (Gateron Blacks for Mods), Zealios Purple 65g, also the Blacks for Mods)
Maybe there i try an ergodox later but i'm a soldering newbie and i want to try easier boards before.
Cheers.
Re: Hello Clackers
« Reply #1 on: Sat, 02 January 2016, 09:55:06 »
Are you r00tw0rm's relative?
Offline r00tbox
Re: Hello Clackers
« Reply #2 on: Sat, 02 January 2016, 10:57:15 »
No, i'm not ;-)
Re: Hello Clackers
« Reply #3 on: Sat, 02 January 2016, 13:59:24 »
damn, almost cracked the case
Re: Hello Clackers
« Reply #4 on: Sun, 03 January 2016, 04:11:48 »
Welcome to Geekhack!
I though of r00tw0rm when I first saw your username :))
I'm the weird keyboard guy at my work too!  I'm happy in my insanity :D
Have a look at the soldering thread - lots of tips and tricks there.  Also if you can find some old broken electronic device, an old DVD player or stereo or computer motherboard, you can practice desoldering components and soldering them back on.  It won't matter if you break anything (the board would be broken before you start), and after a few components you should begin to feel soldering getting easier.  Then maybe move up to a simple soldering kit or two from your local electronics store.  After that building a keyboard should be simple :)
Offline r00tbox
Re: Hello Clackers
« Reply #5 on: Sun, 03 January 2016, 08:17:10 »
The funny thing is that i have an old DVD Player at my desk and it's not worth selling :-D
Re: Hello Clackers
« Reply #6 on: Mon, 04 January 2016, 20:28:33 »
:thumb:
