Author Topic: IBM Model M (where to buy refurbished, not used)  (Read 7623 times)
Offline cnnx
« on: Mon, 04 January 2016, 23:51:26 »
So its been exactly a year since I've received by new in box ibm model M by lexmark 1995 from ebay and I couldn't be happier.  What would make me happier? To buy another one of these as a spare, and to make it better I'd the original IBM model not the lexmark model (I heard the quality is better and they are heavier too).  My question to you guys, where is a place I can order this keyboard from that will ship to Canada? there's a few on amazon.com but they wont ship here.  Refurbished is fine, new in box might be too $$$ or hard to find.  PM me or reply here, thx.
« Last Edit: Mon, 04 January 2016, 23:53:40 by cnnx »
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: IBM Model M (where to buy refurbished, not used)
« Reply #1 on: Mon, 04 January 2016, 23:56:33 »
Get a bolt-modded IBM 1391401 from Phosphorglow!  Don't compromise!
http://phosphorglow.net/
« Reply #2 on: Tue, 05 January 2016, 00:02:29 »
+1
No personal experience, but I have not heard the slightest negative whisper about him, and the photos on his web site illustrate miracles performed with ancient keyboards.
Offline fanpeople
« Reply #3 on: Tue, 05 January 2016, 00:06:29 »
There is also Clicky keyboards but they seem to be getting a little pricey now.
http://www.clickykeyboards.com/index.cfm/fa/search.results/keywords/e/orderBy/lowestPrice%20asc/prodDesc/0/endrw/24
« Reply #4 on: Tue, 05 January 2016, 07:42:35 »
The heaviest plates ended around 1988 but it seems to vary considerably by plant.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #5 on: Tue, 05 January 2016, 08:24:35 »
The original, old IBM models are heavier as they used thicker plates, and of course IBM just plain sounds better than Lexmark, but in terms of typing experience I haven't found any real difference between even extremely old IBM models and late Lexmark ones, to be honest. There are many myths like that circulating around the keyboard community though :p .
Offline Snowdog993
« Reply #6 on: Tue, 05 January 2016, 10:50:39 »
The builds came out of the same factory too!  I don't get it.
Look at the build dates too.  I want this myth to END.
« Reply #7 on: Tue, 05 January 2016, 11:13:09 »
There are a lot of blank slots and question marks, but the general consensus is that Lexmark started making blue label IBM Model Ms around mid-1992 as a sideline to their printer business and sold the Lexington plant to Unicomp in 1996.
I have never seen the specifics on the time-frame and rationale behind Lexmark-branded Model Ms, but they seem to be uncommon and probably happened near the end of the run.
https://en.wikipedia.org/wiki/Lexmark
https://en.wikipedia.org/wiki/Model_M_keyboard
Offline Snowdog993
« Reply #8 on: Tue, 05 January 2016, 11:32:36 »
That would be true (if you only knew that the 1398601 IS a Lexmark Model M.)
http://imgur.com/a/p6kmH
1992.
Edit: This kind of throws everything on it's own head.
« Last Edit: Tue, 05 January 2016, 11:40:07 by Snowdog993 »
Offline livingspeedbump
    • KeyChatter
« Reply #9 on: Tue, 05 January 2016, 11:55:51 »
+1 he is legit.
<- My Collection (so far)
Offline SamirD
« Reply #10 on: Wed, 06 January 2016, 08:04:36 »
Every so often you can find a company selling 'refurbished' Ms at a decent price.  But they're usually just basically cleaned (not opened) and work.  If you want a superior backup at a great price, phosphorglow is the way to go.  At one point he had an M listed that had a lot of love and care in it for a very reasonable price.  If all his work is priced out that way, you can be sure that it's a superior value.
