Author Topic: Leopold keycaps  (Read 2477 times)
Offline elmer
Leopold keycaps
« on: Tue, 05 January 2016, 12:19:00 »
Hi
I just got a leopold FC750 with white keycaps and i'm pretty new to the world of mechanicals keyboards  :D
I'd like to pimp it a bit but I noticed that the leopold keycaps dont have OEM profile, so i was wondering if it was DCS or another one?
Does anyone know if it's possible to buy custom keycaps with leopold profile ?
Best regards
Offline KnivesM
Re: Leopold keycaps
« Reply #1 on: Tue, 05 January 2016, 12:56:41 »
Hi
Best regards
Leopold 750R's and other new model boards stock caps are Step Sculpture 2 profile it's close to Cherry profile which DCS is imitating.
No, you can't buy custom Leopold caps to my knowledge, you can buy keycaps for it that are DCS, OEM, or any of the other profiles though.
Others
Offline elmer
Re: Leopold keycaps
« Reply #2 on: Tue, 05 January 2016, 14:58:04 »
Thks  :)
