Author Topic: Model M Led Mod  (Read 6677 times)
Offline BradTheGeek
Model M Led Mod
« on: Wed, 06 January 2016, 13:10:26 »
Needs a touch more work, but I like it.  Thanks to E29 for model information.
The full build can be found here: http://imgur.com/MuZyC/
123052-0
123054-1
Let me know what you think, and I will try to answer questions as I have time!
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: Model M Led Mod
« Reply #1 on: Wed, 06 January 2016, 13:16:38 »
1393464 01-16-1992.
Not a bad day for it.
Ironically, mine is made exactly 2 years earlier!
« Last Edit: Wed, 06 January 2016, 13:21:34 by Snowdog993 »
Offline E TwentyNine
    • Some of My Keyboards
Re: Model M Led Mod
« Reply #2 on: Wed, 06 January 2016, 13:38:57 »
Nice.  I'm not big on LED's, but if I were to do one, I love the whole color changing thing.
Regarding your spacebar stabilizer and the hooks the wire slips into, don't go removing LEDs just yet.   You may want to try putting a couple of washers (in your case, transparent plastic ones) over the barrels on the V and M keys so the wire can slip under that.  May be a little noisy if they're not secured, but you get to keep those LEDs.
Offline SamirD
Re: Model M Led Mod
« Reply #3 on: Wed, 06 January 2016, 13:49:44 »
Pretty interesting.  Not my thing, but it does light up nicely.  :thumb:
Offline BradTheGeek
Re: Model M Led Mod
« Reply #4 on: Wed, 06 January 2016, 14:38:25 »
I think I may have to lose those LEDs under the top of the space bar.  The retention wire cannot attach with them in place, and washers won't help that I can see.  This leave the space bar mushy and with poor response, you have to really hammer it.
The space bar blocks most of the light from that 3-4 LED segment, so I do not think it will affect the visual aspect much.
Besides if I wanted mushy and unresponsive, I'd get a Dell QuitetKey :)
Offline Snowdog993
Re: Model M Led Mod
« Reply #5 on: Wed, 06 January 2016, 17:11:33 »
It is interesting.  I was thinking of a way to make it look even better, and the one thing that comes to mind is having it in a transparent clamshell.  It could be different colors, but you can see the guts inside through it.
That might be very cool.  I don't know.
Re: Model M Led Mod
« Reply #6 on: Thu, 07 January 2016, 02:03:17 »
Nicely done :)
Offline bocahgundul
  • a seal
Re: Model M Led Mod
« Reply #7 on: Thu, 07 January 2016, 02:39:35 »
Cool project
Offline Bucake
Re: Model M Led Mod
« Reply #8 on: Thu, 07 January 2016, 06:50:18 »
sexy! blue's a good color : )
Offline BradTheGeek
Re: Model M Led Mod
« Reply #9 on: Thu, 07 January 2016, 08:16:39 »
My favorite color is electric blue.  But, I can change color to suit mood, now it is dull green :)
Re: Model M Led Mod
« Reply #10 on: Thu, 07 January 2016, 08:52:45 »
No such thing!
Offline tronbeaver
Re: Model M Led Mod
« Reply #11 on: Thu, 07 January 2016, 09:01:26 »
Shouldn't this be in "Making Things Together"?
Offline BradTheGeek
Re: Model M Led Mod
« Reply #12 on: Thu, 07 January 2016, 09:28:58 »
If it should be moved, I won't be mad if a mod moves it.  Much like your avatar, I am a noob here and do not know all the subforums and local culture!
