Author Topic: Octagon V2 75% Kustom Keyboard Group Buy (Closed for Orders)  (Read 571546 times)
Offline axm2
Re: Octagon V2 75% Kustom Keyboard Group Buy
« Reply #1350 on: Sun, 05 March 2017, 16:21:06 »
Yeah I tried that one too, doesn't work.
edit: Tried it on 3 windows 10 pc's, and it just worked like a normal keyboard everytime :(
edit2: Pause/Break doesn't appear to work in the key tester, could that be an issue?
« Last Edit: Sun, 05 March 2017, 20:15:07 by axm2 »
Offline yookwh
« Reply #1351 on: Mon, 06 March 2017, 10:44:08 »
Is this on a board you just made? Or did you buy it pre-built? If it's the latter, did it happen all of the sudden, or when you received it?
Offline axm2
« Reply #1352 on: Mon, 06 March 2017, 10:55:59 »
Bought it from another user, I fixed it now though. One of the solder joints came loose during shipping. Should've been the first thing I checked honestly, oops.
Offline P1kas
  • AKA Crono
« Reply #1353 on: Sat, 11 March 2017, 22:07:21 »
Has anyone weighed this board? I'd like to see how it compares to other top mount 75% cases.
Offline gaiden
« Reply #1354 on: Sat, 11 March 2017, 22:26:55 »
5.5lb or ~2.5kg
Sent from my SM-G935F using Tapatalk
Offline yookwh
« Reply #1355 on: Sat, 13 May 2017, 21:59:53 »
Deleted
« Last Edit: Sun, 14 May 2017, 18:46:50 by yookwh »
Offline Charizard
« Reply #1356 on: Sun, 21 May 2017, 02:09:18 »
Is there a PCB diagram for these boards anywhere?  My enter key isn't working and I'm trying to repair, but hard to see where some of the traces are going...
Offline -musubi
  • Spam rice 'n eggs
« Reply #1357 on: Wed, 24 May 2017, 00:15:31 »
Well who would've thought I'd screw up my most prized possession... thought I'd be cool and try to desolder a switch cause it made a slightly different pingy noise (barely noticeable) and got carried away at how I kept failing and eventually burnt some of the pads. Called it quits and soldered it back just to find out that my whole keyboard was rendered useless... anyone know if a single switch could do that?
Basically when I plug the board back in, the top right light stays lit and the caps/top right key LEDs stay active. No keys get registered when typing.
Would appreciate it if anyone could give some insight (switch is the "B" key, next to the D71 and R85). Thanks!
Offline hkf
  • your #1 fan
« Reply #1358 on: Wed, 24 May 2017, 00:20:14 »
You will definitely need to jump some traces to get it fixed. I can see some broken traces near R85 just from the pics you provided. best ofluck
Offline -musubi
  • Spam rice 'n eggs
« Reply #1359 on: Wed, 24 May 2017, 00:24:39 »
Thanks for the suggestion, I will try that once I've given myself a bit of a break from my regret and frustration... do you think I should bother connecting up the led trace as well? I figured that one isn't as important since taking out the LED makes it open anyways. I thought the one above was for the resistors as well (also tied to the LEDs) but maybe it is important... definitely the top suspect for now though.
Offline merlin64
    • MechMerlin
« Reply #1360 on: Wed, 24 May 2017, 00:29:14 »
Oh No!! I'm sorry to hear that musubi! This is actually one of the reasons why I still haven't built my kit. I'm looking into holtites since I can't seem to get a metal switch plate just perfect.
Offline hkf
  • your #1 fan
« Reply #1361 on: Wed, 24 May 2017, 00:33:26 »
I think it may not matter, it depends on how it flows.
It's probably something crossing and shorting causing a few keys to get sent / locking your board up, but other than that I can't be of much help other than suggesting which solder sucker to use (https://www.amazon.com/Engineer-SS-02-Solder-Sucker/dp/B002MJMXD4/ref=s9u_wsim_gw_i1?_encoding=UTF8&fpl=fresh&pd_rd_i=B002MJMXD4&pd_rd_r=FRV550TVKXCNSAKYM4M1&pd_rd_w=2G3K8&pd_rd_wg=Jo9mm&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=JKNAM1N2SER3GNJKB5R3&pf_rd_t=36701&pf_rd_p=2a4fafb6-9fdc-425a-aee8-c82daa7b18ed&pf_rd_i=desktop)
Offline -musubi
  • Spam rice 'n eggs
« Reply #1362 on: Wed, 24 May 2017, 00:50:11 »
Haha don't make the same mistakes I made  :'( it was actually working fine it was just me and my bad desoldering skills (this was my 2nd session/attempt at the same key so I didn't have much room to work with anyways so I probably should've left it alone after the first time).
The funny thing is the first time I tried desoldering it I used a cheapo $5 one, and told myself I would buy one of these if I tried again. Ended up buying it and the 2nd time around I think the pads were already a bit too worn for at least an inexperienced desolderer like me and this happened... lol T___T Seriously though the LED pads are the hardest, still couldn't get out the switch in the end.
Offline zoomwalt
« Reply #1363 on: Wed, 24 May 2017, 01:10:31 »
These stories are why I have 4 unbuilt duck kits sitting in my closet.
Offline dubious
  • 쏘쿨
« Reply #1364 on: Wed, 24 May 2017, 12:04:32 »
what a shame :/
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #1365 on: Wed, 24 May 2017, 12:30:18 »
It's really not that difficult and if you're not feeling confident enough, why don't practice your soldering skills on a cheaper pcb?
Offline zoomwalt
« Reply #1366 on: Wed, 24 May 2017, 12:32:04 »
A lot of it is I've been really busy. I'll probably attempt one later this year.
Offline gaiden
« Reply #1367 on: Wed, 24 May 2017, 13:19:46 »
Oh man, I didn't know so many people are afraid they will mess up. I have put together about a dozen custom boards including Duck & TX boards, a couple Ergodox, fixed a few boards too. If anyone just need a board to put together I might be able to help. Thought I would throw this out there. I really want to see more assembled board pictures and not kits sitting in a box somewhere collecting dust.
« Reply #1368 on: Wed, 24 May 2017, 18:12:35 »
This. Many people would love to have the chance to even own one Duck keyboard and others, who were luckier getting their hands on one have them lying around unbuilt. Bit of a shame I think about it.
I'm sure that zoomwalt can do it and he should ask as many question as necessary; there are a lot of people lurking who are more than willing to help! You can do this!
Offline hkf
  • your #1 fan
« Reply #1369 on: Wed, 24 May 2017, 18:21:58 »
this
soldering is a joke with a temp controlled station
Offline -musubi
  • Spam rice 'n eggs
« Reply #1370 on: Thu, 25 May 2017, 02:39:02 »
Good news everyone! Got my baby to work again with some jumpers (rip traces and pads). Guess the trace running parallel with all of the LEDs is an important power rail or something (would've expected it to be parallel with each LED row and not so critical), but good thing they have those debug holes for easy troubleshooting. Also the switch pad was dead as well but that was more obvious.
« Reply #1371 on: Thu, 25 May 2017, 02:41:23 »
Glad to hear that it works! Would you mind showing a few more captures of the keyboard as a whole?
Offline -musubi
  • Spam rice 'n eggs
« Reply #1372 on: Thu, 25 May 2017, 02:47:30 »
Thanks! And sure, do you mean of just the pcb or of the actual board itself? It's not a new build or anything  :))
« Reply #1373 on: Thu, 25 May 2017, 04:06:22 »
The actual build itself. I don't think I've seen it before! :)
Offline hkf
  • your #1 fan
« Reply #1374 on: Thu, 25 May 2017, 17:07:44 »
Nice fix.
It's very odd that the power rail is not in series on the MCU. But that's on the designer...
Offline -musubi
  • Spam rice 'n eggs
« Reply #1375 on: Thu, 25 May 2017, 18:22:59 »
Nice fix.
Ye
Nice fix.
Yeah maybe it's just that rail that happens to share power with critical components since it's closer but who knows  :p
Ahh okay, here's a few pics of it:
Offline P1kas
  • AKA Crono
« Reply #1376 on: Sat, 27 May 2017, 20:10:07 »
Is that Sky Dolch + Ocean Dolch?
« Last Edit: Sat, 27 May 2017, 22:13:11 by P1kas »
Offline poolside
« Reply #1377 on: Sun, 28 May 2017, 02:54:24 »
Ocean Dolch has not shipped yet. The mods are from Hyperfuse.
Offline -musubi
  • Spam rice 'n eggs
« Reply #1378 on: Sun, 28 May 2017, 05:19:27 »
Yup that's correct, hyperfuse mods and sky dolch alphas. I believe ocean dolch would be the same color code though.
Offline merlin64
    • MechMerlin
Re: Octagon V2 75% Kustom Keyboard Group Buy (Closed for Orders)
« Reply #1379 on: Tue, 20 June 2017, 11:48:37 »
With much encouragement, and finally getting some time. I would like to announce that I am finally building my Octagon V2 this coming Saturday, June 24th, 2017.  :D
Offline gaiden
« Reply #1380 on: Tue, 20 June 2017, 11:56:23 »
Will there be a live stream?😀
Offline merlin64
    • MechMerlin
« Reply #1381 on: Tue, 20 June 2017, 12:09:35 »
The Seattle crew is doing a build party on someone's roof top. I don't think I'll be live streaming it, but that is a good idea. Maybe when I build my Duck Eagle..sometime around 2018 or so
Offline merlin64
    • MechMerlin
« Reply #1382 on: Thu, 22 June 2017, 09:32:44 »
For those of you curious....holtites (even the tin ones) fit super loosely on the Octagon V2. Looks like I'll be soldering them in.
Offline dubious
  • 쏘쿨
« Reply #1383 on: Thu, 22 June 2017, 13:55:30 »
when's this build party you speak of?  :)
Offline kawasaki161
« Reply #1384 on: Fri, 23 June 2017, 15:56:19 »
If the PCB is made to the same spec as the Blackbird one, don't add solder to the pads, they already come with a bit of solder on them, just get a soldering iron with a clean tip and press them in like that, works perfect.
Offline merlin64
    • MechMerlin
« Reply #1385 on: Fri, 23 June 2017, 16:05:04 »
It's tomorrow at 4! Are you in Seattle?
Offline merlin64
    • MechMerlin
« Reply #1386 on: Fri, 23 June 2017, 16:05:50 »
I got it working! Didn't have to use a soldering iron. Between the plate, and the PCB mount studs, everything is perfect. Guess what I'm typing on?
Offline kawasaki161
« Reply #1387 on: Fri, 23 June 2017, 17:24:43 »
Korean alu goodness?
Offline merlin64
    • MechMerlin
« Reply #1388 on: Fri, 23 June 2017, 18:33:19 »
Yah this is my first Kustom =). I've been using an eepw84 at work and before that a facew board. So this is very nice. It's my heaviest board so far.
Any of you know what those holes on the top right are for...and what the standard layout for this board is?
Offline kawasaki161
« Reply #1389 on: Sat, 24 June 2017, 04:03:01 »
The holes on the top right are for indicator LEDs. The first three are for Num, Caps and Scrollock, the others tell you which layer you are on.
Offline dubious
  • 쏘쿨
« Reply #1390 on: Sat, 24 June 2017, 17:14:26 »
Nope, not till next weekend. Looking forward to pics and a video hopefully!
Offline giangpn
« Reply #1391 on: Fri, 25 August 2017, 10:49:07 »
hey buddies!
So I'm super lucky that I just acquired an Octagon V2; however, I'm super curious about how the indicator LEDs (on the top right corner) works and what does it mean? I kinda see a few is Caps/Num/Scroll but what about the rest?
Also, is there a way to program the Underglow LEDs to be static? I'm trying to have Cyan underglow but it keeps on throbbing haha.
I see dead people.
Offline kawasaki161
« Reply #1392 on: Fri, 25 August 2017, 11:38:07 »
The other indicators show you which layer you are currently on.
To set the underglow to a static color you have to edit the colors in the keymap. Open your keymap, then select tools on the top, then select RGB color preset and then change all of them to the color you want.
Offline giangpn
« Reply #1393 on: Sat, 26 August 2017, 17:52:31 »
thanks buddy! do you know what is the exact name for RGB Color Preset in the keymapper? I saw RGB Mode, RGB Sel - and RGB Sel + but no matter how much I switch the RGB Mode, I can't find a static one.
I see dead people.
Offline kawasaki161
« Reply #1394 on: Sat, 26 August 2017, 17:59:19 »
Change to:
Then hit apply, then close, then save like you would save a keymap and then flash it  :thumb:
Offline giangpn
« Reply #1395 on: Sat, 26 August 2017, 18:11:23 »
Change to:
oooooh my, I'm feeling super dumb right now lol. Thanks a lot buddy!
I see dead people.
Offline gaiden
« Reply #1396 on: Sat, 26 August 2017, 20:20:30 »
Change to:
Kind of wish this software would get a facelift to something more intuitive and user friendly similar to the bootmapper.
Offline kawasaki161
« Reply #1397 on: Sun, 27 August 2017, 04:35:11 »
Change to:
The placement of the side menus is pretty bad, but I think the keymapping itself is a lot better than Bootmapper Client because it actually shows you the layout of the board and not just a grid with keys that don't make sense unless you hit the button to see what it corresponds to.
Offline gaiden
« Reply #1398 on: Sun, 27 August 2017, 07:09:32 »
Change to:
It's not all bad, but things like connecting to keymapping software and changing colors s super easy on other software. No holding the flip key and reconnect keyboard necessay. Again, only pointing it out because seen others like WKL and TAX boards work better in some aspects.
Offline giangpn
« Reply #1399 on: Mon, 18 September 2017, 15:51:24 »
hmmm, is there any "official" guide for setting this board up properly on the software side? Sometimes mine acts a little funky (it rarely chatter a random switch) and sometimes a see a little delay.
I see dead people.
