Author Topic: Outdated IT words or phrases  (Read 34035 times)
Offline Waateva
Re: Outdated IT words or phrases
« Reply #50 on: Thu, 14 January 2016, 17:22:46 »
We still have an intranet. 95% of our company calls it SharePoint, I like to call it hell.
We used tapes as well up until last year. It's still a viable cold storage option, and not a bad one at that. The backup software used to write to the tapes on the other hand....(LOOKING AT YOU BACKUPEXEC)
Oh god, and the massive robot we used to store, write to and eject our tapes was enormous. Now there is a huge space where it once was, and all our tapes got destroyed. Lol.
Like the machine that Vanessa Williams uses to steal the railgun files in the movie Eraser?
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #51 on: Thu, 14 January 2016, 17:27:20 »
I have not seen that movie.
But it was basically a self contained storage/robot/drive enclosure that sat at the end of our DC. Probably about 18ft long, 6ft wide and 10ft high. You could walk in there and there were these robot arms on rails, and tapes stacked in two sections about 12 tapes high. A lot of storage space, but most of it was empty by the time we decom'd it because we have moved everything to virtual. Finally.
Offline Pdub
« Reply #52 on: Thu, 14 January 2016, 20:52:00 »
"Intranet"
Do people not use this word anymore?  :confused:
Some companies do.
I don't think anyone uses HDD any more. It's all SSD now. Am I right? :)
Offline katushkin
  • Just the guy
« Reply #53 on: Thu, 14 January 2016, 20:54:35 »
"Intranet"
Some companies do.
Our main data domains are all HDD, but our blades are all SSDs.
Offline Pdub
« Reply #54 on: Thu, 14 January 2016, 20:55:27 »
"Intranet"
Some companies do.
What kind of blades?
Offline katushkin
  • Just the guy
« Reply #55 on: Thu, 14 January 2016, 21:10:27 »
"Intranet"
Some companies do.
Uhhhh, HP ProLiant Gen 7 stuff.
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #56 on: Thu, 14 January 2016, 22:01:32 »
Shared Drive
TGR Jane CE | TX-CP | ZZ96 | HHKB | Ducky Shine 3 | Atreus | Infinity Ergodox | IBM Model M | Smart Pad | Taobao Acrylic 96 | TGR910 SE | RGB96 | M4-A | Moon
Pending: Exent | EM7 | M-60 | Kira EXS | 910 Poly | Kn210 | Alice
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #57 on: Thu, 14 January 2016, 22:17:08 »
cyber
Offline katushkin
  • Just the guy
« Reply #58 on: Thu, 14 January 2016, 22:45:50 »
Offline atectatifern
« Reply #59 on: Thu, 14 January 2016, 23:06:44 »
instream data
EBCDIC
timesharing (but see "cloud")
terminal (but see "endpoint")
partitioned data set
COMMON block
baud rate
JOB card
finger
DD statement
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #60 on: Fri, 15 January 2016, 00:38:16 »
Shared Drive
Lol... Still use it XD
We just changed and now use sharepoint for additional security
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #61 on: Fri, 15 January 2016, 00:42:07 »
Okay. So what is the new word now? And why did it change? We still have local networks that host internal services for companies, no? What should I be calling this now?
LAN
Intranet is right. LAN is a much broader term. At least that his how I feel.
That is correct.
I will edit to make it more clear.  You can have several intranets in a LAN.  It's not the other way around.
« Last Edit: Fri, 15 January 2016, 00:48:48 by Snowdog993 »
Offline Jokrik
« Reply #62 on: Fri, 15 January 2016, 00:42:57 »
Bus cable
Offline jaffers
« Reply #63 on: Fri, 15 January 2016, 00:45:36 »
HDD
Windows
AMD CPU
Offline sean
  • Mechanical newb
« Reply #64 on: Fri, 15 January 2016, 00:47:56 »
HDD
Windows
AMD CPU
Those burn like a 220w tdp
Offline Krytone
  • ᕦ(ò_óˇ)ᕤ
    • Krap Shop
« Reply #65 on: Fri, 15 January 2016, 00:49:46 »
Cobol
Offline animal
« Reply #66 on: Fri, 15 January 2016, 00:54:41 »
Insert disk labeled "whatever" and press any key to continue...
And some funny ones
General failure reading drive c:
Who is general failure and why is he reading my disk?
Keyboard not connected press F1 to continue...
Real men do it with a keyboard.
Offline Snowdog993
« Reply #67 on: Fri, 15 January 2016, 00:54:55 »
ISA
EISA
VESA
RLL
MFM
Math Co-Processor (x87)
Offline animal
« Reply #68 on: Fri, 15 January 2016, 00:56:55 »
ISA
EISA
VESA
RLL
MFM
ESDI
ERROR 1701
SIMM (memory)
Offline Snowdog993
« Reply #69 on: Fri, 15 January 2016, 01:05:43 »
ISA
EISA
VESA
RLL
MFM
ESDI
ERROR 1701
SIMM (memory)
ERROR 1701!!!!!!  How could I forget that?
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #70 on: Fri, 15 January 2016, 01:13:22 »
AUTOEXEC.BAT
CONFIG.SYS
MEMMAKER.EXE
shareware
Offline Snowdog993
« Reply #71 on: Fri, 15 January 2016, 01:14:09 »
AUTOEXEC.BAT
CONFIG.SYS
MEMMAKER.EXE
shareware
QEMM
Offline sth
  • 2 girls 1 cuprubber
« Reply #72 on: Fri, 15 January 2016, 01:45:07 »
mouse balls
Offline hashbaz
  • Grand Ancient One
« Reply #73 on: Fri, 15 January 2016, 01:54:31 »
mouse balls
Cleaning the schmutz out of mouse ball rollers with a Rambo knife.
124363-0
« Last Edit: Fri, 15 January 2016, 01:56:54 by hashbaz »
Offline rm-rf
« Reply #74 on: Fri, 15 January 2016, 01:59:22 »
bulletin board system!
Offline Niomosy
« Reply #75 on: Fri, 15 January 2016, 02:21:37 »
tape backups
Audit came down hard for going strictly to virtual tape with no offsite backups.  The storage team had to put in new tape units to back up from the VTL disk pool and send the tape offsite.  I had to build a couple new servers to handle that as well as additional server backups.
« Reply #76 on: Fri, 15 January 2016, 04:22:52 »
"bureau system" - all the kids call it "cloud services" these days.
Offline Lurch
« Reply #77 on: Fri, 15 January 2016, 04:31:23 »
WINS
NT4
Citrix Metaframe
Quote from: Flyersfan1
Offline baldgye
  • Will Smith Disciple
« Reply #78 on: Fri, 15 January 2016, 04:36:30 »
winfs
Offline Lurch
« Reply #79 on: Fri, 15 January 2016, 04:38:24 »
SCSI/scuzzi drives
« Reply #80 on: Fri, 15 January 2016, 04:41:16 »
cyber
As in a IRC channel: "Hey girl, wanna cyber?" ...
I have not heard "BBS" in a long time, but people use "board" about boards such as this one ...
« Last Edit: Fri, 15 January 2016, 04:45:27 by Findecanor »
Offline baldgye
« Reply #81 on: Fri, 15 January 2016, 04:45:16 »
ASL
Offline Lurch
« Reply #82 on: Fri, 15 January 2016, 04:46:27 »
broadband
Offline keshley
    • Blog n stuff
« Reply #83 on: Fri, 15 January 2016, 07:09:09 »
cyber
This one bugs the hell out of me. It sounded lame 20 years ago, why is it a buzzword now?
I heard somebody say "memory chips" yesterday. Haven't heard that in a long time.
I half agree with Lurch on SCSI, except the last S in SAS stands for SCSI...
CPU (Not in reference to the processor, but to the computer itself)
Mainframe (A Hollywood staple)
PATA
MFM
FD
NDS
Nuke and Pave
8.3
Apple Talk
Token Ring
CMOS
Defrag
IPX
GUI (pretty much replaced with UI/UX)
Dot Matrix
CRT
VLB/EISA/ISA... etc
Color Graphics Array
Microprocessor
Zip (now we compress or archive, we don't 'zip' files)
IRQ (I hear interrupt or interrupt requests, but not the old school IRQ anymore)
Y2k
SIMM
Daughter board
Standalone (still a thing, but not called this anymore)
Terminator (for both thin/thicknet and old school SCSI)
Vax
Warm boot
Hard reset
I'm sure I could come up with more...
And can we please retire the term Cable Modem... they neither modulate nor demodulate.
HHKB Pro 2       Pok3r
  • Live long and prosper
« Reply #84 on: Fri, 15 January 2016, 07:31:20 »
Dot Matrix
I wish this was the case where I work... our day-to-day operations rely heavily on paper tickets printed on dot matrix printers.
tp thread is tp thread
Offline Nai_Calus
  • CLACK
« Reply #85 on: Fri, 15 January 2016, 07:51:12 »
IPX/SPX and Netware in general.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #86 on: Fri, 15 January 2016, 07:52:17 »
Good one, AppleTalk = worst network protocol NA.
« Reply #87 on: Fri, 15 January 2016, 08:02:41 »
We use BBS tags on this forum all the time.  :P
Offline digi
  • elite af tbh
« Reply #88 on: Fri, 15 January 2016, 08:04:26 »
« Reply #89 on: Fri, 15 January 2016, 08:08:36 »
wat did i do  :(
Offline digi
  • elite af tbh
« Reply #90 on: Fri, 15 January 2016, 08:10:10 »
wat did i do  :(
You mean BBCodes? BBS is bulletin board....can't take you anywhere...ugh.
« Reply #91 on: Fri, 15 January 2016, 08:11:07 »
wat did i do  :(
Yeah I meant BBCodes.  :-[  I'm the worst.  Are they not even related??
* HoffmanMyster leaves this thread  :(
Offline digi
  • elite af tbh
« Reply #92 on: Fri, 15 January 2016, 08:11:53 »
wat did i do  :(
Ok, now I feel bad...come back hoff. Give me your kishsaver and we'll be friends again.
« Reply #93 on: Fri, 15 January 2016, 08:13:44 »
Nuuuuu, I've been trying so hard to fit in but now I have revealed my poor IT knowledge!  There's no coming back from this shame.
Offline digi
  • elite af tbh
« Reply #94 on: Fri, 15 January 2016, 08:14:15 »
True..it will take time..
Offline keshley
    • Blog n stuff
« Reply #95 on: Fri, 15 January 2016, 08:25:30 »
wat did i do  :(
Silly Hoff.
BBS is kind of like what you'd call a forum today. Except you (typically) had to dial into them with a modem. They did a lot more than just forums though, could include chat rooms, multi-player games, etc.
Assuming they're related isn't a reach if you look at the acronyms. BBS: Bulletin Board System. BBCode: Bulletin Board Code. So if you've never used a BBS, it would be reasonable to think BBS is related to a modern forum.
They're still some BBSes around from what I understand. I was never big on them personally.
HHKB Pro 2       Pok3r
Offline digi
  • elite af tbh
« Reply #96 on: Fri, 15 January 2016, 08:26:18 »
wat did i do  :(
Silly Hoff.
KICK HIM WHILE HE'S DOWN!!
Offline davkol
  •  Post Editing Timeout
« Reply #97 on: Fri, 15 January 2016, 08:26:29 »
VESA
VESA is still used, but not in that context. It's a standards organization after all. For instance, we still have VESA mode on Linux systems, and people tend to call the VESA MIS standard for monitor mounts just "VESA".
Offline animal
« Reply #98 on: Fri, 15 January 2016, 11:35:27 »
Offline animal
« Reply #99 on: Fri, 15 January 2016, 12:13:10 »
Someone mentioned shareware, I liked public domain more. But the best shareware program ever developed was by far Terminate! In fact I used Terminate when I connected the first time to the internet
BBS? Yeah I had one, I even had a Fidonet node 2:410:30/thirthysomething! which reminds me:
ATZ
OK
ATX3
OK
ATT
OK
ATC2
AT&W
OK
Xmodem
Zmodem
v.32 v32bis and v.EVERYTHING (except for ZYX16800)
NS16650
Norton Commander was my best friend, along with the utilities
Norton Disk Doctor and editor
Norton Speeddisk (disk caching)
Another great program (shell actually)
4DOS
Qedit. It was a DOS editor which had no problem at all to open very extremely large text files
And for multitasking Quarterdeck's Deskview
I could go on and on... those were the days :)
