Author Topic: Korean keycaps set  (Read 7312 times)
Offline BLaZe
Korean keycaps set
« on: Sat, 16 January 2016, 11:54:52 »
 I was going to buy a Tai Hao Miami keycap set on MD, but I realised that the space bar wouldn't fit in my keyboard, also I'm lacking 2 other keys, the one for the hanja, and for the Hangul. I think it might be a bit weird to have a spacebar and 2 other keys which don't fit at all with the rest of the keys.
Here's the problem:
124540-0
124542-1
So, does anyone know where I can buy a korean keycap set that will fit my keyboard ?
Offline BLaZe
Re: Korean keycaps set
« Reply #1 on: Sun, 17 January 2016, 14:21:15 »
The 2 keys next to the spacebar have the same dimension as the other standard keys so it's not problem anymore, but I still can't find a spacebar  :( Any help ?
Offline ghostjuggernaut
« Reply #2 on: Sun, 17 January 2016, 14:27:08 »
I have not personally seen any aftermarket spacebars in that size.  That's not to say there aren't any though.
Worst case scenario is you keep the stock spacebar and use whichever keysets you want for the remainder.  Its not ideal, but it should work.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Sun, 17 January 2016, 14:27:39 »
Here you can find spacebars and the corresponding colour codes are right here.
Quote from: elton5354
Offline Steezus
  • Keeper of Facts
« Reply #4 on: Sun, 17 January 2016, 14:30:09 »
That looks smaller than a 6u spacebar which is the lowest that SP goes to.
« Reply #5 on: Sun, 17 January 2016, 14:31:05 »
Yep, his looks to be about 4.25x or close to.
Offline BLaZe
« Reply #6 on: Sun, 17 January 2016, 14:54:42 »
Thank you so much I can finally change this spacebar  ;D
Offline Wulfre
« Reply #7 on: Thu, 21 January 2016, 09:45:20 »
What keyboard is this? I would love to use those extra keys as macros and the little space bar looks oddly adorable.
Offline BLaZe
« Reply #8 on: Thu, 21 January 2016, 10:57:50 »
Offline vamdolly
« Reply #9 on: Wed, 27 July 2016, 04:25:49 »
Hi do you have a link to this cap set? as it fits my need  for a 4.25 spacebar.
Offline Adgar
    • Pheilcia
« Reply #10 on: Tue, 09 August 2016, 01:53:34 »
This one looks simple but really amazing ,I am really into it
