Author Topic: [GB] R2 PURPLE ZEALIO SWITCHES (Complete)  (Read 3162068 times)
Offline mcometa
Re: [GB] R2 PURPLE ZEALIO SWITCHES (New spring weight & options added)
« Reply #50 on: Sun, 17 January 2016, 22:56:16 »
Which one is to buy for the White Fox keyboard drop?
Offline eeymiel
« Reply #51 on: Mon, 18 January 2016, 03:41:20 »
What is the GB deadline? And is there a way to distinguish R2 pcb mounted 65G from R1 zealios (guess not, but who knows)?
Offline Zeal
    • Zeal Generation Inc.
« Reply #52 on: Mon, 18 January 2016, 03:47:19 »
All switches offered on my site will work with the WhiteFox keyboard drop.
Tentative GB deadline is Feb 27, but could end up closing earlier. I'll have a more solid deadline in a few weeks.
No, there's no way of distinguishing R2 PCB mounted 65gs from R1 unless you inspect the springs, etc.
Offline Brammm87
« Reply #53 on: Mon, 18 January 2016, 04:02:12 »
Do you have any idea how the 78g's compare to MX Greens?
pls gief bbv2
Offline Zeal
« Reply #54 on: Mon, 18 January 2016, 04:11:34 »
MX Greens bottom out at around 90g, so my 78g Zealios are still a bit lighter.
Offline Brammm87
« Reply #55 on: Mon, 18 January 2016, 04:16:54 »
Put in my order. Looking forward to it. I'm a heavy typer, so this'll be interesting. Now to determine what the hell I'm gonna build with it :p
pls gief bbv2
Offline amharris
« Reply #56 on: Mon, 18 January 2016, 07:25:20 »
I'll probably order some 67gs for my WhiteFox; though I would like to take a 'try before I buy' approach to the 78gs.
Regardless, I can't wait! :)
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #57 on: Mon, 18 January 2016, 07:27:55 »
Nice to see these are back, I used the R1 switches in a few different boards and I loved them, will definitely order more!
Offline mcometa
« Reply #58 on: Mon, 18 January 2016, 09:36:20 »
Thanks Zeal, will definitely order one. Another question, which LED is the buy for this one?
Offline Steezus
  • Keeper of Facts
« Reply #59 on: Mon, 18 January 2016, 11:12:17 »
1.8mm, 3mm flangless, or 2x3x4mm LEDs should all work. The last option tends to be the brightest but can have some interference with keycaps, they're still my favorite option.
Offline tkpresent
« Reply #60 on: Mon, 18 January 2016, 11:19:24 »
Is "65g - Transparent Top, Milky bottom" the only option for the plate mount, like Octagon v2?
- HHKB
- Varmilo VA68M
- Octagon V2
- TX 87
- ZZ96
- TX1800
Offline Steezus
  • Keeper of Facts
« Reply #61 on: Mon, 18 January 2016, 11:27:38 »
No, Octagon v2 uses a plate but allows PCB mounted switches.
Offline 64rky
« Reply #62 on: Mon, 18 January 2016, 12:13:44 »
wait, apart from this one, are all the other's PCB mount? I thought they were all plate mount? My last batch of 62g were plate mount... I'm confused.
Offline Dernubenfrieken
« Reply #63 on: Mon, 18 January 2016, 12:19:05 »
I'm glad this has a long period to order, because its gonna be impossible for me to decide what to get. Definitely getting some for my office numpad, and the 78's seem right up my alley for a 60% build... hmmmm.
Offline profet
« Reply #64 on: Mon, 18 January 2016, 12:40:03 »
I think everyone here is confusing Plate and PCB mount switches.
PCB mount switches have 2 extra plastic legs.
Plate mount are missing these legs.
You can convert a PCB mount switch to Plate mount by using a flush cutter and removing these legs.
You can put EITHER plate or PCB mount switches into a plate.
TLDR:  You should always get PCB mount switches and if you ever find a pcb that lacks the PCB holes... then use a flush cutter to remove the extra legs on the switch.
Bringing custom Ergodoxes to the masses.
My heatware: http://www.heatware.com/u/102649
Offline Steezus
  • Keeper of Facts
« Reply #65 on: Mon, 18 January 2016, 12:42:49 »
Beat me to the punch. :p
Profet is correct and provided clear info, thank you.
Offline 64rky
« Reply #66 on: Mon, 18 January 2016, 13:44:36 »
Ah ok, so they are the same as in R1... ok... I can feel comfortable with my order then :) As these are likely going on my Octagon V2
Offline tkpresent
« Reply #67 on: Mon, 18 January 2016, 14:38:46 »
Now it's very clear.
- HHKB
- Varmilo VA68M
- Octagon V2
- TX 87
- ZZ96
- TX1800
Offline roostrc0gburn
  • its just plastic
« Reply #68 on: Mon, 18 January 2016, 15:24:53 »
Production time + shipping will take roughly 2 weeks. Reshipping bulk order from Zeal PC to you will take roughly 3 weeks.
So lead-time is 5 weeks once pre-order is closed? potentially meaning that these switches may not be delivered until April?
Offline Zeal
« Reply #69 on: Mon, 18 January 2016, 15:58:33 »
It's just a rough estimate. I'll of course try to get everything out by March.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #70 on: Mon, 18 January 2016, 16:45:18 »
I need some of these. The 78g's are a bit lighter than the MX Clears that I usually prefer but it could be very nice for a 60% build I have in mind.
I'm guessing these would feel like regular MX Clears with Clear springs?
|||My other keyboards :
x
Offline Zeal
« Reply #71 on: Mon, 18 January 2016, 16:58:24 »
If you put MX Clear springs inside, yes, it would become a smoother MX Clear. 78gs are a "softer" MX Clear variant.
Offline FlofromProgresso
« Reply #72 on: Mon, 18 January 2016, 21:53:11 »
Will there be a sampler pack with the 4 switch weights?
Offline tofgerl
« Reply #73 on: Tue, 19 January 2016, 08:24:59 »
Could you not add that to the order form now? I'm going to get some more 67s, since that's what I ordered before and I don't change horses mid-stream, but those other horses might be faster and I'll never know!
« Reply #74 on: Tue, 19 January 2016, 09:01:34 »
Will GB R3 be around April - June? I know its early to ask but I am planning on getting some purple zealios but would like to get the sample pack first to test out the feel of them to make sure that i get the right one and to give my wallet some time fill back up. Also thank you for making these switches they look fantastic.
Offline aaron6301
  • Pixel Pusher
« Reply #75 on: Tue, 19 January 2016, 10:50:49 »
Anyone know what Zeal switch weight would be comparable to an Ergo Clear with 62g Gold Springs and lubed with Krytox 205/103?
Offline Steezus
  • Keeper of Facts
« Reply #76 on: Tue, 19 January 2016, 10:53:36 »
Just read the reviews of what other users have to say about Zealio switches if you're having trouble making a decision.
Offline Zeal
« Reply #77 on: Tue, 19 January 2016, 11:32:26 »
Depends on how worn and how you lube your 62g ergo clears. Due to the smoothness of Zealios, you might have to bump up the weight to get roughly the same "feel". I'd say 65g would be the equivalent of 62g ergo clears, while being slightly more tactile due to leaf design in Gaterons.
Offline 64rky
« Reply #78 on: Tue, 19 January 2016, 13:45:58 »
So I have the 62g purple from R1.  I love these for typing large amounts,  but for gaming I want something heavier... I want to get an idea on the 78g feel?  What would one compare this to? I like MX clears,  and vintage black for gaming.
Thanks in advance.
Offline Zeal
« Reply #79 on: Tue, 19 January 2016, 13:50:15 »
Thanks in advance.
78gs would be a softer MX Clear in weight, almost the same as vintage black weight.
Offline 64rky
« Reply #80 on: Tue, 19 January 2016, 14:08:52 »
Thanks in advance.
So kind of like tactical Gateron black?  If so,  this might be my choice!
Offline Waateva
« Reply #81 on: Tue, 19 January 2016, 15:18:12 »
Thanks in advance.
hehe tactical
Offline tofgerl
« Reply #82 on: Tue, 19 January 2016, 16:23:20 »
Tactleneck.
Offline 64rky
« Reply #83 on: Tue, 19 January 2016, 18:27:53 »
Thanks in advance.
hehe tactical
haha... only just noticed my mistake, what I meant to say if MX black were tactile, this would be the comparison :)
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #84 on: Tue, 19 January 2016, 20:35:04 »
Does the 78g bump feel any diff from the 67g or is it pretty much the same but a heavier switch?
Offline Steezus
  • Keeper of Facts
« Reply #85 on: Tue, 19 January 2016, 20:40:28 »
The "bump" is due to the stem, the 78g spring will just make it heavier.
Offline Zeal
« Reply #86 on: Tue, 19 January 2016, 20:50:46 »
Feels like a heavier 67g with cushiony bottom out.
« Last Edit: Tue, 19 January 2016, 23:17:18 by Zeal »
  • sleever supreme
  • greyhat co-leader
« Reply #87 on: Tue, 19 January 2016, 22:00:33 »
Yeah I understand that, was wondering if it was like 62g vs 67g. Same slider but the bump in the 67g felt more tactile.
Could just be me tho :p
Feels like a heavier 78g with cushiony bottom out.
Alright thanks :)
Offline Zeal
« Reply #88 on: Tue, 19 January 2016, 23:17:03 »
Alright thanks :)
Woops, typo fixed.
Offline Goranth
« Reply #89 on: Wed, 20 January 2016, 00:30:03 »
I keep going to checkout but then have second thoughts over 65g or 67g -.-
At least I have some time to think about it.
Offline tofgerl
« Reply #90 on: Wed, 20 January 2016, 07:17:55 »
This is something I've wondered about... Would it be possible to cushion the bottoming out further by using two springs? Say a normal 65g spring, but about 2/3rd the length (though with the same weight) and then a really heavy spring (150g?) for the last 1/3rd length?
That way you would get what I imagine to be a really cool effect...
Offline duckness
« Reply #91 on: Wed, 20 January 2016, 07:58:46 »
I don't think that's how springs work though, won't the amount of force required be similar to if not the same as a 65+150=215g spring?
Offline UTEster750
« Reply #92 on: Wed, 20 January 2016, 07:59:59 »
It's a cool idea but I would be worried as to how hard it would be to create.  :eek:
Offline tofgerl
« Reply #93 on: Wed, 20 January 2016, 08:00:22 »
Quite possibly. I have no idea about these things, I just type.
Offline Zeal
« Reply #94 on: Wed, 20 January 2016, 14:32:34 »
2 custom made springs would theoretically be possible, but you're constrained by the limited space in the switch. For example: a heavier spring that has a reduced height would need to have thicker wires coiled to compensate the loss in compression (wider coils generally result in heavier springs). Once you overcome that issue, there's also the chance that the top spring will move around too much and could dislocate/deform over time.
Offline breitling
« Reply #95 on: Wed, 20 January 2016, 15:11:14 »
67g Zealios ordered! Love my 62g ones from the first buy and would like to experiment with something a bit heavier.
Offline tofgerl
« Reply #96 on: Thu, 21 January 2016, 01:35:16 »
I guess we'll have to wait till Jack and Adam figures out the electromagnetic switches they invented on their podcast :)
Offline lawlz_xD
« Reply #97 on: Thu, 21 January 2016, 02:52:20 »
I apologize for my ignorance but unless we specified otherwise when ordering, are we to assume that the switches we receive will be plate-mounted?
Offline henz
  • What?
« Reply #98 on: Thu, 21 January 2016, 02:56:37 »
For how long will this be offered? I need to get some cash :D
Offline tofgerl
« Reply #99 on: Thu, 21 January 2016, 03:23:14 »
No, I think PCB-mounted. At least the last batch were, and since the plate-mounted in this round are specified to be plate-mounted, I would assume the default still to be PCB mounted.
By the way, why don't we say mountable? They don't come pre-mounted after all... [8]
