Author Topic: Filco cherry black v. brown for gaming  (Read 6762 times)
Offline mljs54
  • Team Topre
« on: Tue, 24 November 2009, 20:23:13 »
Hi there ---
First time poster:
Looking into picking up a Filco mechanical keyboard.  Question: which is better for gaming: black or brown cherry switches?  I tend to hit my keys pretty forcefully so will that have anything to do with my decision?
Thanks much in advance
ReΛlforce 87UB EK
Offline AndrewZorn
« Reply #1 on: Tue, 24 November 2009, 20:30:52 »
brown - very light / easy to press, with a subtle bump when the switch actuates
black - very heavy / difficult to press (with no bump)
these switches are nearly polar opposites
(never used cherry black myself)
Offline savage
« Reply #2 on: Tue, 24 November 2009, 20:41:50 »
I find the browns not optimal for gaming. I prefer my Unicomp, but suspect the blacks to be even better.
Offline mljs54
  • Team Topre
« Reply #3 on: Tue, 24 November 2009, 21:47:59 »
Quote from: ripster;136106
Welcome to Geekhack!
Check the "Mechanical Keyboards Sorted By Switch" wiki entry (home page).  At the bottom are several links to threads with this same question.  Take a look at them and post back.
Short Answer:  Pros use Blacks.  Everybody else often get by fine with their favorite typing switch.
Thanks much for this -- after reading a few posts it sounds like the Cherry Blacks are what I want.  I have a very heavy hand and keystroke and one thing I notice right now is that I tend to really bottom out my keys.  Also, if I accidentally hit the wrong key and pull back up I'm usually too far into depressing it and it registers on screen (hope that description made sense).  Does this sound like something the Blacks are meant to prevent?
ReΛlforce 87UB EK
Offline AndrewZorn
« Reply #4 on: Tue, 24 November 2009, 21:58:31 »
actually, the cherry switches in general should only make that happen more.  since you dont have to bottom it out, like a rubber dome, the key will register earlier, mid-stroke.
Offline imsto
    • imsto.cn
« Reply #5 on: Wed, 25 November 2009, 06:11:54 »
games    black 's the best choice i think
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline hyperlinked
« Reply #6 on: Wed, 25 November 2009, 08:53:08 »
Although the conventional wisdom is that heavier linear switches tend to be better for a lot of games, if you're playing FPS games, you may want to give light switches like the Cherry Browns a try. It might be easier on you hands in the long run. My left hand is a little worn out from too much work and too much Unreal Tournament. These days, I can only play on a light switched board and even then only in moderation.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline mljs54
  • Team Topre
« Reply #7 on: Wed, 25 November 2009, 17:25:30 »
Yea I'm getting confused as well.  I wish elitekeyboards had a 30 day satisfaction policy.  I definitely want a Filco for gaming but it's annoying that you could spend $140 and not get what you want since you can't really go and try these in a store somewhere if you've never used any of the switches before.  I'm almost leaning towards a Deck now since they have that kind of return policy.
As a side note, I use a IBM M at work that I had our IT guy dig out of the supply closet and that would be waaay overkill for gaming comfort for me.
ReΛlforce 87UB EK
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #8 on: Wed, 25 November 2009, 17:26:40 »
I thought people liked tanks in games.
