Author Topic: RAMA CNC Aluminium Keycap - SHIPPED!  (Read 128520 times)
Offline eyedrop
Re: RAMA CNC Aluminium Keycap - SHIPPED!
« Reply #250 on: Tue, 07 June 2016, 00:01:16 »
Thanks to Den411, I was pleasantly surprised when I receive the package today.
It even includes the limited edition Zealio bubblewrap.   :thumb:
The attention to detail is simply amazing.
KingRama, what other components would I need to actually assemble this?
Love this.  Too bad I didn't get that orange acrylic one.
Switches for the 4% board?  Surprise!
Thanks, Den411 and KingRama.  Now I am a fan!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #251 on: Tue, 07 June 2016, 15:08:56 »
Woah, whats that plate? I've never seen one before.
All the components are listed on the PCB: diodes, resistors, tiny85 and a tiny85 programmer.
http://rama.works/#/r042b/
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #252 on: Tue, 07 June 2016, 22:28:13 »
WOW! Awesome, thanks heaps for the photos man!! Do you mind if I repost them on my Facebook: https://www.facebook.com/ramaworks
Awesome it came with some Zeals! :D
The BoM is as follows:
4x 10k resistors
2x diodes
1x tiny85
2x 68 ohm resistors
1x 1k5 resistor
NOTE/PROTIP: Make sure you program the ATTINY85 before soldering it on! You can pick up tiny programmers off eBay for like $2 :)
Plate? :o
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
« Reply #253 on: Tue, 07 June 2016, 23:16:05 »
Plate? :o
The etched square thingy  :p
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #254 on: Tue, 07 June 2016, 23:23:42 »
Plate? :o
Ohhh, the Certificate of Authenticity!
That only came with the colored limited editions  :( :blank:
INSTA: @ramaworks
FB: ramaworks
Offline eyedrop
« Reply #255 on: Tue, 07 June 2016, 23:39:15 »
Rama, sure, feel free to use the pic to promote on Facebook.
I think I found all the components online.  Just a small question regarding the diodes.  Which type do I need?
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #256 on: Tue, 07 June 2016, 23:48:59 »
Great thanks heaps eyedrop! :)
Awesome! Have a look at "Zener Diodes" - Hope this helps  :D
INSTA: @ramaworks
FB: ramaworks
Offline Waateva
« Reply #257 on: Fri, 24 June 2016, 12:41:08 »
SKIDATA+ has arrived and I ordered the orange Wave cap for it, so here is a picture!  I love how it looks with the set and the color matches really well, so great work as usual Rama :)
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #258 on: Sat, 25 June 2016, 08:51:17 »
Oh dayyuumm Waateva! That looks great man! Thanks for the photo :) Definitely a cool combo for sure. Gonna repost this on my Facebook page later :D
INSTA: @ramaworks
FB: ramaworks
Offline misconceit
« Reply #259 on: Tue, 05 July 2016, 07:02:58 »
Rama, for the HHKB case posted on Instagram please add cut out on left shirt and return for Novatouch stems :(
HHKB Pro 2 Type-S
HHKB Pro 2
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #260 on: Tue, 05 July 2016, 18:53:36 »
Hey mate, are the novatouch stems different to the HHKB stems? I was under the impression that they are the same :o
INSTA: @ramaworks
FB: ramaworks
Offline osxoep
« Reply #261 on: Wed, 06 July 2016, 10:32:10 »
The novatouch stems let you use MX style key caps.
HHKB Pro JP with hasu's controller (waiting for MX sliders)
« Reply #262 on: Wed, 06 July 2016, 10:46:14 »
I think he means the same length, diameter, etc.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #263 on: Wed, 06 July 2016, 18:20:45 »
Ahh yes, I should have been more succinct, that is what I meant, thanks Romevi! :)
If they are the same dimension-ally compared to an OEM Topre stem, they should be interchangeable :) I believe that they are since you can swap them out with existing Topre keyboards!
INSTA: @ramaworks
FB: ramaworks
Offline misconceit
« Reply #264 on: Thu, 07 July 2016, 18:24:27 »
What I meant was the holes for the MX keys to go through just like a Novatouch, the pictures on instagram doesn't seems to have them
Only needed on the big modifiers: Return and Left Shift
« Last Edit: Thu, 07 July 2016, 18:28:29 by misconceit »
HHKB Pro 2 Type-S
HHKB Pro 2
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #265 on: Thu, 07 July 2016, 18:40:28 »
Ohhh okay I see, for the stabilisers? I'll look into it man! Cheers
INSTA: @ramaworks
FB: ramaworks
« Reply #266 on: Thu, 07 July 2016, 19:45:55 »
WHAT UP KING?
I SEE YOU GOT SOME DOPE **** COMING UP.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #267 on: Thu, 07 July 2016, 19:49:01 »
WHAT UP KING?
DEMIK, bruh, so much to even explain RN.
One I'm currently most excited about is this:
I keep forgetting how damn tiny this board is, for something that looks so huge D:
MOAR: http://rama.works/#/m36a/
INSTA: @ramaworks
FB: ramaworks
« Reply #268 on: Thu, 07 July 2016, 20:10:19 »
yo i saw that.
i dont even know what it is but lawd do i want like 3 of them.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #269 on: Thu, 07 July 2016, 20:57:04 »
yo i saw that.
You gonna have to rob Qaz for it :P
INSTA: @ramaworks
FB: ramaworks
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #270 on: Mon, 05 September 2016, 15:21:46 »
still loving this cap. :)
Offline xondat
  • i'm not a star
« Reply #271 on: Mon, 05 September 2016, 15:23:44 »
That color is truly amazing, pls.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #272 on: Mon, 05 September 2016, 18:30:04 »
 :o :o :o  I really do love how that color came out, thanks for the photo bro!
INSTA: @ramaworks
FB: ramaworks
