Author Topic: Where can I get Topre switches to build my own keyboard?  (Read 5515 times)
Offline burli
    • My Neo 2 Blog
« on: Tue, 19 January 2016, 03:32:02 »
Hi, is it possible to get single Topre switches to build own keyboards? If yes, where can I get them?
I love the Neo 2 Layout and splitted matrix keyboards. Never want to go back
Offline sth
  • 2 girls 1 cuprubber
Re: Where can I get Topre switches to build my own keyboard?
« Reply #1 on: Tue, 19 January 2016, 03:33:17 »
this is unfortunately not possible because topre switches are not discrete units.
Offline VinnyCordeiro
« Reply #2 on: Tue, 19 January 2016, 06:23:37 »
There is another problem: a Topre switch is basically a variable capacitor. Making a long story short: you have to use a PCB for it to work.
There is a thread on Deskthority where a guy is building a custom Topre keyboard, if you are interested: https://deskthority.net/workshop-f7/designing-a-custom-topre-board-t11734.html
Offline burli
    • My Neo 2 Blog
« Reply #3 on: Tue, 19 January 2016, 07:24:53 »
Well, I know that the PCB is part of the switch. But it should be possible to get the components and the know how to build Topre keyboards
Offline joey
« Reply #4 on: Tue, 19 January 2016, 07:29:03 »
You currently have to buy Topre boards and disassemble them.
« Reply #5 on: Tue, 19 January 2016, 08:02:42 »
Pfu already made the only keyboard you need.
Hhkb
Offline burli
    • My Neo 2 Blog
« Reply #6 on: Tue, 19 January 2016, 08:15:07 »
Hhkb
If you read my signature or my threads you can see that HHKB is not the keybord I want
« Reply #7 on: Tue, 19 January 2016, 08:30:42 »
Hhkb
Oh, ****. He insulted demik's HHKB.
Offline burli
    • My Neo 2 Blog
« Reply #8 on: Tue, 19 January 2016, 15:48:18 »
Hhkb
Did I? Oh. Well, I could say, I don't want a staggered, unsplitted keyboard at all. Is that better?  ;D
