Author Topic: Mitsumi repair  (Read 1905 times)
Offline Rob2D
  • Alright lads
Mitsumi repair
« on: Sun, 24 January 2016, 08:13:04 »
Hello all!
So I recently pulled an old Mitsumi keyboard out of an ancient crate of scrap/rubbish/****e at work and set about cleaning it up.
Thing is, on the circuit sheet/membrane? I noticed that one of the traces is missing where it terminates. Will this leave me with a dead key somewhere and is there any way to repair it?
Shiny
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Mitsumi repair
« Reply #1 on: Sun, 24 January 2016, 08:23:02 »
You probably wouldn't be able to repair it since it's a membrane sheet. You could try silver ink but there's no guarantee it would work. Unless you just really like Mitsumi, it seems like a lot of work for a membrane keyboard that you can easily replace with a modern membrane board.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Mitsumi repair
« Reply #2 on: Sun, 24 January 2016, 08:45:11 »
Personally, my advice is to not bother. Mitsumi hybrid isn't that great, and that particular model of keyboard is very common, it's easy to find another one for nothing. Check around offices, they have them everywhere.
Offline Rob2D
  • Alright lads
Re: Mitsumi repair
« Reply #3 on: Sun, 24 January 2016, 10:13:28 »
Ha, yeah I figured as much.
Oh well, I was just bored that day and thought I'd take something apart ;D
Shiny
