Author Topic: IBM 8923 & 7953 Model Names?  (Read 1940 times)
Offline Carthik
« on: Sun, 24 January 2016, 10:17:20 »
Does anyone know the model names of the 8923 and 7953 IBM keyboards? For example, I know IBM has a "Active Response" and a "Rapid Response" etc.
Cheers,
Carthik
Re: IBM 8923 & 7953 Model Names?
« Reply #1 on: Sun, 24 January 2016, 10:21:28 »
Most people in this forum consider rubber dome keyboards to be irrelevant. That said, those are 2 of the best ones.
- D Trump 2026-10-24
Offline Carthik
« Reply #2 on: Sun, 24 January 2016, 11:30:13 »
The contribution this post has had on this thread is...?
Offline neverused
« Reply #3 on: Sun, 24 January 2016, 15:10:10 »
Given that he is something of a subject matter expert, it should probably indicate that you may not find much info. Also, he did qualify the statements to explain that those models are better than the average rubber dome.
