Author Topic: [GB] F104+SSK+122+62+77+50+Ergo orders now open! Kishsaver+Industrial Model F  (Read 3464390 times)
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
Re: [GB] F104+SSK+122+62+77+50+Ergo orders now open! Kishsaver+Industrial Model F
« Reply #3500 on: Sun, 07 September 2025, 13:28:04 »
Bluetooth wireless Model F update:
Is anyone interested in making their Model F wireless?
I recently saw a post on this, for the Model M:  https://deskthority.net/viewtopic.php?t=29368
Maybe it can be an update or add-on PCB to Rico's Leyden Jar controller or the xwhatsit controller, or a new controller entirely (less convenient as it would require everyone to desolder their current controller).
The Leyden Jar RP2040-based controller does accept power and signal on its header extension, so something like the Supermini NRF52840 used for the above project may be able to work with a battery.  Ideally, if a PCB is needed it could be designed to be manufacturable by JLCPCB.  If it is powered off the header extension, it might also be helpful to have an extension header on the add-on PCB for a solenoid driver and solenoid (though the battery won't last as long).  The Leyden Jar currently allows one controller to communicate with and power another:  https://github.com/mymakercorner/Leyden_Jar
There are other projects not specific to the Model F that may work but are currently not tested with the Model F:
https://handheldsci.com/kb/
https://sterling-key.com/
https://www.wscome.com/product/wired-keyboard-converted-to-wireless-keyboard-diy-kit/
https://www.wscome.com/product/convert-a-wired-keyboard-to-wireless-keyboard-wbt-v2-wbt2-v4/
https://git.kkozai.com/kenji/pico_ble_hid/
https://www.reddit.com/r/MechanicalKeyboards/comments/1d7c5dc/sterlingkey_a_bluetooth_adapter_to_turn_your/
https://www.reddit.com/r/olkb/comments/sby7k6/diy_bluetooth_qmk_microcontroller/
My guess is that the Model F would require a much larger battery to be able to run for several weeks (15000mah?).  Maybe one of those Lithium iron phosphate batteries of that size could be used.
Offline callllll
« Reply #3501 on: Tue, 16 September 2025, 16:31:56 »
Hey all! Recieved my model F122, it's wonderful. Super well built and it looks stunning.
I do have one small issue - compared to either of my model M's, the keys are a bit scratchy, and even the 1U keys can be inconsistent/bind slightly with off-center key presses. I did not find any information in the manual regarding this behavior. I believe this is caused by the keycaps, as I do not have this issue if I install an original Model M key.
Any advice would be appreciated!
Offline Ellipse
« Reply #3502 on: Tue, 16 September 2025, 17:05:07 »
No, I would not characterize Model F keys as scratchier than Model M keys.  Your old keyboard is probably decades old and may be quite smooth after so much usage.
Offline callllll
« Reply #3503 on: Tue, 16 September 2025, 17:28:20 »
That makes sense. Primary concern is binding with off-center presses. It isn't major, and I'll see if that resolves with continued use!
Offline Ellipse
« Reply #3504 on: Mon, 22 September 2025, 20:35:43 »
For those who have received and started using the new F122 keyboards:
Please email me with feedback on how things are going.  As always, make sure you're running the latest firmware (I think 5/19/25 is the latest?) which fixes potential issues with key ghosting, etc.
Is the F122's RP2040-based Leyden Jar controller better able to handle KVM switches, USB hubs, USB extension cables, etc.?  I recall that these caused issues for some xwhatsit controller-powered keyboards.
Offline Ellipse
« Reply #3505 on: Wed, 24 September 2025, 12:10:42 »
Here's a nice article on the 40th anniversary of the Model M keyboard this year:  https://www.pcgamer.com/hardware/gaming-keyboards/the-keyboard-that-all-other-keyboards-copied-turns-40-this-year-heres-how-the-ibm-model-ms-legacy-lives-on-today/
And here is the latest update from someone who got Bluetooth working with their new Model F keyboard, which uses Rico's RP2040-based Leyden Jar controller:
"I was able to get this https://www.amazon.com/Ruitutedianzi-Bluetooth-Converter-Keyboard-Wireless/dp/B0DP6WTZY4/ Bluetooth adapter to work on this Leyden Jar board, whereas my xwhatsit based restored IBM F122 does not register any keypresses with it. The Handheld Scientific BT-500 does not work with either controller, but does at least register double keypresses with the Leyden Jar. I don’t have their updated BT-600 to test with.  According to my in-line USB meter, the BT adapter and keyboard idles at 26mA (with all LEDs on, each consuming ~1mA). With the solenoid at factory settings, I’ve seen it peak at 189mA – but the ~1s sampling rate makes this a very rough estimate.
Using an average 2000mAh 18650 Li-ion cell, I would guess we’d get ~76 hours (or as little as 10 with the solenoid and constant firing)."  In other words, one month of battery life with a 20000mah battery.
« Last Edit: Wed, 24 September 2025, 19:56:56 by Ellipse »
Offline Ellipse
« Reply #3506 on: Fri, 26 September 2025, 22:53:13 »
Now that the backlog of F122's is done and we are just waiting on boards with orders in August and Everything After (!) (as well as the Round 2 beam spring boards), I will be proceeding with the pad printed Model F PBT keycap project.  Due to poor quality I had to switch factories.  Below is the new factory sample.  This company is one of the largest keyboard manufacturers in the world.
Based on feedback with a focus on durability instead of authenticity to original standards, these keycaps will be using the highest quality abrasion-resistant inks offered by a major manufacturer, as well as a protective coating on top of each legend, with a slight margin of safety.  The original IBM M13 boards were known to wear more quickly as they had no protective coating.  While this reduces originality it should greatly increase durability.
Please disregard the lack of alignment for these test prints; the production keys will have normal alignment.
314680-0
Below is a photo from the first batch of combined Apple/Mac Text and Icon keys, which are now in stock and available to order.
314682-1
Apologies that both photos are slightly out of focus for parts of the image.
As always please sign the following interest forms if interested and if you have not done so already:
Pad Printed keys interest form:  https://forms.gle/Md7p5oA8zySy6pkG7
2025 Model F Project Interest Form for new designs:  https://forms.gle/c9cSCCmsDhZk4ZDR6
ISO Black, Industrial SSK Blue, Dark Gray Key Sets, Big Enter Keys, Code Keys Interest Form:  https://forms.gle/cDDypmZii6ihxgDY8
And with permission I am sharing a nice image of the Quebec CSA key set:
314684-2
Offline ploxiln
    • GitHub profile
MK
« Reply #3507 on: Tue, 30 September 2025, 00:16:25 »
Hi @ellipse ... I'm new to these forums, but I ordered an F77 way back in 2017 (received in 2019). Anyway, to my professional-software-developer sensibilities, the firmware situation has always been a bit of a mess. Don't get me wrong, what you've accomplished with finding overseas manufacturers, communicating with them, quality control, etc, is truly amazing and far beyond my abilities. But, software, firmware ... I have some notes I really hope you consider.
First, the QMK-layout-files.zip you currently host is nested (surely that's not intended):
Code: [Select]
$ unzip -Z QMK-layout-files.zip
Archive:  QMK-layout-files.zip
Zip file size: 21286345 bytes, number of entries: 1
-rw-a--     6.3 fat 21560059 bx defN 25-May-20 21:56 QMK-layout-files.zip
1 file, 21560059 bytes uncompressed, 21286171 bytes compressed:  1.3%
$ mkdir tmp
$ unzip QMK-layout-files.zip -d tmp/
  inflating: tmp/QMK-layout-files.zip
$ unzip -Z tmp/QMK-layout-files.zip
Archive:  tmp/QMK-layout-files.zip
Zip file size: 21560059 bytes, number of entries: 767
-rwxa--     2.0 fat     1801 t- defN 24-Feb-12 17:12 QMK-layout-files/b104 r1 ansi.bat
-rwxa--     2.0 fat     1808 t- defN 24-Feb-12 17:12 QMK-layout-files/b62 ansi HHKB 2U Backspace.bat
-rwxa--     2.0 fat     1805 t- defN 24-Feb-12 17:12 QMK-layout-files/b62 ansi HHKB Split Backspace.bat
-rwxa--     2.0 fat     1801 t- defN 24-Feb-12 17:12 QMK-layout-files/bssk r1 ansi.bat
-rwxa--     2.0 fat     1804 t- defN 24-Feb-12 17:12 QMK-layout-files/bssk r2 ansi.bat
-rwxa--     2.0 fat     1803 t- defN 24-Feb-12 17:12 QMK-layout-files/bssk r2 iso.bat
-rw-a--     2.0 fat     4929 t- defN 23-Nov-07 05:00 QMK-layout-files/build.sh
-rwxa--     2.0 fat     1804 t- defN 24-Feb-12 17:12 QMK-layout-files/f104 r1 non-shrunk ansi.bat
... lots of files ...
767 files, 38218027 bytes uncompressed, 21387443 bytes compressed:  44.0%
Instead of always updating /wp-content/uploads/2020/07/QMK-layout-files.zip it really would be better to give each version a different dated name, and have a directory with all dated archives ever released available. This is very rare for commercial software, but very common for well-run open-source software projects. It just makes things less confusing for anyone trying to come in and figure out what's really changed, or confirm whether something used to work, etc.
On that note, you really should have separate manual pages for the firmware stuff (and other sections too). Having a huge rambling firmware section that covers different controllers and different firmware lines and different OSes, in the middle of a truly gigantic single-page manual, with misc links sprinkled throughout, is really not great. The manual is quite verbose, but pretty good, after the first part which spends 12+ paragraphs saying you really need to read the whole damn manual, and up until the firmware section, which is truly a mess. (BTW you've got some older instructions for the pandrew utility in Action step 7, bullet 7. Ideally that would just link to a common up-to-date page about the utility.)
More importantly, you should host mirrors of all the source code yourself (or on your own GitHub account, or GitLab, or SourceHut, or Codeberg, or anywhere reliable). This is quite evident since pandrew's git host has been down for a couple months. But even back in 2019 this bothered me (along with the web QMK configurator hosted at some ip address, presumably by some other third party). I think you mentioned back in 2019 that you merged pandrew's wip branch with later QMK and made some more builds and updated the "one zip file" ... you really should have your own git repo and branches to support the keyboards you sell (with tags for every build you ever released, ideally).
Continuing with @NathanA's nice Vial port/fork/whatever ... which is distributed as an archive (7z is fine), and by following the gist to build pandrew-util for linux (linked in the middle of the firmware section of the manual), I figured out that build.sh constructs a source tree by checking out an old commit from vial-qmk and then applying a bunch of patches. This is what git is actually for! By the way, that build.sh is broken, and thus the gist instructions for compiling the linux pandrew-util are broken, because http://purdea.ro/qmk_firmware is offline. Luckily I do have all needed commits/branches from pandrew's git host, due to customizing my layout in QMK source back in 2019/2020. Anyway... I suggest using git hosting and git branches, and link to reliable git mirrors from a dedicated firmware page on modelfkeyboards.com ... so my mild OCD doesn't turn me into the crazy guy in front of a corkboard unraveling the tangled web of where all the builds and patches are  ;)
FWIW I've mirrored pandrew's branches here: https://github.com/ploxiln/qmk_firmware
and I've constructed nicer branch of commits version of NathanA's `build.sh` here: https://github.com/ploxiln/vial-qmk
(enough to build pandrew-util with all proper sources, but not quite including the actual final Vial layouts build part, maybe a TODO)
@NathanA while working on that I noticed the old upstream Vial CI found VIAL_KEYBOARD_UID re-used across f104_round_1_nonshrunk and f104_round_1_shrunk, I'm not sure how much that really matters for these 2 boards, or if it's tricky to fix now that some people already flashed these? But here was my guess at a fix:
Code: [Select]
--- a/keyboards/xwhatsit/brand_new_model_f/f104_round_1_nonshrunk/wcass/config.h
+++ b/keyboards/xwhatsit/brand_new_model_f/f104_round_1_nonshrunk/wcass/config.h
@@ -19,7 +19,7 @@ along with this program.  If not, see <http://www.gnu.org/licenses/>.
 #include "config_common.h"
-#define VIAL_KEYBOARD_UID {0x01, 0x41, 0x46, 0x4D, 0x04, 0x47, 0x09, 0x12}
+#define VIAL_KEYBOARD_UID {0x01, 0x40, 0x46, 0x4D, 0x04, 0x47, 0x09, 0x12}
 /* USB Device descriptor parameter */
 #define VENDOR_ID 0x1209
 #define PRODUCT_ID 0x4704
All that said ... the Vial firmware and local utility is actually quite nice, thanks @NathanA
Offline ploxiln
    • GitHub profile
« Reply #3508 on: Tue, 30 September 2025, 00:30:56 »
Oh, one more thing ... the way you rename the flash scripts, actually makes it really not obvious which is appropriate for my F77 with split right shift and non-split backspace:
Code: [Select]
'UNIX - f77 ansi block1 Ins Del etc.sh'
'UNIX - f77 ansi block2 0-9.sh'
'UNIX - f77 ansi HHKB 2U Backspace block1 Ins Del etc.sh'
'UNIX - f77 ansi HHKB 2U Backspace block2 0-9.sh'
'UNIX - f77 ansi HHKB 2U Backspace, Regular position Caps Ctrl block1 Ins Del etc.sh'
'UNIX - f77 ansi HHKB 2U Backspace, Regular position Caps Ctrl block2 0-9.sh'
But in NathanA's r5 archive, it's much more clear:
Code: [Select]
$ ls newfxx-vial-package/flash-scripts/f77/ | cat
flash-f77-allpads_opt1.sh
flash-f77-allpads_opt2.sh
flash-f77-ansi_fn_opt1.sh
flash-f77-ansi_fn_opt2.sh
flash-f77-ansi_fn_opt3_nlock.sh
flash-f77-ansi_fn_opt3.sh
flash-f77-ansi_fn_opt3_simulock.sh
flash-f77-ansi_fn_opt4_nlock.sh
flash-f77-ansi_fn_opt4_simulock.sh
... it's the ansi_fn_opt1 which was clear from the readme.txt / "NathanA's notes.docx"
(Obviously we have some differences of preferences and comfort, due to working mostly with hardware and windows, vs software and other OSes. Again, I'm really impressed and grateful for your work on the hardware manufacturing and QC side, managing the whole project for so many years, dealing with analog gremlins, etc. But on the software side, there's really some very "low hanging fruit" for organizational improvement. I hope these comments can help somewhat in the future.)
« Last Edit: Tue, 30 September 2025, 00:38:12 by ploxiln »
Offline Ellipse
Re: MK
« Reply #3509 on: Tue, 30 September 2025, 02:19:19 »
Thanks for your feedback and for your help organizing and updating the various sources of code.  This is most helpful so that we can have everything in one place, at least as a copy of the original sources.  One main request would be to make sure compiling the pandrew utility works (without needing pandrew's offline source) on Win, Mac, and Linux (it has to be recompiled whenever there is an update of a new keyboard).  And my second request would be to combine Rico and NathanA's various branches into one combined fork if possible, while keeping each branch separate (more details below).  Kindly see my replies in-line:
----This is intentional due to false positive virus reports from some folks, unless it is zipped twice.
----If you could set things up in your github account for how you describe they should be organized, then I can fork them into the project's github account, if possible (https://github.com/ModelFKeyboard).  I have just added forks of the various projects as you have recommended from Rico's account and from your account (more details below).  I see that there is a new github feature to press a button to auto sync from the place you forked from, but I am not sure what is the easiest way to get updates as the Rico and NathanA projects are updated on github.  However I like the one file for most users who are not as technical and at most will just be flashing whatever is the latest set of firmware files.  In my experience folks look all over online and mistakenly flash various files, some of which are years out of date and do not work well.  The one constant link allows you to find all needed files in one place, where you know there are no extraneous files to choose from.
----Any further improvements would require someone such as yourself to kindly update the section with a Microsoft Word style track changes option so I can see what is being changed.  Each section is in the correct sequence and the beginning of the paragraphs include a bolded statement which helps determine if the paragraph is applicable to someone's specific setup.
----Yes, I hope to be able to do this if the NathanA and Rico repos can be combined into one while still being able to auto sync (maybe with different branches?  I don't know git too well. Also they use different QMK versions and may update them at different times in the future, so I don't know how that will affect the ability to combine them).  However it is done, they should maintain their ability to both be automatically synced with that sync button that I can press in my github account to sync things in the future.
----Thanks!  Is there a way for you to combine the vial forks of Rico's various branches and NathanA's various branches?  Since github doesn't want two of the same forked projects (qmk) in one user's account.  Can you explain pandrew's various branches and when you last synced with pandrew's github?  I wonder if it is fully up to date.  May need to compare against pandrew's site when it is put back up, hopefully soon.  Maybe NathanA's future update can link to my github after I fork pandrew's latest files, if possible.
Code: [Select]
Regarding your subsequent post, I renamed the original files to match the names per the web site configuration tools.  For example, you described your keyboard as an "F77 with split right shift and non-split backspace" and the firmware name is "f77 ansi HHKB Split Backspace" plus a descriptor for the two right side block options; this is a shorthand for how it is described on the keyboard product page.  Those who prefer the original names can delete all the bat and sh files and then extract the "flash-scripts with original names.7z" file within the QMK layout files.zip file.
« Last Edit: Tue, 30 September 2025, 02:23:30 by Ellipse »
Offline Ellipse
Re: MK
« Reply #3510 on: Tue, 30 September 2025, 02:22:28 »
(double post)
« Last Edit: Tue, 30 September 2025, 02:24:07 by Ellipse »
Offline ploxiln
    • GitHub profile
« Reply #3511 on: Tue, 30 September 2025, 23:00:52 »
Ah, freakin' anti-virus, I guess this is why some people put silly encryption passwords on zip files (e.g. "password"). Whatever works I guess.
Sure, I can work on this. I'm not as familiar with compiling stuff on windows, but I'll figure it out.
Git is very flexible, and the way GitHub associates "forks" of repos in different accounts, doesn't really limit what you can do. On GitHub if you want to do branch comparisons (on the web) and create pull-requests across repos, they need to be in the same "fork network". I haven't really used the "sync" button, but it appears to only merge the default branch from the "forked-from" repo. I don't think it will do multiple branches and it definitely won't do multiple source repos.
But with a local git repo, you can add a bunch of "remote" repos, and work with all branches across all repos.The local git command doesn't care how GitHub associates the forks. You can pull branches from a bunch of different remote repos to your local system, and then push them to your own github repo. It doesn't have to be too complicated (but I don't have a great idea for how you can best automate it). I'll try to avoid churning out a full git tutorial which will bore many, but hopefully here's a useful taste of what's possible, and reasonably simple.
Even though I have ploxiln/qmk_firmware repo which I "forked" from qmk/qmk_firmware, and also ploxiln/vial-qmk repo forked from vial-kb/vial-qmk, these all share ancient qmk_firmware commit history, and I've added them all as remotes to my local qmk_firmware repo on my laptop:
Code: [Select]
$ git remote -v
darkcruix     https://github.com/darkcruix/qmk_firmware.git (fetch)
darkcruix     https://github.com/darkcruix/qmk_firmware.git (push)
pandrew       http://purdea.ro/qmk_firmware/ (fetch)
pandrew       http://purdea.ro/qmk_firmware/ (push)
ploxiln-qmk   git@github.com:ploxiln/qmk_firmware.git (fetch)
ploxiln-qmk   git@github.com:ploxiln/qmk_firmware.git (push)
ploxiln-vial  git@github.com:ploxiln/vial-qmk.git (fetch)
ploxiln-vial  git@github.com:ploxiln/vial-qmk.git (push)
upstream      https://github.com/qmk/qmk_firmware.git (fetch)
upstream      https://github.com/qmk/qmk_firmware.git (push)
vial          https://github.com/vial-kb/vial-qmk/ (fetch)
vial          https://github.com/vial-kb/vial-qmk/ (push)
$ git branch -a
  f77_layout_ploxiln
  latest
  master
* nathana_vial_xwhatsit
  pandrew_wip
  pandrew_wip2
  pandrew_wip_newqmk_2023
  pandrew_wip_old
  vial
  remotes/darkcruix/HEAD -> darkcruix/master
  remotes/darkcruix/arm-dac-work
  remotes/darkcruix/arm_rgb
  remotes/ploxiln-qmk/HEAD -> ploxiln-qmk/master
  remotes/ploxiln-qmk/f77_layout_ploxiln
  remotes/ploxiln-qmk/master
  remotes/ploxiln-qmk/pandrew_wip
  remotes/ploxiln-qmk/pandrew_wip2
  remotes/ploxiln-qmk/pandrew_wip_newqmk_2023
  remotes/ploxiln-qmk/pandrew_wip_old
  remotes/ploxiln-vial/HEAD -> ploxiln-vial/vial
  remotes/ploxiln-vial/latest
  remotes/ploxiln-vial/nathana_vial_xwhatsit
  remotes/ploxiln-vial/vial
  remotes/upstream/HEAD -> upstream/master
  remotes/upstream/arm-dac-work
  remotes/upstream/audio_out
  remotes/vial/HEAD -> vial/vial
  remotes/vial/merge-2025-06-21
  remotes/vial/old-sekigon-gonnoc-rp2040
  remotes/vial/tap-dance-tap-hold-fix
  remotes/vial/vial
That way I could "cherry-pick" commits (or files or directories from commits) on other branches on other repos, while "reconstructing" the NathanA source tree. (I didn't really need to make a new ploxiln/vial-qmk fork on github, I could have just used my existing ploxiln/qmk_firmware, but I thought it might be a cleaner way to present the branches publicly.)
So if I want to update my "master" branch from qmk/qmk_firmware, and my "vial" branch from vial-kb/vial-qmk, I would do:
Code: [Select]
git fetch --all       # update local cache of all remote repos/branches
git checkout master
git merge --ff-only upstream/master
git push ploxiln-qmk master
git checkout vial
git merge --ff-only vial/vial
git push ploxiln-vial vial
What I call the remote repos is arbitrary, you can see the mapping in the output of "git remote -v" above. The --ff-only means "fast-forward only" which means to abort if what is being "merged" does not exactly include the current branch's  entire history already, i.e. if this is not strictly a forward update. That's unexpected, and needs to be investigated/handled. Whatever I'm doing, I very often use "git status" and "git log" to confirm state of the current branch, and "gitk" or another graphical tool to see how branches intersect.
The latest I have from pandrew is April 26, 2023 (though you see author dates of April 15, or in commits on the "wip2" branch from 2021, the commiter date is how I know this is due to rebase/squash). If pandrew's host comes back, it's no problem to sync (assuming I'm paying attention).
314731-0
I think that might be the latest he published though, because NathanA's build.sh script references that commit "758febb" at the head of the "wip" branch (and "6ebae72" is the "change SOLENOID_DEFAULT_DWELL ..." commit a few below, the build.sh script effectively skips over the "util++" commits which appear add support for Vial and original non-qmk firmwares to the util, but probably conflict with NathanA's work on the util).
Code: [Select]
git clone http://purdea.ro/qmk_firmware "$(dirname "$0")"/tmp/pandrew-qmk
git -C "$(dirname "$0")"/tmp/pandrew-qmk show 758febb > "$(dirname "$0")"/tmp/f104r1-zeropads-fix.diff
git -C "$(dirname "$0")"/tmp/pandrew-qmk reset --hard 6ebae72
So I've pushed "pandrew_wip" which is pandrew's "wip" branch, which I think is his main branch. It starts from upstream QMK at tag 0.8.72 from 2020. It looks like the "wip2" branch (which I've pushed as "pandrew_wip2") is a rework of the xwhatsit calibration code, but maybe it never got to a state that is always clearly better? And finally he had a "wip_newqmk_2023" which I pushed as "pandrew_wip_newqmk_2023" which starts off somewhere between upstream QMK tag 0.20.5 and 0.20.6, adds support for more old IBM keyboards, and ends with some stack-debugging commits which suggest it wasn't stable yet?
Offline Ellipse
« Reply #3512 on: Thu, 02 October 2025, 14:21:21 »
Major project milestone:
Today the keyboard projects passed $4 million in total orders!
Thanks for your notes and update ploxiln!
« Last Edit: Thu, 02 October 2025, 14:25:20 by Ellipse »
Offline jtd
« Reply #3513 on: Fri, 03 October 2025, 12:44:10 »
Got my F122, which I already love. Unfortunately it's configured for ANSI enter when I prefer ISO enter, so I opened it up and moved some flippers around. I also split apart all the numpad keys so I can have a tab key and a dedicated comma. Now that I've booted into VIAL, however, I find I'm missing the Layout tab I expected (my F62 has one).
F62:
314767-0
F122:
314769-1
I'm guessing I need to flash a new version of the firmware to get it? Unfortunately the great Achilles heel of this project is that just about anything to do with the firmware is very difficult for me to understand. I hate to register just to ask for help, but if someone wouldn't mind holding my hand here I'd be much in your debt.
Offline Ellipse
« Reply #3514 on: Fri, 03 October 2025, 13:00:22 »
I strongly recommend that everyone reads the manual fully, as your specific question is answered there.  The Leyden Jar requires flashing an "all pads" firmware version (the first version in the folder when the files are sorted alphabetically) to split or un-split keys.
Offline jtd
« Reply #3515 on: Fri, 03 October 2025, 16:09:45 »
Thanks for answering. I have a number of unproductive complaints about what a hassle getting the pandrew utility to work was, the Windows version only showed a black screen for a second or two before crashing, and left no error message when launched from a command prompt, but I was eventually able to compile and run it in a Linux VM and get the controller into the bootloader mode so I could drag-drop the option file.
314771-0
At this point, though, may I ask why this firmware isn't the default? When I loaded into Vial it came preset to ANSI, and had the layout tab with all the options I needed easily accessible. It seems to me this would be a much more intuitive default for European users like me (I know ISO isn't popular among keyboard enthusiasts, but there are several of us who do prefer it).
I'm not technically inept, but the manual is a very dense read that frankly meanders and repeats itself (it reads a lot like a compilation of useful forum posts). That's fine in and of itself, but enthusiasts with a programming background don't always produce the best tutorials for relative amateurs like me (and being able to install a Linux VM and compile software from source already puts me in a relatively technically adept category). It's very easy to slip into skimming over sections, and then you inevitably miss something or end up on a section for a model that isn't relevant for your own keyboard. If some random person from Europe bought one of these keyboards and just wanted to use it to write with, they'd have a very hard time repeating the process I just went through, even if they do have a photographic recollection of the manual. I think expecting a normal person to use Vial to configure a keyboard is fine, it's a very intuitive tool, but when the manual instructs them to download a zip containing another zip containing a massive amount of files and an executable that doesn't work, they're going to be confused and annoyed.
I don't know what things are like from your end, but from my end I've just spent the better part of two hours figuring this stuff out (and that was after you gave me the hint that there is an all pads file, which I missed), and I'd be lying if I said I wasn't a bit frustrated. If it had been my father or my girlfriend, they'd likely still be scratching their heads figuring out whether they have an xwhatsit or a Leyden Jar. And it just seems such a pointless issue to me when the "all options enabled" firmware still defaults to a standard ANSI. You might save yourself a lot of support requests like mine if you just ship all the keyboards flashed with the "every layout option enabled" firmware, and then just include a printed "quick setup guide" detailing how to use vial.rocks to set the keyboard to an ISO layout with any keyboard sold with an ISO or HHKB key cap set. Just a thought.
Love the keyboards, but the software side of things could use some work. Thank you for taking the time to make this project a reality, I love my F62 and now I will love my F122, also.
« Last Edit: Fri, 03 October 2025, 16:15:06 by jtd »
Offline Ellipse
« Reply #3516 on: Fri, 03 October 2025, 18:22:49 »
The manual was recently reorganized.  Some points are repeated for emphasis.  If anyone would like to improve the manual, firmware, or anything else, kindly email me with recommendations and specific sentences/paragraphs to move/remove, not a general statement that the manual could be updated.
I have passed along the specific feedback to Rico to enable the adjustability for all firmware versions.  There is no time to enable the allpads version and manually go into Vial to adjust each keyboard when thousands of boards are being produced and mailed.  For now, for the small percentage of Leyden Jar users who want the adjustment, they will need to flash the firmware.
I appreciate your feedback, but your case is a good example of why the manual specifically mentions how folks get frustrated and waste hours trying to figure something out, when it was written in the manual.  Had you just flashed the needed option after reading the manual fully, it would have taken you no more than several minutes to go into vial and click the options to split or un-split keys.  The first sentence of each paragraph is often bolded if it only applies to one type of keyboard, to save some time.
The project philosophy is firmly against the idea of a "quick setup guide."  The goal of the project is to require that everyone spend an hour or more to teach themselves how to maintain their Model F keyboard for life, so that they can keep it running for many years and decades to come, long after the project has shut down.
Offline jtd
« Reply #3517 on: Sat, 04 October 2025, 04:55:13 »
I will try to organise my thoughts about the firmware section. To begin with I think it would help if it was formulated such that it’s obvious how the firmware files are organised in the archive. There are also multiple locations containing various firmware files, and it can be confusing to find the right one. In my case I was frustrated when I entered the various folders labelled firmware and keymaps to find the F122 not listed. This is probably because it uses a different controller, but I think the readme could describe what each folder contains and guide the user to the right location. Also to me the “all pads enabled” file appeared to be some sort of default version, as its name didn’t indicate it would enable the ISO enter, or the other split key options.
Additionally the section on how to use the pandrew utility was fine, but only once it actually ran. As I mentioned the Windows version didn’t open for me at all, and to compile the Linux version I had to manually clone it from GitHub because the zip in the layout archive didn’t include the git submodules (external folder, basically dependencies to compile the thing), nor the .git folder that would have let me do a git submodule pull. None of this was described in the manual. I then had to edit the build for unix script to disable SDL pipewire, because for some reason that failed to compile. I also had to edit the cmakefile because it was too out of date. And all this work seems pointless to me when you could just have your vendor flash the “all options enabled, ANSI default” firmware instead of the “no options, only ANSI” firmware.
I’m not asking why you don’t pre-configure every keyboard individually, I’m asking why the default firmware doesn’t enable any of the layout options. The all pads firmware still defaults to the ANSI layout 90% or something of your customers will want, so flashing that by default makes no difference to them (and saves them a lot of hassle if they do want to split a key in the future), but it would save your European customers a hell of a lot of trouble.
Had I only followed the manual and not understood how to compile projects off of GitHub I would still be scratching my head. I agree that users should read the manual, but I also think you’ve made things needlessly complicated for some of your users. I can see no reason why it’s on the user to flash a firmware to enable layout options, when the factory could just enable the options on every keyboard from the start.
I love the work you’ve done to future-proof these keyboards, from the good descriptions and videos on how to do mechanical adjustments or repairs, to selling every spare part a user might desire. I just think the issue I’ve had here was one that was not necessary. If I’d received a keyboard with the firmware to enable all layout options, I would have installed my solenoid, installed my key caps, booted up my computer, plugged the keyboard in, open up vial to check that each key registers, noticed my ISO enter was incorrectly showing up as an ANSI enter on the preview, opened the layout tab, and set the correct option. A US user would have had the same experience except their preview would have just been correct from the start and they could start using the thing right away. Instead I spent about three or four hours total looking through the manual, googling various forums, and trying in vain to open the Windows pandrew utility with various .net runtimes. It’s just an issue I think didn’t need to exist in the first place.
I do appreciate the work you’ve put into this project, and I love the keyboards. But I think this firmware issue is an area in which your opinion is wrong. The keyboards being made to last a lifetime doesn’t mean they need to be more complicated just for the sake of complexity.
Offline Ellipse
« Reply #3518 on: Sun, 05 October 2025, 01:01:30 »
Thanks for your feedback.  I have updated the manual based on some of your suggestions.
A file locations paragraph and some text about the "all pads" option have been added in reference to your first paragraph.
Is anyone having issues with the Leyden Jar diagnostic utility not opening on Windows?  I have not seen a report of this issue.  Maybe the entire folder was not extracted first?
2nd paragraph:  I have passed a suggestion to Rico.  Rico is looking into the best way to enable all pads on all firmware files based on these requests.
3rd paragraph:  it should not be necessary to compile anything outside of making custom firmware.  If you could email me more details about this issue with the Leyden Jar diagnostic tool on Windows, I can send to Rico.  No one else has reported such an issue.
4th paragraph:  if the ANSI firmware was flashed by mistake and you wanted the normal ISO firmware, all that was needed is to click Enter Bootloader in the utility or by using a key combination, and then flash one of the pre-made files, such as leyden_jar_f122_vial-iso.uf2.  The all pads is only needed to do additional custom splitting of keys that is not available with any of the default configurations when ordering the keyboard, unless you ordered the layout modification service.  There are even pre-made files for HHKB split only as well as HHKB right shift and split backspace.
You mention trying to open the pandrew utility in Windows.  Since you mention having the F122, that utility will not work.  Only the Leyden Jar utility will work.  I am curious, did you try with the utility in the qmk layout files zip file, or another file such as one on the NathanA site?
In general, what you did is neither required nor expected of a user who wants to just change the layout from one default option to another pre-made file.  The diagnostic utility is not even needed since you could just look in the Vial utility or the vial.rocks web site.  An issue with the utility not opening is a software bug that should be reported to me after a few minutes of trying to open it.
« Last Edit: Sun, 05 October 2025, 01:03:10 by Ellipse »
Offline jtd
« Reply #3519 on: Sun, 05 October 2025, 14:30:19 »
Every other file seemed to extract just fine. It seems most likely I was missing some dependency, but trying a bunch of .net runtimes didn't help, and they're the usual culprits in my experience.
Thank you. The best solution, in my opinion, is probably that whoever flashes firmware onto the controllers simply flashes the all pads option instead of the only ANSI one. That way ANSI users who don't modify their layouts get the same experience they do today, and ISO users, or users who want to modify the layout, can do so without needing to faff about with the firmware at all.
I don't know that I have anything more to add, really. I downloaded the archive linked in the manual, extracted it, extracted it again because it's nested, and launched the utility by double-clicking it. I got a black window for a second or two, which then closed itself. Same thing happened when I right-clicked and launched as administrator. This was on Windows 11. I tried a bunch of .Net Runtimes but it made no difference. I received no error message, and running the .exe from a terminal didn't output any errors (or other information) either.
I got the names mixed up, my bad. I used the Leyden Jar Diagnostic Tool included in QMK-layout-files.zip from the manual, "Leyden_Jar_Diagnostic_Tool.exe". I did not know that there was on NathanA's site, or I would have tried that also.
Isn't it? When I opened up Vial to set the layout options for ISO enter and splitting up the left shift and numpad, I was missing the Layout tab those options are held under. Once I had compiled the Leyden Jar Diagnostic Tool on Linux I was able to click Refresh, click Enter Bootloader, and drag-drop the firmware file. After I'd replaced the firmware with the all pads version, the Layout tab was present in Vial.
There does seem to be a bug here though, as the split left shift option turns itself off every time I open Vial. I can just toggle it back on, and the added key keeps the option it was set to after being toggled back into existence, so it's not a big deal.
Offline xyzzy42
« Reply #3520 on: Tue, 07 October 2025, 21:13:05 »
Once I had compiled the Leyden Jar Diagnostic Tool on Linux I was able to click Refresh, click Enter Bootloader, and drag-drop the firmware file. After I'd replaced the firmware with the all pads version, the Layout tab was present in Vial..
Seems like it should be possible to enter the bootloader via a hotkey sequence, without a need to run some sort of utility to trigger it.
Offline xyzzy42
« Reply #3521 on: Tue, 07 October 2025, 21:39:19 »
One wonders why the keyboards can't be supported in upstream QMK.  It supports hundreds already.  It be far better for long term viability that way.
Order are still shipping, and yet the source is already "lost" since pandrew's site went down.
Is a kludge build script that downloads things for specific hosts on the internet and applies patch files going to work in 40 years?  Obviously not.  It's already broken now!
Offline ploxiln
    • GitHub profile
« Reply #3522 on: Wed, 08 October 2025, 14:20:18 »
It's not so easy ... I think upstream is reluctant to add so much code, and probably overwhelmed by all the keyboards they already "support". Anyway, it has been attempted:
https://github.com/qmk/qmk_firmware/pull/21193
https://github.com/qmk/qmk_firmware/pull/21181
Agreed. For what it's worth, you can just replace http://purdea.ro/qmk_firmware with https://github.com/ploxiln/qmk_firmware.git in the build script, it checks-out specific git commit hashes, so if it works it's the same. It does work :)
I also went ahead and made a qmk/vial branch which matches the result of running the build script (confirmed by diff): https://github.com/ploxiln/vial-qmk/tree/nathana_vial_xwhatsit
... with 2 caveats:
 * my branch includes pandrew-util-new_kbd_defs_r5.diff but the build script does not (since the build script is for the firmware, not the util, I guess)
 * my branch does not yet include the src/layouts/*.json files (which are configs used for actual "qmk compile" commands in the build.sh script) nor the keymaps/ presets (used by the flash scripts to set initial keymap in eeprom)
I was just having trouble deciding where to put these in the qmk/vial repo fork ... looking at most other keyboards in there, it looks like there are a bunch of older or just alternative ways to organize keymaps and layouts, and for the xwhatsit dir in particular there may be a lot that are generated boilerplate or vestigial, it's kinda confusing. I'm not really familiar with QMK or Vial firmware (just software development and source-code wrangling in general) so I'm really not sure what direction we should even go to make this more well-organized and upstreamable, what could or should be "cleaned up" from the xwhatsit keyboards tree...
So anyway, I'll shortly just pick some reasonable arrangement and go with it, and add a very short script to do the compile and flash stand-alone from my fork/branch, and then iterate from there if there is some good motivation/advice.
Offline Ellipse
« Reply #3523 on: Tue, 14 October 2025, 20:11:05 »
jtd-my note was that it is not necessary to perform all those steps.  To flash to the default ISO, one can use the key combination Fn+Spacebar+R or Leyden Jar diagnostic tool to enter the bootloader, and then copy and paste the firmware uf2 file to the empty drive that appears in the Explorer/File Manager.
Rico is currently working on an updated firmware to fix the all pads splitting not saving some changes, as well as the calibration bin issue introduced with a recent beta firmware (my recommendation is that everyone stay with the latest May 2025 firmware unless you'd like to help with the beta testing).
Thanks for your updates ploxiln.  If you come up with any recommendations to combine the Leyden Jar/NathanA/pandrew files into one, please let me know.  Maybe I can make my github page the official one and add NathanA and Rico as admins so they can update everything (while keeping the git history)?  I know that the NathanA and Rico firmwares run on different versions of QMK/Vial.  This would likely involve updating my github to incorporate your source files and copy to my github, so that there are no outside files needed.
« Last Edit: Tue, 14 October 2025, 22:15:01 by Ellipse »
Offline Ellipse
« Reply #3524 on: Wed, 15 October 2025, 13:49:37 »
With permission I am sharing a custom "all pads" layout with the custom 3x5 cut out mod.  These mods were first suggested by this user, who is nicknaming this version the F138; now several others have ordered this mod for their F122 (you don't have to use all pads with the 3x5 cut out mod - you can have a regular ANSI/ISO/split shift layout just with 5 keys added above your cursor keys).  I still have some cut out cases but they are only available in certain colors (beige and others, no more black cut out cases).  Please email me if interested in ordering one.
With this layout, every available pad is used for a key.  Each key can be configured in Vial as there is a working pad for each one.
314922-0
Offline Ellipse
« Reply #3525 on: Wed, 22 October 2025, 13:23:12 »
Has anyone come up with additional Model F 3d printed mods?  I have looked around the various 3d parts sites.
I have purchased a 3d printer to help with prototyping as well as to offer 3d printed items to those who do not have their own 3d printer - items like 3d printed solenoid holders and feet.
Maybe even some flip-out feet like the IBM F122 and XT/AT feet that could be attached by bolts to the holes in the bottom of the cases.
Any other ideas for 3d printed parts?
Offline Ellipse
« Reply #3526 on: Fri, 24 October 2025, 15:18:44 »
Rico has just published the latest firmware update for all Leyden-Jar based keyboards (currently just the F122 but soon the Round 2 B104 and B122, and eventually all boards):
https://github.com/mymakercorner/vial-qmk/releases/tag/Firmware_Release_2025_10_24
This firmware fixes a bug where the keyboard needed to be unplugged and plugged back in to work after certain computers resumed from sleep mode.  It also fixes an issue where splitting certain keys in the allpads version was not saved after the keyboard is power cycled.
Everyone feel free to test this latest version and let me know if there are any other issues.
Offline ploxiln
    • GitHub profile
« Reply #3527 on: Mon, 27 October 2025, 15:05:16 »
Hi Ellipse, I've been working on building the xwhatsit/wcass firmware and util for all platforms, and my own scripts for building and flashing, etc. It's not really better than NathanA's r5 release build, as far as I know, but the purpose is more to confirm that my scripts can do it all "from scratch". These scripts are in the repo: build_vial_xwhatsit_all.sh, flash-util/*, keyboards/xwhatsit/util/*.sh You can see the resulting builds of all this at https://github.com/ploxiln/vial-qmk/releases/tag/newfxx_r5c
Something new included there is a Linux AppImage build of pandrew-util. (There's also a Windows exe and macOS app, but built for the newer cpu archs compared to NathanA's builds, see release description). I took the liberty of using your favicon from modelfkeyboards.com and scaling/adapting it "quick and dirty" for pandrew-util, I hope that's OK.
See also the updated repo README starting around here: https://github.com/ploxiln/vial-qmk?tab=readme-ov-file#build-vial-firmware
Regarding syncing both the leyden_jar and xwhatsit github repos / branches ... it would probably have been simplest to "fork" from both my repo and rico's repo, but you mentioned you can't do that because both forks are in the "vial-kb/vial-qmk" "network" and you can only have one fork related to that network in your github account. I could theoretically unlink my repo from upstream "vial-kb/vial-qmk" but actually that function is disabled because my repo "already has child forks". Hmm. I think maybe the cleanest thing to do is just fork from the more-upstream "vial-kb/vial-qmk", and then use git locally (or some git gui) to periodically sync the branches from rico and I, if there are changes. If someone else effectively takes over from me (or NathanA comes back), it would be simpler to switch to pulling a branch from them at that point.
« Last Edit: Mon, 27 October 2025, 16:53:09 by ploxiln »
Offline Ellipse
« Reply #3528 on: Mon, 27 October 2025, 16:10:40 »
Great thanks ploxiln!  I have shared your update on the DT forum thread as well.
I like the added icon!  Makes it easy to identify the program in the taskbar for Windows.
NathanA has noted that due to size limitations of the Atmega chips, the xwhatsit versions will not run QMK Vial versions after a certain point, so updates from QMK Vial are not expected.  Rico's RP2040 controllers have enough room to work with newer QMK as it is updated.  So maybe Rico's version can remain linked but NathanA's stuff can be disconnected from QMK, or some other way you can think of to keep xwhatsit and Leyden Jar together.
Or can NathanA be added as a branch within the Rico Leyden Jar?  I have read that "Different branches within a Git repository can indeed reference different gits or, more accurately, different versions or configurations of the same linked resource, particularly when using Git submodules."
And what about folks running older computer systems?  Can there be a separate file or folder to build it for those older systems that you removed support for, just to make sure these keyboards are supported as widely as possible?
« Last Edit: Mon, 27 October 2025, 16:13:21 by Ellipse »
Offline ploxiln
    • GitHub profile
« Reply #3529 on: Thu, 30 October 2025, 10:08:41 »
Yes, this would be quite reasonable ... but the way to do it is with local git commands, like:
Code: [Select]
# first, "fork" mymakercorner/vial-qmk to "ModelFKeyboard/vial-qmk" on GitHub's web UI, then
git clone git@github.com:ModelFKeyboard/vial-qmk.git
cd vial-qmk
git remote add ploxiln git@github.com:ploxiln/vial-qmk.git
git fetch --all
# use any unused name for the new branch, here I call it "xwhatsit"
git switch --create xwhatsit ploxiln/latest
git push --set-upstream origin xwhatsit
# initial setup done
# to sync further changes:
git switch xwhatsit
git fetch --all
git merge --ff-only ploxiln/latest
git push
It's actually easy to compile for Windows i686 (x86_32), but I figured those systems would be rather rare now. I think intel Apple Mac (x86_64) systems are more common out there, but trickier to compile for with the Apple Silicon (amd64) Mac which I have convenient access to. (It should be possible, but I need to compile qt5 and any sub-dependencies from source for the old arch, and they may need some tricky hacking on their build systems.) I'll probably start by trying to compile dfu-programmer for old intel Macs, should be a much simpler exercise to start ...
Offline Ellipse
« Reply #3530 on: Fri, 31 October 2025, 13:33:54 »
With permission I am posting a nice new production F122 setup with a CRT monitor.  I had one of those old Dell CRT's back in the day!  I don't recall the specific model but we got it in 1997 or 1998 I believe.
315077-0
Offline OCTAGRAM
« Reply #3531 on: Tue, 04 November 2025, 11:25:48 »
Is it possible to make Amiga layout keyboards? Recent Amiga 40 event had some keyboard announcement, like if it is some achievement. I personally prefer Model M look, but maybe some Amiga fans can be made happy
Offline Ellipse
« Reply #3532 on: Tue, 04 November 2025, 12:41:27 »
All layouts are possible if there is enough interest - everyone feel free to sign the Google form for the new Model F keyboard designs:
https://geekhack.org/index.php?topic=79141.msg3203218#msg3203218
Offline Ellipse
« Reply #3533 on: Tue, 04 November 2025, 14:35:09 »
Leyden Jar firmware update (for F122):
Rico has posted an update for the Leyden Jar firmware.  It allows more space to store macros compared to the Vial default and all firmware files can now split and unsplit keys (no need to reflash the allpads firmware).
As noted with last month's update, the firmware was fixed last month with issues related to resume from sleep and certain split settings not saving after you make changes to them.
Offline Ellipse
« Reply #3534 on: Thu, 06 November 2025, 23:19:49 »
This month the keyboard projects passed 7,000 shipped keyboards!  Shipping started in late 2019.
We still have the normal backlog of recent orders as well as the round 2 beam spring keyboards, which are currently in production and expected to go out over the coming months (more details on the beam spring thread).
Orders (with and without keyboards) have gone to 71 countries in total (per ISO 3166):
Argentina
Australia
Austria
Bahrain
Belgium
Brazil
Bulgaria
Canada
Chile
China
Colombia
Croatia
Curaçao
Cyprus
Czechia
Denmark
Estonia
Faroe Islands (the)
Finland
France
Germany
Gibraltar
Greece
Guam
Hong Kong
Hungary
Iceland
India
Indonesia
Ireland
Israel
Italy
Japan
Kazakhstan
Korea (the Republic of)
Lithuania
Luxembourg
Macao
Malaysia
Mauritius
Mexico
Netherlands (the)
New Zealand
Norway
Oman
Peru
Philippines (the)
Poland
Portugal
Puerto Rico
Qatar
Republic of North Macedonia
Romania
Russian Federation (the)
Saudi Arabia
Senegal
Serbia
Singapore
Slovakia
Slovenia
South Africa
Spain
Sweden
Switzerland
Taiwan (Province of China)
Thailand
Turkey
United Arab Emirates (the)
United Kingdom of Great Britain and Northern Ireland (the)
United States of America (the)
Viet Nam
« Last Edit: Thu, 06 November 2025, 23:22:59 by Ellipse »
Offline Morning Song
« Reply #3535 on: Fri, 07 November 2025, 13:11:43 »
So I just got mine! Lovely piece of kit, and worked much easier than the manual implied. (Which is fair enough, the information is much more important to someone who hasn't used an F122 for a decade now)
Anyway I'm trying to mess around with my keymap in Vial.Rocks, and I want to map the left hand fkey block to their corresponding Sun Type 6 keycodes. Of which seven appear in the media key tab(Stop, Again, Undo, Copy, Paste, Find, Cut), but we're missing three (Props, Front, Open)
Am I blind and missing them in there, and if not, is this a bug I should file with Vial, or who should I bug about it?
Clicky keyboards and big trackballs forever!
Keyboards:
Buckling Spring: IBM Model M 1391401, Unicomp Customizer 104, PS/2 modded IBM Model F Terminal 6110668 (current favorite)
Cherry: Filco Majestouch 105 Blue NKRO w/ doubleshots
ALPS: Dell AT101W Black SNAFU (Silent No-longer; All Fukka\'d Up), Siig Minitouch KB1948 Geek Hack Spacesaver edition, Focus FK-2001 w/ WinKeys+XM Alps
Rubber Dome: Belkin F8E887-BLK, Silitek SK-6000, Logitech Internet Navigator Keyboard
Works in Progress:
Prism ATX N9 Keyboard w/ Fukkas (Clickleaf Donor), Cherry G80-8113HRBUS-2/02 Brown NKRO, Cherry G81-7000HPCUS-2/02 (Doubleshot donors), Unicomp Customizer 101 (Springs donor, needs boltmod)
Pointing Devices:
Kensington Expert Mouse 7, Wacom Intuos3 6x8 w/ classic pen
Looking to buy/trade for:Dolch Cherry keycaps, Northgate Omnikey (With Fkeys on top, or both top & left), IBM Model F AT
Offline Rico
« Reply #3536 on: Fri, 07 November 2025, 15:37:20 »
Hello,
Those are really special keycodes you are looking for.
Please find below a list of all supported QMK keycodes:
https://docs.qmk.fm/keycodes
Maybe Props could be KC_CRSEL.
Also not all keycodes have a name mapped into VIA/VIAL, in this case there is a need to directly type the hexadecimal value.
This sucks but neither VIA or VIAL teams look to be willing to have complete keycode support in their application.
« Reply #3537 on: Sat, 08 November 2025, 12:15:52 »
Hello,
That was it exactly, thank you!
No glamour shots until I get the keycaps I forgot to order, but this is what the completed mapping looks like for anyone else who wants to pretend to have a sparcstation but with better keyboard:
Keyboards:
Works in Progress:
Pointing Devices:
Offline Rico
« Reply #3538 on: Sun, 09 November 2025, 13:14:56 »
Oh, you even found all the keys you wanted, great !
Offline Ellipse
« Reply #3539 on: Mon, 10 November 2025, 12:47:04 »
With permission I am posting some interesting photos:
First, here is a customized New F122 with third party extras:  an IBM badge and LED overlay.
315261-0
And here is a very rare IBM Selectric I typewriter repair log / service transcript.  A true testament to the repairability of built to last IBM products.
315263-1
315265-2
Offline Ellipse
« Reply #3540 on: Wed, 26 November 2025, 13:48:33 »
Chyrosran22 has just posted the new F122 trailer - I am looking forward to the full video!
Offline Ellipse
« Reply #3541 on: Thu, 04 December 2025, 02:07:52 »
Pad print update:
After the other pad print supplier failed to produce keycaps that met my requirements, I changed to another factory earlier this year.  They have been in business for a couple decades and focus on computer peripherals.
A reminder to sign the Google form (link below) to reserve a pad printed key set.  The first batch of about 250-300 will be white text on black keys, US key sets only, no front printing.  Additional sets will proceed based on demand.
https://forms.gle/moBjiL2uPUGTosWZ6
To protect the pad printing which is less durable than sublimation printing by design, these keycaps will be packaged both before and after the pad print process in custom blister packaging.  The first sample blister pack is below (apologies for the low quality image).  These should be available to order separately in the future, to store other Model F keycap sets.  Note:  by design, the blister packs do not hold a spacebar, and they contain additional spaces for keycaps, more than what would fill a regular board.
315499-0
Offline Ellipse
« Reply #3542 on: Sun, 07 December 2025, 13:29:53 »
Chyrosran22 has just posted the new F122 unboxing video - I am looking forward to the full review coming soon!
Offline Zhugeliang
« Reply #3543 on: Fri, 19 December 2025, 00:14:07 »
First time deep cleaning my F77 after more than 3 years. Thanks Ecplise for the wonderful project! This is still my daily driver and it stays strong!
Offline Ellipse
« Reply #3544 on: Sat, 20 December 2025, 15:21:06 »
Glad your new F77 is working well even after 3 years Zhugeliang!  It looks quite clean.
3d printed parts update:
https://www.modelfkeyboards.com/product/3d-printed-parts/
On the above product page, everyone can now get Model F - related 3d printed parts from the shop, including 3d printed solenoid driver and solenoid holders, flip out feet, and original Model F feet.  If any others should be added to the page, please email me.
Solenoid Driver and Solenoid Holder Example 1
Solenoid Driver and Solenoid Holder Example 2
Solenoid Driver and Solenoid Holder Example 3
Spacebar adapter (set of 2)
PC XT Replacement Foot
Riser Stand for Classic Style F104/FSSK
Flip Out Feet Example 1 (set of two)
Flip Out Feet Example 2 (set of two)
Offline Ellipse
« Reply #3545 on: Mon, 22 December 2025, 16:36:29 »
The long-awaited Chyrosran22 new F122 keyboard review has just been posted!
My reply is copied below in case you can't find it among all the comments:
Thanks Thomas for making a great Model F F122 video!  I greatly appreciate what you have done to keep these great old style keyboards alive and to make folks aware of all the various options that are lesser known.  I will try to keep my replies more terse per your advice but it takes far fewer words for some of these commenters to mislead someone with a one-liner than it is for me to offer an explanation.  Your video was incredibly detailed in featuring different aspects of the board and some amount of detail is beneficial in response.
Replacing parts:  I am seeing that some folks in the comments noting that I have not followed up with replacing some of the parts.  Please note that damaged parts will be replaced as part of the limited warranty.  Please email me a reminder so I can follow up on getting out your replacement parts as I am still going through the backlog.  Normally I also cover shipping fees for replacement parts, even for international folks.
Case material:  The new production cases are all aluminum now, while the original project F62/F77 cases were Zamak 3 Zinc.  Otherwise these keyboards would be even heavier!  The inner assembly plates are steel.
USB Cable:  The USB-C cable is detachable at the controller, if you open up the keyboard you can replace the cable with your own cable, or even with a short extension cable so that you can detach the cable externally.  For my future models (ortholinear, split, 5x12, Kinesis style, etc.) since they will be compact case style, they should have externally detachable cables.
The pinging/ringing sound:  you noted that the original F produces less of a ringing sound.  I have noted that many Model F boards vary in their pinginess.  I have found the earlier Model F keyboards to produce more ringing (IBM XT, and the original 4704 boards like F62/F77) while the later ones produce less ringing (AT, the later production F122's such as your two-piece version).  My reproductions were designed around the 62/77 so they will make more sound.
Regarding criticism: some folks may think that companies must always deferentially accept criticism and that otherwise they are in the wrong.  I feel I have a right to respond, and I don't have to accept the criticism as valid and apologize for customer service that does not meet expectations that are not in line with the project philosophy, which emphasizes empowering users to set up and maintain their keyboards and accept small but noticeable cosmetic defects (more details can be found on the project site).  Companies can do this if the manufacturing cost is many times less than the sales price or those that have enormous markups.  In summary I can't sell these keyboards at as low a price as they are currently without having users learn how to replace springs, reseat keycaps, etc. instead of having to take back the entire keyboard for repairs.  My goal is to get as many of these keyboards out into the world and that limits my ability to raise prices to pay for repair technicians, customer service reps, etc.  I'd rather have 0.5% of orders having complaints than having 50% fewer folks being able to afford it if pricing is increased for everyone to make the 0.5% happy with extra "free" services.
Limited warranty:  I would agree that it would not be economical if the keyboards cost double but everything is taken care of, no questions asked, like those complete warranties offered by big companies.  I am looking for folks who prefer the former, and not the latter.  I ask that folks review the manual to fix things themselves, and go to me as a last resort, where I will usually replace what is non-functional for free.
Once again thanks for putting all of this together!
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
Re: [GB] F104+SSK+122+62+77+50+Ergo orders now open! Kishsaver+Industrial Model F
« Reply #3546 on: Wed, 31 December 2025, 23:36:25 »
Blog update:
The latest blog update has been posted on the project website:
https://www.modelfkeyboards.com/blog/
As always, this update collects all of the various updates since the last update in mid-year.
« Reply #3547 on: Wed, 07 January 2026, 09:49:50 »
Got all the extra keycaps, so a proper glamour shot:
315752-0
Keyboards:
Works in Progress:
Pointing Devices:
Offline Ellipse
« Reply #3548 on: Wed, 07 January 2026, 12:28:04 »
Looks great Morning Song!  That 1.25U Enter is quite rare so it is nice to see how flexible IBM's Model F design was, to allow all sorts of layouts (ANSI, ISO, JIS, TIE Enter, etc.).
« Reply #3549 on: Wed, 07 January 2026, 13:11:02 »
I originally got it on my OG F122 so i would be able to have Escape, |\ and `~ without sacrificing any FKeys. Less necessary with your modernized layout, but I'm used to it now and like having more keys available. (Until I start running out of usable HID codes, anyway)
Keyboards:
Works in Progress:
Pointing Devices:
