Author Topic: Nonfunctional escape key  (Read 3506 times)
Offline HTN47
  • Mr. SoCal
« on: Thu, 28 January 2016, 02:19:13 »
Hey guys, so I am in need of advice. I was soldering some switches into my tx87 pcb today and made some mistakes.
 Long story short, I basically burned off the heating pad for the diode on the escape key. My question now is if there is a way for me to maybe "jump" the diode from another key to my escape key?
I've included s picture of my terrible job, but that was before I effed it up even more... The pads are completely gone now  :(
Any help would be greatly appreciated  :)
What is love.... Baby don't hurt me... No more!!
Re: Nonfunctional escape key
« Reply #1 on: Thu, 28 January 2016, 02:41:44 »
Is it the top pad? That one connects to the switch pin above it :)
Offline HTN47
  • Mr. SoCal
« Reply #2 on: Thu, 28 January 2016, 02:57:56 »
I'm sorry... I'm not sure what do you mean by it connecting to the switch pin alive it... Both of the pads, top and bottom got burned unfortunately... It fell off after my repeated attempts to fix it...  :(
Offline henz
  • What?
« Reply #3 on: Thu, 28 January 2016, 03:07:38 »
well the pcb is just there to make everything looks nicer, usually it goes like this: controller-> matrix -> diode  -> switch -> matrix -> controller  so you should be able to attach a diode to the switch pin(look at the traces which pin goes to the diode pads) then connect it to the matrix in an appropriate place. There is a bunch of good pcb repair videos on youtube.
Edit: i think you should be able to attach a through hole diode to the rightmost pin and the bottom pad. Im not sure which way is the anode or cathode is cause youve burn the whole thing but you have a 50/50 chance. if it doesnt work just change the directon of the diode.
Offline HTN47
  • Mr. SoCal
« Reply #4 on: Thu, 28 January 2016, 03:25:08 »
Ahhhh okay, so if I burned the bottom pad also, I just have to trace it to where it links up next and attach my diode there?
My bottom pad fell off also  :(
Offline henz
  • What?
« Reply #5 on: Thu, 28 January 2016, 03:30:25 »
That or you can GENTLY rub off the cover of the trace with a knife or something and attach it there.
Offline tronbeaver
« Reply #6 on: Thu, 28 January 2016, 09:22:28 »
This.
Use a wire and sandpaper and bridge it.
Offline HTN47
  • Mr. SoCal
« Reply #7 on: Thu, 28 January 2016, 15:59:35 »
So this is what I ended up with... It's still not working unfortunately...
Any tips on what I did wrong?
Thanks again for helping me out ^_^
Offline radish
« Reply #8 on: Thu, 28 January 2016, 16:39:13 »
double check to see if you didnt kill the switch. it may very well be as simple as swapping the switch. fingers crossed.
LZ CP
Offline HTN47
  • Mr. SoCal
« Reply #9 on: Fri, 29 January 2016, 23:39:07 »
So I finally got the Esc key to work thanks to your advices  :D
But my problem now is that when I plugged in the keyboard again, the SMDs on the back started flashing... I tried to flash the firmware to the latest version and it worked the first time but when I rebooted my computer it started flashing again. So just like last time, I tried to flash the firmware again but this time it won't register any keys when I was prompt to "press any key to continue firmware update"...
I think somewhere along the line I messed up the controller during the firmware update...
Anyone have an idea of where can I purchase another TX87 PCB? or maybe a method of resetting the whole keyboard somehow?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #10 on: Sat, 30 January 2016, 04:09:43 »
Download SharpKeys and rebind Pause/Break to Esc. That key is never used anyway.
Offline HTN47
  • Mr. SoCal
« Reply #11 on: Thu, 04 February 2016, 15:40:36 »
Hey guys, just wanted to give an update and a big thank you to all of you  :)
I really appreciate it, my keyboard is fully functional now  :D
Special shoutout to Radish, you the man! Apparently my escape key was faulty and it caused shorting issues with the ` key right below it, which is actually what made my keyboard not work when I plugged it in.
According to Leeku holding the ` key put the keyboard into update mode when you plug it in.
Learned a lot about keyboard this week  :D
Thanks again guys, much love <3
Offline crickclackman
« Reply #12 on: Thu, 04 February 2016, 16:40:17 »
There IS Escape!
Offline radish
« Reply #13 on: Mon, 15 February 2016, 02:46:59 »
right on! super happy to see you fixed it!
LZ CP
