Author Topic: Unusual vintage KB in handbuilt wood box...?  (Read 4435 times)
Offline ander
  • I type, therefore I am
« on: Mon, 01 February 2016, 18:47:54 »
Here's an interesting thing:
Vintage Very Rare Wooden Computer Case Body-Cherry Keyboard UB8-01AA Digital
I haven't posted it in Great Finds, as they're asking $12K (though it may very well be worth that much, for all I know.) Seller doesn't know more about it—any theories?
Notice the "Bill" sticker at lower L... Maybe a '70s Bill Gates original?  :?)
Offline 0100010
  • Not Sure
Re: Unusual vintage KB in handbuilt wood box...?
« Reply #1 on: Tue, 02 February 2016, 15:35:40 »
Pretty unique - but not $12K unique.
Offline 0100010
  • Not Sure
« Reply #2 on: Tue, 02 February 2016, 15:39:05 »
It is a hand made shell for this : https://geekhack.org/index.php?topic=45470.0;nowap
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #3 on: Tue, 02 February 2016, 18:49:48 »
It's incredibly easy to bend the metal pieces inside the switches and break the switch completely
Offline crickclackman
« Reply #4 on: Tue, 02 February 2016, 19:13:11 »
$12,001!
Offline ander
« Reply #5 on: Thu, 04 February 2016, 04:55:09 »
You're right! How did you remember something like that? I'm impressed.
Why do you think they went to all that trouble? To raise and angle the KB the way they wanted it, and have a platform for their monitor? Or maybe because it looked a bit more tasteful as a home furnishing? I guess that would've looked pretty chic in the '80s.
Nope! It's an even funnier thing to consider, now that we know what it actually is.
Offline 0100010
  • Not Sure
« Reply #6 on: Thu, 04 February 2016, 08:18:00 »
My guess is that it came from a terminal + printer DECwriter; and that someone wanted to re-use the board with a CRT based terminal instead of the printer.  Hence the new case, that the CRT could be placed on top of.
rootwyrm would probably like to see this.
Offline iLLucionist
  • Topre is Love.
« Reply #7 on: Thu, 04 February 2016, 10:47:44 »
My guess is that it is a custom-case that was originally intended to fit an Apple 1 board. Apple 1's were just the PCB's and you needed your own case / kb / display (tv back then). Looks like it would fit those dimensions.
Offline 0100010
  • Not Sure
« Reply #8 on: Thu, 04 February 2016, 18:48:15 »
I'm pretty sure its a DECwriter custom "case".
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #9 on: Fri, 29 April 2016, 08:39:43 »
Little late to the party but indeed, me likey.
Also, you are correct - that's a DECwriter board in a housing to rest a CRT on top of. Note the wiring inside - that's power and a DB25 direct to the board. No room for any other PCBs. And you see that sub-controller? I'm betting that's a code translator board, because this thing appears to be wired for a VT100-series (first models without an integrated keyboard.) My guess is somebody liked the DECwriter feel enough to do this.
The white and gold part there in the center is what makes it rare and unique - that's likely a Zilog Z80 or Intel 8080 doing duty as the code translating processor. So yeah, custom keyboard controller in a custom housing back around I'd say mid 80's possibly. (I don't see a UVEEPROM tho, so not sure how they're doing code storage.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline chuckdee
« Reply #10 on: Fri, 29 April 2016, 08:59:12 »
I think you nailed it.  I had a Franklin Ace 1000 and the setup looked very similar to that when I had to break it open to mod it. (Added an 80 column card, a sound card, and a speech processor)
Offline 0100010
  • Not Sure
« Reply #11 on: Fri, 29 April 2016, 12:26:16 »
