Author Topic: [IC] VE.A  (Read 381366 times)
Offline Data
Re: [IC] VE.A
« Reply #650 on: Wed, 06 April 2016, 16:48:37 »
What is everyone doing for spacebars?  Are those just blank R4 Shifts or... ?
I space with the left hand.  It's a shame the position of the shorter space and FN key can't be swapped to the right half.
i spaced with the wrong hand before as well, you should change!
I verified with Mavis Beacon: left thumb is correct for spacing.
Have a nice day.
Left space bar is number pad 2x 0 keycap.
Right space bar is 2.75x right shift keycap.
Position if ThumbFN is pretty controversial so I'll work on that for next version.
Yeah I just checked.  My left thumb rides right between V and B on the spacebar in staggered QWERTY and that's exactly where you've placed the Fn key in the default layout.  This layout is no good for me.  What a bummer!  I suppose I'll have to wait for Version 2.  :(
« Last Edit: Wed, 06 April 2016, 16:53:00 by Data »
Offline yicaoyimu
Re: [IC] VE.A
« Reply #651 on: Wed, 06 April 2016, 17:17:47 »
I guess you can always just program the fn key to be space.
Offline FrostyToast
  • Litshoard
Re: [IC] VE.A
« Reply #652 on: Wed, 06 April 2016, 17:33:04 »
I use qwerty and I like spacebar with the right because the left hand sees a lot more activity when typing. This means that the right hand is often free and giving the spacebar to the right hand helps to balance out the work between hands.
Though I can see problems when people are playing games. Not being able to comfortably position your fingers on the wasd cluster and thumb on space can be an issue.
Quote from: elton5354
Offline hkf
  • your #1 fan
Re: [IC] VE.A
« Reply #653 on: Wed, 06 April 2016, 17:51:42 »
how heavy are these going to be?
OP mentioned approx. 1 Kg / side.
Vouch. 1kg/side is about right.
Offline G.C.W.
  • Formerly t!ng
Re: [IC] VE.A
« Reply #654 on: Thu, 07 April 2016, 06:57:35 »
Considering this vote there should be an option to change Layout:
https://deskthority.net/keyboards-f2/which-thumb-do-you-use-for-the-space-bar-t12936.html
Premium pouches for premium peripherals at www.wegner.design
Offline krisst
Re: [IC] VE.A
« Reply #655 on: Thu, 07 April 2016, 10:44:41 »
Interesting read. Would agree if possible, to support different buttom row option. I am right handed, using left thumb for spacebar. Specifically the area under V and B key. That means I would be hitting the function key.
Offline muon
Re: [IC] VE.A
« Reply #656 on: Sat, 09 April 2016, 04:14:26 »
Totally in for next round, if there will be one.
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #657 on: Sun, 10 April 2016, 23:32:17 »
I'm listening guys :)
And working on that.
ZeFyr "Vermillion" J.
Vergo type.T / alpetit / alpetit II / VE.A with Vergo type.T-II
Offline Data
Re: [IC] VE.A
« Reply #658 on: Mon, 11 April 2016, 00:45:00 »
 :thumb:
Just a thought: if the locations of the 2u left Space and left Fn were reversed (or if there was an option for it on the PCB) that would be an easy fix for me.
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC] VE.A
« Reply #659 on: Mon, 11 April 2016, 07:58:51 »
After buying the Hana keycap set, it might look good on this  :)
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #660 on: Mon, 11 April 2016, 11:18:24 »
 :thumb:
Yes exactly.
Offline alienman82
Re: [IC] VE.A
« Reply #661 on: Mon, 11 April 2016, 11:57:13 »
still can't wait for this one :)
Offline Azzures
  • ༼ つ ಥ_ಥ ༽つ PRAISE HELIX ༼ つ ಥ_ಥ ༽つ
Re: [IC] VE.A
« Reply #662 on: Mon, 11 April 2016, 17:37:57 »
Man, have a bunch of 67g zealios lying in wait for my ergodox, but so tempted to wait to put them on this instead.
Offline BlueMoon
Re: [IC] VE.A
« Reply #663 on: Wed, 13 April 2016, 15:52:55 »
If you add an option for the opposite spacebar configuration, the current option will still exist too, right? I'm right handed and hit space with my right thumb (between N and M) and so the default configuration would be ideal for me.
Really, really excited about this buy -- this board is endgame for me. Any more updates on the timeline and when we will be able to buy?
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #664 on: Thu, 14 April 2016, 02:49:17 »
Positive.
Offline Vimto
Re: [IC] VE.A
« Reply #665 on: Thu, 14 April 2016, 03:39:01 »
any ETA yet?
HHKB Pro 2    HHKB Pro 2   Realforce 87U       WhiteFox        Keyboardio
   BT Hasu                              55g 10th      The True Fox        Model 01
  Controller                        Anniversary Ed.     On Order         On Order
Offline hkf
  • your #1 fan
Re: [IC] VE.A
« Reply #666 on: Thu, 14 April 2016, 03:42:02 »
Zefyr, will we be able to get just pcb and plate?
Offline Karura
  • Professional Canadian
  • SKidata life.
Re: [IC] VE.A
« Reply #667 on: Thu, 14 April 2016, 05:14:12 »
What will the opposite spacebar configuration look like?
Offline turboloser
Re: [IC] VE.A
« Reply #668 on: Thu, 14 April 2016, 13:01:17 »
I am a leftie, please be kind to us.
Offline demonlinx
Re: [IC] VE.A
« Reply #669 on: Thu, 14 April 2016, 15:40:00 »
Definitely interested. Can't wait for this to be a GB.
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #670 on: Thu, 14 April 2016, 23:17:22 »
No, not this time.
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #671 on: Thu, 21 April 2016, 08:26:53 »
Announcement from team oddforge
As mentioned several times, we struggled to set this GB smoothly.
We are building up e-shop solution but time is too short.
We cannot hold you guys anymore.
Finally found solution and this will happen in very safe/smooth way.
We've been in touch with Massdrop to assist with coordination on this GB.
Massdrop was excited to help with this project and VE.A is scheduled to launch in the middle of May.
At this point, we will not set limit of quantity.
Hope you guys are happy with this way :)
Thanks for waiting everyone.
Re: [IC] VE.A
« Reply #672 on: Thu, 21 April 2016, 08:29:39 »
Dang! Crazy! Massdrop actually getting a Korean custom...
Never thought I'd see the day.
Excited!
Offline Geekmie
Re: [IC] VE.A
« Reply #673 on: Thu, 21 April 2016, 08:34:14 »
Awesome. I'm ready for it! Where is my time machine? ;D
Offline limitz
  • "the old gods stir and will not let me sleep..."
Re: [IC] VE.A
« Reply #674 on: Thu, 21 April 2016, 08:44:44 »
Thanks for the update Zefyr. Will there be any compromises in quality by going through MassDrop, or will you try to stay true to your GB, V2 version?
Mmm... machined aluminum
Offline Vittra
  • Airflow Optimizer
Re: [IC] VE.A
« Reply #675 on: Thu, 21 April 2016, 09:01:28 »
I suggest you speak to Massdrop and be very specific regarding the details of HOW the keyboards need to be packed/protected for shipment, otherwise many people will receive damaged product.
Filco MJ Linear R LE TKL
Offline alienman82
Re: [IC] VE.A
« Reply #676 on: Thu, 21 April 2016, 09:04:47 »
ooooohhhhhhh.  I need to get one!x
Offline exitfire401
  • The Force is Re/\l
Re: [IC] VE.A
« Reply #677 on: Thu, 21 April 2016, 09:08:32 »
That is insane! Looking forward to it!
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #678 on: Thu, 21 April 2016, 09:08:43 »
Personal customized marking plate will not be provided, only common product signature marking plate will be included.
Except that, no quality compromise. We have really strict standard about quality. - Only Quality Matters -
And I don't understand what you are meaning "V2"?
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #679 on: Thu, 21 April 2016, 09:09:04 »
Noted!
Thanks for your advice.
Offline limitz
Re: [IC] VE.A
« Reply #680 on: Thu, 21 April 2016, 09:17:17 »
Ahh, I thought the VE.A that just ran in S. Korea was the V2. My confusion.
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #681 on: Thu, 21 April 2016, 09:17:39 »
Additional Announcement.
I have to say really sorry for Alps fans since Alps switch mounting plate will not be provided in Massdrop.
I believe all Alps fans can understand why I removed this option.
But I'll explain anyway.
Alps mounting system is very strict about layout.
It has no sustain pins like Cherry MX, and stabilizers is mounted on mounting plate so "Universal Alps plate" cannot be made.
Plus, there's no "Standard" keycap sets for alps (except Matias, but I don't want to limit selection of keycaps.).
So, We will share alps plate drawing on public.
And for who have no access to metalworks shop, we will accept order of Alps plate in our website.
This can make you spend another shipping money. but at this time, I have no better way.
Sorry again and thank you for your understanding in advance :)
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #682 on: Thu, 21 April 2016, 09:19:02 »
VE.A uses PCB Vergo type.T-II
that might cause you confusion.
Re: [IC] VE.A
« Reply #683 on: Thu, 21 April 2016, 09:19:04 »
That's okay. Finding keycaps for Alps would be difficult, anyway.  :thumb:
Offline sitch
Re: [IC] VE.A
« Reply #684 on: Thu, 21 April 2016, 09:19:20 »
I wonder if we can request direct shipment from korea instead of korea > USA > Asia ?
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #685 on: Thu, 21 April 2016, 09:27:38 »
To avoid direct shipping (individual) work/risk is one of many reasons that we are working with Massdrop.
Sorry my friend.
Offline sitch
Re: [IC] VE.A
« Reply #686 on: Thu, 21 April 2016, 09:29:49 »
Sorry my friend.
Thank you sir for prompt reply! cant wait for it to drop :)
Offline Hexterdude
  • I have a problem when it come to artisans
Re: [IC] VE.A
« Reply #687 on: Thu, 21 April 2016, 09:30:22 »
now that you're working with massdrop will there be an option to buy it assembled?
Offline zefyr
  • Oddforge
Re: [IC] VE.A
« Reply #688 on: Thu, 21 April 2016, 09:34:18 »
No assembly option at this moment.
But essential ICs will be pre-soldered (SMT).
So all you have to do is soldering switches :)
(Plus in-switch LEDs if you want it)
Offline harlw
Re: [IC] VE.A
« Reply #689 on: Thu, 21 April 2016, 10:24:17 »
*PEES PANTS VERY LOUDLY*
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline redbanshee
  • actually Dade Murphy
Re: [IC] VE.A
« Reply #690 on: Thu, 21 April 2016, 10:24:28 »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline lootbag
Re: [IC] VE.A
« Reply #691 on: Thu, 21 April 2016, 10:39:09 »
Sorry my friend.
Hopefully, shipping will not cost too much.
I am in Hong Kong and it does not seem very efficient to ship from South Korea > US > and back to Hong Kong...
Offline yuktsi
  • Colour my life with the chaos of trouble
Re: [IC] VE.A
« Reply #692 on: Thu, 21 April 2016, 12:18:59 »
I would love to pickup another VE.A
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline biocalves
Re: [IC] VE.A
« Reply #693 on: Thu, 21 April 2016, 12:29:10 »
My wallet is ready
Offline BlueMoon
Re: [IC] VE.A
« Reply #694 on: Thu, 21 April 2016, 12:55:32 »
Very excited about this news! Can you give an estimate of what the price and estimated shipping time will be once it's launched on MassDrop? Definitely going to be in on this GB :)
Offline Niomosy
Re: [IC] VE.A
« Reply #695 on: Thu, 21 April 2016, 13:24:17 »
Price was listed in the first post.  $400-450 was the estimate.
Offline Data
Re: [IC] VE.A
« Reply #696 on: Thu, 21 April 2016, 14:58:36 »
Awesome.
Offline Butter
Re: [IC] VE.A
« Reply #697 on: Thu, 21 April 2016, 16:02:10 »
May is turning out to be really expensive :)
Offline Niomosy
Re: [IC] VE.A
« Reply #698 on: Thu, 21 April 2016, 19:10:00 »
Massdrop is generally a good choice.  I weep for the extra taxes on it but it makes sense from a distribution standpoint for you.
Offline tuco
Re: [IC] VE.A
« Reply #699 on: Thu, 21 April 2016, 20:00:47 »
Can't wait!
