Author Topic: Teensy Mount  (Read 9178 times)
Offline merlin64
    • MechMerlin
Teensy Mount
« on: Tue, 02 February 2016, 21:49:41 »
Just wanted to share a find to everyone who has struggled with mounting their teensy
http://www.thingiverse.com/thing:167491
Looks like all you have to do is 3d print it. LOL.
Offline Dernubenfrieken
Re: Teensy Mount
« Reply #1 on: Wed, 03 February 2016, 06:11:31 »
Group buy?  :p
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #2 on: Wed, 03 February 2016, 07:15:35 »
Actually thinking about it. Haha
Offline FletchINKy
  • Troy Fletcher, Kentucky USA
    • Troy Fletcher Dot Net
Re: Teensy Mount
« Reply #3 on: Wed, 03 February 2016, 09:42:07 »
You can put me down for a few;
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #4 on: Wed, 03 February 2016, 10:23:17 »
I'll buy one for myself first and test fit and everything, then I'll do an IC as per GH regulations. Stay tuned =)
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
Re: Teensy Mount
« Reply #5 on: Wed, 03 February 2016, 10:27:58 »
wonder if i can machine that out on my CNC. great idea so kudos to the creator!
Projects
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #6 on: Wed, 03 February 2016, 10:29:57 »
Yah so I'm looking up places for cheap 3d printing and it asks me if the STL file is in mm or inches, how do I tell?
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #7 on: Wed, 03 February 2016, 10:33:38 »
i know ponoko.com does printing and laser cutting. ive used them before. they do pretty good stuff and cost isn't ridiculous usually.
as for the STL i'm not sure how to tell off hand. i use Fusion 360 and it defaults to metric but as long as its accurate it shouldnt matter i wouldn't think. i'll try to give it a once over tonight when i get home and see if i can be of any help. i'm also going to try and machine one out of acrylic ;)
Projects
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #8 on: Wed, 03 February 2016, 10:40:16 »
Alright thank you very much. I'm looking everywhere and the cost doesn't seem too bad. Few bucks at most. However locally (WA state), I'm finding places that are much more expensive.
I'd love to get an IC/GB started but have to get all the info/source/pricing correct first =). Thanks Dernubenfrieken for the inspiration haha.
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #9 on: Wed, 03 February 2016, 10:44:50 »
I might add that the unit I linked is for a Teensy 3.0, which is 2.0 mm longer than a Teensy 2.0, which from the looks of it, would make the usb port flush.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #10 on: Wed, 03 February 2016, 10:46:44 »
i'll let you know how mine comes out if i can get one machined tonight. i have some .25 acrylic lying around that needs a use.
if it comes out ok i'll send you one for the cost of shipping.
i'll probably do my own design tho so there is no infringement on the original design. depends on my needs. I have a project i'm working on that needs a teensy 2.0++ mount but it needs to be face down to be able to access the reset button without removing the back plate. PM me i'll keep you posted (as not to hijack the thread anymore)
Projects
Offline Rhedone
Re: Teensy Mount
« Reply #11 on: Wed, 03 February 2016, 10:54:32 »
If the group buy has a European shipping option count me in
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
Re: Teensy Mount
« Reply #12 on: Wed, 03 February 2016, 11:03:14 »
I could 3d print a bunch of these no problem for people that are interested. My prints aren't show quality but if you're hiding it, it shouldn't be an issue.
I built in something similar to a custom board that I'm working on where the teensy 2 is just held in place by tabs and it works just fine.
You can kinda see it in this pic:
If you have the need for custom mounting points that is also something I could handle.
    IBM Model M            Fjell 002           Klippe            KC60           Planck
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
Re: Teensy Mount
« Reply #13 on: Wed, 03 February 2016, 11:08:36 »
Oh and most things on thingiverse are in metric/mm.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #14 on: Wed, 03 February 2016, 11:15:23 »
Very nice Sir!
Projects
Re: Teensy Mount
« Reply #15 on: Wed, 03 February 2016, 12:30:32 »
My solution is to instead use a regular IC socket, but instead of using pins on the teensy that go into the socket, solder the sockets' pins in the Teensy's holes and insert the wires into the socket's slots.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #16 on: Wed, 03 February 2016, 16:45:06 »
I made a thing!
Flush or not friction mount
Projects
Re: Teensy Mount
« Reply #17 on: Wed, 03 February 2016, 16:49:52 »
I made a thing!
I like this a lot. Nice job. Simple is always great :)
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #18 on: Wed, 03 February 2016, 16:52:50 »
I made a thing!
Thanks. Now I have to make a teensy ++ version for my 108. But if anyone is interested in one PM me.
Projects
Offline whiskytango
  • Don't touch the trim
Re: Teensy Mount
« Reply #19 on: Wed, 03 February 2016, 16:59:10 »
In case you're looking for options, this is a thing also. Figure the thread is old enough that people may not know about it:
Teensy breakout board Rev. A
https://geekhack.org/index.php?topic=45587.msg955666#msg955666
and Rev. B:
https://geekhack.org/index.php?topic=45587.msg1233204#msg1233204
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #20 on: Wed, 03 February 2016, 17:01:55 »
and Rev. B:
Nice
Projects
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #21 on: Wed, 03 February 2016, 18:34:37 »
Oh nice did you check to see if it still fits if we solder from the bottom
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #22 on: Wed, 03 February 2016, 18:46:15 »
What do you mean?
Projects
Offline merlin64
    • MechMerlin
Re: Teensy Mount
« Reply #23 on: Wed, 03 February 2016, 18:48:08 »
Once you solder in wires and you apply solder on the bottom, does it still fit in there
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #24 on: Wed, 03 February 2016, 18:51:06 »
It should. I may make another one with the pocket a little deeper.
Projects
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #25 on: Wed, 03 February 2016, 21:00:04 »
Better?
Projects
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #26 on: Wed, 03 February 2016, 23:02:53 »
Projects
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
Re: Teensy Mount
« Reply #27 on: Thu, 04 February 2016, 13:42:16 »
Dig it. Those came out pretty awesome.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #28 on: Thu, 04 February 2016, 13:45:33 »
Thanks JB
had to tweak it alittle to give it a more snug fit but other than that it came out real nice. hopefully i'll machine out a finished version tonight if i get time. house full of sick kids and family.
also of note the teensy 2.0 prototypes have been given away. but if anyone wants the "B stock loose fit" 2.0++ that is in the pictures pay me shipping or something. i like shipping acrylic in small flat rate boxes as acrylic tends to break pretty damn easy in the mail.
Projects
Offline MrRooks
  • Always be knolling
Re: Teensy Mount
« Reply #29 on: Fri, 05 February 2016, 10:01:42 »
How to you keep the teensy in this version? The one Merlin64 linked is appears to have angled sides to prevent the teensy from popping out.
Re: Teensy Mount
« Reply #30 on: Fri, 05 February 2016, 10:03:02 »
It's such a cutie!
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #31 on: Fri, 05 February 2016, 10:04:02 »
friction. the sides touch the edge of the PCB
Projects
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #32 on: Fri, 05 February 2016, 10:04:27 »
Projects
Offline MrRooks
Re: Teensy Mount
« Reply #33 on: Fri, 05 February 2016, 10:10:42 »
I'd be afraid of that coming loose over time.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #34 on: Fri, 05 February 2016, 10:11:51 »
hot glue?  ;D
Projects
Offline jbondeson
Re: Teensy Mount
« Reply #35 on: Fri, 05 February 2016, 10:22:01 »
Looks good. If you wanted to you could use a woodruff keyset cutter to get the slide-in nature of the original.
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #36 on: Fri, 05 February 2016, 10:22:55 »
sweet. thanks for the link!
Projects
Offline xondat
  • i'm not a star
Re: Teensy Mount
« Reply #37 on: Fri, 05 February 2016, 12:27:17 »
Saw this on slack but it looks good!
Offline mrbishop
  • Evil Genius
Re: Teensy Mount
« Reply #38 on: Fri, 05 February 2016, 12:28:01 »
Thanks xondat
Projects
