Author Topic: Digil0g case screws help  (Read 6518 times)
Offline bocahgundul
  • a seal
« on: Fri, 05 February 2016, 09:18:30 »
Can anybody help me with digilog screws? I could'nt find it anywhere I do manage to find 4 of them but the bottom part just doesn't want to be screwed
Can someone help me? like in this videos :
Offline bocahgundul
  • a seal
Re: Digil0g case screws help
« Reply #1 on: Fri, 05 February 2016, 09:25:49 »
anyone? please help me  :'(
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #2 on: Fri, 05 February 2016, 09:41:24 »
It looks like the hole is stripped if the screw is intact. That really isn't good.
Are you sure the screws are the proper ones?
Offline bocahgundul
  • a seal
« Reply #3 on: Fri, 05 February 2016, 09:44:02 »
The screw on the top can be screwed nicely and fit tight but the bottom part just doesn't want to be screwed at all Its not stripped btw I think it just need a longer ones to reach the end can someone with digilog case help me?
    • WTB/WTTF Thread
« Reply #4 on: Fri, 05 February 2016, 09:46:13 »
Are the screws you have on the top the same as the bottom? If they are then they could be stripped because the screws should be the same.
Offline bocahgundul
  • a seal
« Reply #5 on: Fri, 05 February 2016, 09:50:06 »
yep its the same one  :'(
    • WTB/WTTF Thread
« Reply #6 on: Fri, 05 February 2016, 09:51:52 »
I would try to find someone who had or has a Digilog case and ask first about the screws.
If worse comes to worse, email the seller and try to get a refund or see if you can retool the screw holes and then re-anodize the case.
Offline bocahgundul
  • a seal
« Reply #7 on: Fri, 05 February 2016, 09:52:43 »
I check the hole and the bottom are deeper than the top ones
Offline skcheng
    • Tenafly Dentistry
« Reply #8 on: Fri, 05 February 2016, 09:54:48 »
those don't look like the correct screws?
    • WTB/WTTF Thread
« Reply #9 on: Fri, 05 February 2016, 09:55:44 »
skcheng coming in to save the day!
« Reply #10 on: Fri, 05 February 2016, 09:55:49 »
HI SKCHENG. GLAD TO SEE YOU AROUND AGAIN <3
Offline bocahgundul
  • a seal
« Reply #11 on: Fri, 05 February 2016, 09:56:54 »
Can you help me get a correct screws?
Offline bocahgundul
  • a seal
« Reply #12 on: Fri, 05 February 2016, 16:34:41 »
Anyone?
Offline Jokrik
« Reply #13 on: Fri, 05 February 2016, 16:39:40 »
Try to bring it to your local hardware store
pretty sure they've the correct screws for you,
if it fits, at first don't screw it all the way down to see how long you need and you can cut it after to adjust
Offline skcheng
    • Tenafly Dentistry
« Reply #14 on: Fri, 05 February 2016, 16:40:47 »
over the wknd, I'll take mine apart and measure the screws
Offline FrostyToast
  • Litshoard
« Reply #15 on: Fri, 05 February 2016, 16:44:00 »
Try a #5 screw 22mm or 7/8" in length and a 1/4" head.
Epzy asked me once what the measurements for these screws were and that's what I sent him.
He hasn't replied back with an angry PM so there's a chance that those are the correct measurements.
But you should probably wait for skcheng to give you what he finds.
Quote from: elton5354
Offline bocahgundul
  • a seal
« Reply #16 on: Fri, 05 February 2016, 16:58:16 »
Thank you bro I'll wait
Ace hardware doesn't have a screw that fit  :'(
I got the same screw as epzy but the screw is not long enough to reach the other halves I think it needs a longer one
Offline jalaj
« Reply #17 on: Fri, 05 February 2016, 17:11:15 »
IIRC, these are either M2.5 or M3.0 screws
Do not purchase American standard measurements screws.
Offline bocahgundul
  • a seal
« Reply #18 on: Sat, 06 February 2016, 07:16:24 »
Thank you jalaj! I'll purchase this one and test it out  :thumb:
Offline Bucake
« Reply #19 on: Sat, 06 February 2016, 07:25:35 »
goddamn, this man has a digilog case
Offline Jokrik
« Reply #20 on: Sat, 06 February 2016, 07:45:00 »
Not ace hardware, smaller shops
They've more stuff that ace. The shop where usually builders go
Offline bocahgundul
  • a seal
« Reply #21 on: Sat, 06 February 2016, 09:04:22 »
Its no big deal bro you could find 1 too
Might probably sell this one too  :p
Thank you jokrik  :thumb:
I wish that I'm still at home so I could search for screw
Offline skcheng
    • Tenafly Dentistry
« Reply #22 on: Sat, 13 February 2016, 16:50:16 »
Did you find the screws??   If not, next week I'll go buy some at my hardware store and send them to you.    Metric M2.5 or M3.0.   Can't remember which.
Offline bocahgundul
  • a seal
« Reply #23 on: Sun, 14 February 2016, 05:19:21 »
I'm sorry for not replying no I don't get the screw but tomorrow I will go to small hardware store where builder usually goes for screw
Offline Bevo
« Reply #24 on: Sun, 14 February 2016, 05:36:18 »
Lemme know if you decide to sell it bro ;)
Offline bocahgundul
  • a seal
« Reply #25 on: Sun, 14 February 2016, 05:46:01 »
K mate!
Offline Bevo
« Reply #26 on: Sun, 14 February 2016, 05:48:33 »
Offline bocahgundul
  • a seal
« Reply #27 on: Mon, 15 February 2016, 17:21:37 »
My bad everyone  :'(
« Last Edit: Mon, 15 February 2016, 17:48:22 by bocahgundul »
Offline xondat
  • i'm not a star
« Reply #28 on: Mon, 15 February 2016, 17:39:46 »
second day now I'm going to go to the hardware store to get the screw
should start a daily vlog at this point right? that's how the internet works trust me
Offline bocahgundul
  • a seal
« Reply #29 on: Mon, 15 February 2016, 17:48:01 »
i'm sorry I'm gonna remove the post  :'(
Offline xondat
  • i'm not a star
« Reply #30 on: Mon, 15 February 2016, 17:51:25 »
boooooo
why?
Offline bocahgundul
  • a seal
« Reply #31 on: Tue, 16 February 2016, 07:12:42 »
Finnaly got a screw that fits the board now what I need is to lock this thread how can I lock thread?
and really thank you everybody for the help!
Offline joey
« Reply #32 on: Tue, 16 February 2016, 07:13:55 »
No need to lock it, just let it die!
Offline FrostyToast
  • Litshoard
« Reply #33 on: Tue, 16 February 2016, 07:46:19 »
Or tell us what screw you used first.
Offline bocahgundul
  • a seal
« Reply #34 on: Tue, 16 February 2016, 07:52:09 »
oh yeah I don't know what kind of screw that I use I just go to the small builder shops and tell them I need a screw for this thing and voila its done.
