Author Topic: Dunno why, but I kinda like the look of this one...  (Read 2829 times)
Offline FoxWolf1
  • 154
« on: Thu, 11 February 2016, 02:49:43 »
http://www.alibaba.com/product-detail/New-Arrival-Professional-Bamboo-Wood-Mechanical_60281538362.html
Perhaps a wooden mech at a reasonable price at last, if some company decides to pick it up?
Offline Touch_It
Re: Dunno why, but I kinda like the look of this one...
« Reply #1 on: Thu, 11 February 2016, 09:54:14 »
Personally, not my style but I think the case looks pretty awesome.  I think the keycaps would need some changing up.  What would go well with bamboo? :D
Offline KaminKevCrew
« Reply #2 on: Thu, 11 February 2016, 11:23:16 »
bamboo caps? I think Ramage sells some when he makes them!
Offline FoxWolf1
  • 154
« Reply #3 on: Thu, 11 February 2016, 12:15:11 »
I don't really mind the look of the plastic caps, myself...but if you wanted to make it look really fancy, you could put a black lacquer finish on the wood case, swap the red LEDs for white ones, and then use doubleshots of ivory-effect plastic (like they use for piano keys) with transparent legends for the keycaps.
P.S. Based on the description and the glimpses available in the pictures, can anyone ID the switches? The housings look a little unusual to me, but it could just be because they're not easy to see clearly in the pictures.
« Reply #4 on: Thu, 11 February 2016, 21:53:35 »
http://acepads.en.alibaba.com/product/60415253234-801916463/2016_New_Arrival_OEM_Wood_Computer_Gaming_Keyboard_Green.html
similar tkl
also put up a poll on massdrop
https://www.massdrop.com/vote/Bamboo-Wood-Mechanical-Keyboard
It's made with Ace mechanical switch, NOT using membrane with mechanical feeling. The life-span is 100 million times key strokes. All keys are 100% anti-ghosting, no conflict for all keys.
Just an FYI these are $59 with an MOQ of 50 plus freight etc. $80 for a sample.
127923-0
127925-1
127927-2
127929-3
Offline jamster
« Reply #5 on: Fri, 12 February 2016, 03:17:30 »
If you bought one, technically you'd have a grass keyboard.
Offline kokokoy
« Reply #6 on: Fri, 12 February 2016, 03:55:42 »
It's Friday man! Why did you made me think?!  :))
Offline theoriginal123123
« Reply #7 on: Fri, 12 February 2016, 03:56:44 »
Needs more CNC'd wooden keycaps!
Offline FoxWolf1
  • 154
« Reply #8 on: Fri, 12 February 2016, 11:30:46 »
Is...is that a diagram of an optical switch? A hot-swappable optical switch, no less? In a $59 keyboard with backlighting, NKRO, and a cool bamboo case?
Edit: Or maybe Hall effect? The ad for one of their non-wooden keyboards calls their switch a "magnetic switch".
« Last Edit: Fri, 12 February 2016, 15:43:55 by FoxWolf1 »
