Author Topic: I've finally gone over to the dark side  (Read 18533 times)
Re: I've finally gone over to the dark side
« Reply #50 on: Tue, 16 February 2016, 16:14:13 »
Yeah, TKL is perfect for me.. my wife still thinks I'm crazy for getting rid of the ten-key and going TKL
It's a good thing they sell those separately.
Offline jcoffin1981
« Reply #51 on: Tue, 16 February 2016, 20:13:00 »
no regrets going 60 percent.
Offline cmadrid
« Reply #52 on: Wed, 17 February 2016, 15:58:18 »
Yeah, I won't need one for anything, but my wife would want one if she was on a TKL
« Reply #53 on: Sat, 20 February 2016, 23:57:16 »
I'm not getting one, I don't want a 60% size board..
Exactly, why would you need something built for a Doll's House  :)) ?
The smallest you should go is always TKL and nothing less than that.
If your desk is about the size to fit in a doll's house?
I got my HHKB originally to sit in front of my HP MicroServer over in the corner, but ended up liking it so much it is one of my daily drivers now.
Offline jamster
« Reply #54 on: Sun, 21 February 2016, 02:28:28 »
Isn't a HHKB a bit overkill for a machine that seems to be designed to run headless?
« Reply #55 on: Sun, 21 February 2016, 03:13:06 »
Yes, but I do occasionally use the server as is, mainly to change mounts for my external backup drive once a week, and sometimes it's quicker to just use the server than power on one of the workstations.
Offline Polymer
« Reply #56 on: Sun, 21 February 2016, 05:12:36 »
Been thinking about making the switch myself. How does it fare for gaming?
I've consistently heard Topre isn't suited for gaming, but I totally disagree. I play BF4 quite a bit and it's absolutely great for gaming. In fact, I think I prefer it over my Logitech G710+. I use 45g. I just got a 104U in the mail today and I'm pretty sure the variable weighting won't be a problem either.
Uniform will be fine for gaming..I just like the mashability of cherry a bit more when gaming...
Variable sucks though....If you like it for gaming fine..but the light keys are way too light and that just sucks bad...I love variable for typing though...
Offline Bevo
« Reply #57 on: Sun, 21 February 2016, 05:51:06 »
It's always greener on the dark side
Offline 1391406
« Reply #58 on: Sun, 21 February 2016, 08:17:13 »
Like I said in another thread, I consistently heard this before buying a 104U. I fully expected it to suck for gaming, but I was a convert after trying it. Now I prefer it.
Offline Polymer
« Reply #59 on: Sun, 21 February 2016, 08:46:58 »
If they work for you great...I just don't see how anyone using WASD is going to like that (I hate it) or anything using QWER which also feels terrible...When keys are buttons, it isn't the same thing as typing..
The greatness of variable is completely lost on gaming...Same way variable would suck for someone that uses two fingers to type...
Offline 1391406
« Reply #60 on: Sun, 21 February 2016, 10:06:37 »
I respect that you hate variable weighting for games. Personally, after having tried the variable weighted 104U for myself, I've come to the conclusion that the vast majority of criticisms I've read are overblown. For example, I'm not a touch typist and I don't notice the variable weighting when typing, nor when I'm in the middle of a game. Unless I consciously and methodically focus my attention on pressing each individual key, I don't notice the difference in weighting at all. I can tell the difference if I take my time and press, oh say the A and D keys in turn. But I have to consciously and intentionally focus my attention on the differences in order to notice. Otherwise, it's not distracting in real-world typing / gaming situations for me.
The only downside of the variable weighting that I've noticed is that I tend to actuate keys unintentionally when my fingers are resting on the keyboard.
« Last Edit: Sun, 21 February 2016, 13:36:00 by 1391406 »
Offline jamster
« Reply #61 on: Sun, 21 February 2016, 21:25:09 »
That in itself sounds like a pretty major downside! I've only tried 45g Topre, I can't imagine how easy it must be to depress 30g.
Offline 1391406
« Reply #62 on: Sun, 21 February 2016, 23:51:51 »
In all fairness only 4 alphanumerics are 30g, but the overall feel more than makes up for any shortcomings.
Offline jamster
« Reply #63 on: Mon, 22 February 2016, 03:55:18 »
http://i.imgur.com/X6g6Y.jpg
Just checked the key weighting, they go down to 35 rather than 30, but the variable keys fall under WASD. I find the 45g keys almost disturbingly soft already, a variable weighted board would probably drive me nuts :)
Regardless, every time I use my RF I am amazed at how high quality it is compared to other modern boards.
Offline 1391406
« Reply #64 on: Mon, 22 February 2016, 04:20:09 »
Oddly enough, some charts list 30g while others list 35g:
After methodically and carefully taking my time slowly pressing keys, it seems like the weighting is both, 30g and 35g, but the differences disappear and are imperceptible when typing, in my opinion. You really have to pay close attention when pressing a key to even notice. The uninitiated probably wouldn't be able to tell any difference at all, even when paying careful attention. It's a fairly subtle distinction.
Offline cmadrid
« Reply #65 on: Fri, 26 February 2016, 21:05:01 »
I'm liking the all 55g, not sure how I would feel about variable weighting.. I guess I would need to try it out to see
