Author Topic: PBTs for CM Quickfire Rapid?  (Read 5063 times)
Offline Tapdeezy
« on: Fri, 12 February 2016, 10:24:57 »
Hey guys, I'm new to the geekhack community but a definite lurker.  ;D
I recently purchased a CM Quickfire Rapid (TKL) and I'm looking for a set of PBT key caps that will fit the keyboard. I know that the bottom row is a bit unusual and won't work with all sets.
Any recommendations would be greatly appreciated. Thanks in advance!
Offline FLFisherman
  • I'd rather be fishing.
Re: PBTs for CM Quickfire Rapid?
« Reply #1 on: Fri, 12 February 2016, 10:25:47 »
The Quickfire Rapid actually has a standard bottom row. Buy as you like!  :thumb:
Offline Tapdeezy
« Reply #2 on: Fri, 12 February 2016, 12:58:37 »
Haha, that's good to know - thank you!!
Any recommendations on places  to buy high quality, top-printed PBT key caps? Extra points if they carry a Mac OS symbol PBT key cap!  :D
Offline svetlio_vd
« Reply #3 on: Sat, 13 February 2016, 11:47:41 »
The recommendation should depend on the money you are willing to spend. You can buy reasonable keysets if you are not thrilled with designer sets, which are expensive. I am currently very happy with Vortex Thick PBT 104 key set, which I bought recently from ebay - $45 + $13 shipping to EU, and great quality. Installed on a CM Quickfire XT - which is Rapid with 104 keys.
If a had better shipping options to EU, I would look at other options too, you like black, gray, or more colorful options. I would just suggest to look out for thick PBT only (1.5mm thickness).
Offline The Hobbiest
« Reply #4 on: Sat, 13 February 2016, 13:10:10 »
After months of lurking and soaking up knowledge I went with a Ducky dye sub thick pbt set in grey with blue modifiers.  It was $59 shipped for a 104 set.  The legends are sharp and done in nice lettering and the colors are pretty nice as well.  The feel of the caps themselves are great.  I would describe them as a bit grittier than fresh ABS but not grippy or sticky by any means.  I imagine these being on the smoother end of the pbt spectrum when it comes to other pbt caps.
Offline seville57
« Reply #5 on: Sat, 13 February 2016, 14:39:45 »
Where can I buy a 104 keys Ducky PBT Grey/Blue keycaps sets?
My Ducky Shine 2/3/4 and Ducky One RGB YOTG are 109 (ISO/Nordic) and 108 (ANSI) keys k-boards.
My  ISO/Nordic laser engraved is 109 keys set and my blank  ANSI set is 108 keys.
The 109 ISO/Nordic laser engraved Grey/Blue set on my ISO/Nordic Ducky Shine 3.
The 108 ANSI Grey/Blue blank set on my Ducky Shine 4 SCE with Cherry MX Brown/Clears.
The 108 Ducky Cream/Green set.
The 109 Ducky ISO/Nordic Yellow set.
« Last Edit: Sat, 13 February 2016, 15:10:54 by seville57 »
Offline Corsa1r
« Reply #6 on: Sat, 13 February 2016, 14:48:01 »
I, too just recently purchased the Grey/Blue Dye-Sub Ducky PBT set for my TKL (Ganss G.S-87), and they are superb.
I got mine from here:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1321
One thing to note:  They are fairly thick, so if you're using Co-Star stabilizers they may stick on the stabilizer mount. I'm fairly certain QFRs use Cherry now, so you should be solid.
« Last Edit: Sat, 13 February 2016, 14:53:19 by Corsa1r »
Ducky Shine 4 - Mx Blues // Ganss G.S-87 - Mx Browns // Type-S HHKB 45g // FC660M - Mx Reds // FC980M Silent Pink // Aula F75 Ice Veins // Rainy75 MMD Vivians
« Reply #7 on: Sat, 13 February 2016, 17:57:56 »
Tai Hao are relatively cheap, and if you can find a set without the anti-bacterial coating, they are actually quite reasonable.
Or there's something like DSA Granite, if that profile is your cup of tea.
Offline Pinkachu
« Reply #8 on: Wed, 17 February 2016, 20:25:59 »
Are these sculpted or flat? Can't tell from the pic, they look almost flat!
Offline Pinkachu
« Reply #9 on: Wed, 17 February 2016, 20:27:19 »
QFR still use costar wire stabilizers. QFRi might use Cherry, not sure, haven't tried one.
Offline svetlio_vd
« Reply #10 on: Thu, 18 February 2016, 02:12:47 »
The Vortex Thick PBT 104 orange on white set is not completely flat, the keys have a curve - I would describe them as "standard profile" keys.
Offline Lokomotivet
  • (⌐■_■)
« Reply #11 on: Thu, 18 February 2016, 03:36:14 »
QFRi is cherry!
| ISO |
