Author Topic: Question about Pok3r  (Read 1736 times)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« on: Tue, 16 February 2016, 13:16:20 »
I know you can now move FN and PN to any physical key, but can you move PN to be accessible by FN+something (FN+enter maybe)? I think it's very wasteful to have a dedicated key for a feature used pretty rarely.
Offline AwSmCreator
Re: Question about Pok3r
« Reply #1 on: Thu, 18 February 2016, 06:42:06 »
Not that I have found. Seems like you are always gonna have that Pn key. But like you said you can move it almost anywhere that you want.
Offline zslane
« Reply #2 on: Thu, 18 February 2016, 15:42:56 »
Yeah, I put in a feature request some months ago asking that FN and PN be programmable on the alternate layers. For instance, I have my Caps Lock key set to function as FN. I don't need the bottom row FN or PN keys to be FN or PN when in an alternate layer, so they might as well be free to act as something else.
Offline AwSmCreator
« Reply #3 on: Fri, 19 February 2016, 00:50:03 »
Yeah that would be cool if you could just program those as you see fit. I mean if you mess the layer up you can always reset it. I would really like to be able to use the Pn key like the Fn key and set programs to it like the Poker II.
