Author Topic: Cleaning pad-printed buttons?  (Read 2097 times)
Offline ander
  • I type, therefore I am
« on: Tue, 16 February 2016, 21:24:06 »
Hey guys,
I thought this would've been discussed here... Maybe it has and I just couldn't find it.
Is there an accepted way to safely clean pad-printed key buttons? I found a nice Alps board with double-shot standard legends and pad-printed 2nds and 3rds in Japanese and Chinese. It needs cleaning, and I don't want to damage anything. Thanks!
Offline ander
Re: Cleaning pad-printed buttons?
« Reply #1 on: Tue, 16 February 2016, 21:25:27 »
[deleted by poster; not important]
« Last Edit: Wed, 17 February 2016, 01:10:25 by ander »
Offline effectiveduck
« Reply #2 on: Tue, 16 February 2016, 21:39:25 »
I would have thought that warm water and cloth, microfiber would probably be preferred, would be sufficient. But I'm not 100%.
Offline ander
« Reply #3 on: Wed, 17 February 2016, 01:08:19 »
Some kind of soap would be okay, I'm hoping... Dish soap maybe? Has anyone tried that?
BTW, whatever the suggestion, I'll try it on a less-conspicuous one first, and I promise not to sue anyone.
I'm also deleting my irrelevant 2nd post with all the terminology crap... Sorry, I'd had coffee.
« Last Edit: Wed, 17 February 2016, 01:10:01 by ander »
« Reply #4 on: Wed, 17 February 2016, 12:33:16 »
I hear alcohol only sometimes wipes the legends off.  You should try that.
Denture tabs and an ultrasonic cleaner are the two I always recommend.
