Author Topic: Topre switch keyboard owner: Are you satisfied?  (Read 56275 times)
Offline o2dazone
« Reply #50 on: Sun, 06 December 2009, 16:14:56 »
Quote from: GenEric35;139364
if people could add a 20$ option when buying a keyboard, to include a carrying case, this would be perfect for those who do need a carrying case,
for example, I just ordered a white hhkb with no letters, to fit my igloo...
if i drop it in the snow, i might never find it again
I took a hair trimmer kit box and lined it with foam. Does the job, but it's ugly as sin lol
Offline cheater1034
« Reply #51 on: Sun, 06 December 2009, 17:00:25 »
I'm considering buying a happy hacking pro, i'm not 100% if i'll be able to adjust to the layout or not tho :\ (does it have delete/backspace keys?)
Linux Kernel for desktops: http://zen-kernel.org
IRC: irc.rizon.net #zen-sources
ML: http://groups.google.com/group/zen_kernel
Use it! Supported on any distribution, managed through git.
Current Keyboard: Filco FKBN87M/EB (Brown Cherry)
Offline ch_123
« Reply #52 on: Sun, 06 December 2009, 17:04:29 »
No. Users of Happy Hacking keyboards never make mistakes. Ever.
[size=-1](Depending on how you set the keyboard's DIP switches up, the button above Enter is either Delete or Backspace, and holding down Fn will make it do the other one)[/size]
Offline bigpook
« Reply #53 on: Sun, 06 December 2009, 17:12:53 »
Quote from: paranonia;139342
Could you please show me where  to find these scripts?
I'm also a Linux user by using HHKB now, thank you!
A thread of interest can be found here:
http://geekhack.org/showthread.php?t=5906&highlight=emulating+hhkb
Offline bigpook
« Reply #54 on: Sun, 06 December 2009, 19:22:33 »
your nitpicking webwit. using the script is enough to get an idea of what an HHKB will be like.
I would rather run the script and find out that the layout won't work for me before I spend real money on an HHKB.
as for me, the emulation is 'good enough'. you are correct though, it may not suit everyone.
Offline o2dazone
« Reply #55 on: Sun, 06 December 2009, 20:59:20 »
Quote from: cheater1034;139492
It doesn't take that long. It's much easier than switching from mouse to trackball, I'll tell you that. Emulate your Caps Lock <--> Control on a normal keyboard and the rest should come pretty easily.
Offline cheater1034
« Reply #56 on: Sun, 06 December 2009, 21:19:23 »
I'm considering one because they seem to claim that they are good for programming, and I'll be doing a lot of programming in the near and distant future.
Although it is hard for me to drop $250 :O, my other consideration is the filco brown (which is about half of the price), I'm just looking for something comfortable+quiet+not much foce, these blue cherries are nice but have become too loud, something else is up with them too, maybe it's the tacile bump that I'm not very fond of - i read that the topre's have a consistent motion through them which I would probably like. I have a somewhat bad wrist and the counter hand is also not in top shape (I broke my left wrist twice and had surgery, and have broken my right hand as well) - my left is a bit weaker than my right one still :\
compact size is good for me too, because I'd be travelling with it a bit probably using it on the laptop.
I can't believe I'm shopping for keyboards again :( (since using a few mechanical I can't go back)
Offline toffz
« Reply #57 on: Mon, 07 December 2009, 03:40:50 »
Decided that if I can manage to sell my Das, that will justify the Realforce purchase. And what do know! After a couple of days I had posted 'Das on sale' on a finnish computer forum, someone decided to make the switch :)
So to the webstore to order myself a christmas present :)
Unicomp Customizer 105
Topre Realforce 105
IBM Model M 1391411 (\'91)
Offline ch_123
« Reply #58 on: Mon, 07 December 2009, 04:01:20 »
Are you ordering the Finnish layout Realforce?
Offline toffz
« Reply #59 on: Mon, 07 December 2009, 04:51:31 »
Quote from: ch_123;139673
Yep.
Topre Realforce 105
Offline _js_
« Reply #60 on: Tue, 08 December 2009, 11:14:46 »
FWIW, I bought a Realforce 103U with Topre keyswitches, and it has become my favorite keyboard, edging out my Model M and AEKII.  And as soon as the 87U (or equivalent) becomes available in white at elitekeyboards, I'll be buying that model as well.  Thought about the HHKB, but for my uses the layout is far from ideal so I've refrained from picking one up.  Thought about hard.  Really hard.  But in the end, I knew it wouldn't work out for my uses.
HHKB Pro 2, AEK II
Offline rdjack21
« Reply #61 on: Tue, 08 December 2009, 11:47:37 »
Yea I've been really surprised that Elitekeyboards has not carried the white 87U. I believe someone here got one from them though but it is still not shown on the site.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline ch_123
« Reply #62 on: Tue, 08 December 2009, 11:47:52 »
As far as I know, Brian can get you a white one if you ask.
Offline didjamatic
« Reply #63 on: Tue, 08 December 2009, 11:51:40 »
I want a white 87u.  What does Brian charge for them?
Offline ch_123
« Reply #64 on: Tue, 08 December 2009, 12:04:19 »
Quote from: didjamatic;140143
Same as regular ones as far as I know.
Offline itlnstln
« Reply #65 on: Tue, 08 December 2009, 12:05:40 »
Quote from: ch_123;140147
I think the only stipulation is that you have to wait until he places another order and gets that shipment in.
Offline toffz
« Reply #66 on: Tue, 08 December 2009, 12:08:34 »
Thanks! Sure thing, no one had anything negative to say about the switches, except the price of the keyboards. Will be getting the RF tomorrow or on Thursday :)
Topre Realforce 105
Offline didjamatic
« Reply #67 on: Tue, 08 December 2009, 14:27:22 »
I want one too.
Offline _js_
« Reply #68 on: Wed, 09 December 2009, 15:26:21 »
Quote from: ch_123;140140
Not true, sadly.  I asked if he could and he said no.  I asked if he could if I paid extra, and he said unless I was willing to buy 50-100 boards, I'd have to wait until about Feb of 2010.
HHKB Pro 2, AEK II
Offline didjamatic
« Reply #69 on: Wed, 09 December 2009, 15:52:00 »
Yes and that is really lame.  What kind of supplier (Realforce/Topre) refuses to include a color variation on an order.  They should easily be able to include 10 White boards and 90 Black on a purchase.  I would buy a white 87u from overseas but the markup is ridiculous for all of them I've found so far.  Combined with shipping makes it unreasonable.
I'm not blaming Elite for this issue, it's a supplier problem.  I'm sure Elite would be happy to sell me two white 87u boards. :)
I guess there's always the option of getting a black 87u and then a white set of Topre caps from KBC if you want the tuxedo look.
Offline HungryPillow
« Reply #70 on: Wed, 09 December 2009, 20:02:41 »
A white 87U with black alphabet key caps sounds pretty delicious right about now... :)
Realforce 87U | Realforce 104U | Filco Majestouch MX Blues | Corsair K70 RGB MX Browns | Ducky Shine 4 MX Clears / Browns | WhiteFox Aria MX Browns
Offline GenEric35
« Reply #71 on: Wed, 09 December 2009, 20:34:00 »
is the sound of the 87u and 103 key different? When I listen to recordings the 103 always has a lower tone, and aside from the width, are both board the exact same construction?
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline ocdonkb
« Reply #72 on: Wed, 09 December 2009, 20:39:56 »
I've watched a lot of youtube Topre vids, they mostly sound the same to me. I don't own one of these, but the more I watch/listen, the more I want!
here's a few:
Realforce 103
http://www.youtube.com/watch?v=9vcCFWf5fZk
Realforce 87
http://www.youtube.com/watch?v=dNmKQh3YWpo&feature=related
| Filco Brown 87 key | Realforce 87U | Unicomp Spacesaver | IBM Model M | Cherry ML4100 | Dell AT101W | Focus 2001 |
Offline GenEric35
« Reply #73 on: Wed, 09 December 2009, 21:01:51 »
they do sound very similar, they should, could someone that has both shed some light on this?
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline didjamatic
« Reply #74 on: Wed, 09 December 2009, 22:55:56 »
Quote from: HungryPillow;140775
That's funny, I've been picturing a black one with white keys.  Get a white 87u and maybe we can work something out.
The audio on those clips is very close to the real thing, but it depends on how hard you bottom out on each key.  The more you bottom out, the more you'll hear and feel that "thumping" sound, the less you bottom out, the less you'll hear the thump sound.  No matter how you type on this board, it's clean, tight, smooth and thocky.
I have the 103u (white) and 87u (black)... Hopefully I will be able to find 2 WHITE 87u's + numpads and I will be a happy camper at work and at home.
« Reply #75 on: Thu, 10 December 2009, 03:02:04 »
Why don't you just swap the keys on the 103U and the 87U? Will they fit? I've only got a black 87U at the moment but wouldn't mind a white one to play around with...
Offline toffz
« Reply #76 on: Thu, 10 December 2009, 03:28:14 »
Got my RF 105 yesterday! Coding with a big smile :biggrin:
Topre Realforce 105
Offline xyzzy
« Reply #77 on: Thu, 10 December 2009, 04:17:19 »
Nice, congrats! Post some photos when you have a chance :)
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline rdjack21
« Reply #78 on: Thu, 10 December 2009, 11:45:49 »
Quote from: toffz;140823
Congratulations! Yes they are great boards to type on. Now you get to enjoy the
Good feeling of oneness with cup rubber
Keyboards
Black Alps: ABS M1
Offline toffz
« Reply #79 on: Thu, 10 December 2009, 14:27:43 »
I certainly am enjoying typing with the RF, but what do you guys mean with 'good feeling of oneness with the cup rubber'?
Topre Realforce 105
Offline itlnstln
« Reply #80 on: Thu, 10 December 2009, 14:28:34 »
Quote from: toffz;140996
Check out the writing on the box.
Offline didjamatic
« Reply #81 on: Thu, 10 December 2009, 14:28:58 »
It's printed on the Realforce box.
« Last Edit: Thu, 10 December 2009, 14:33:39 by didjamatic »
Offline bigpook
« Reply #82 on: Thu, 10 December 2009, 14:37:53 »
I had a HHKB and strangely the 'good feeling of oneness with the cup rubber' is rather accurate.
I miss my feeling of oneness....sigh.
Offline ch_123
« Reply #83 on: Thu, 10 December 2009, 15:11:04 »
What happened to it?
Offline bigpook
« Reply #84 on: Thu, 10 December 2009, 16:37:39 »
In a moment of stupidity, I sold it.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #85 on: Thu, 10 December 2009, 17:42:26 »
I loved the Mr. Bill show. Don't put him or his dog near a Model M though...or that'll be the end of them!
Offline bigpook
« Reply #86 on: Thu, 10 December 2009, 17:44:59 »
While the thought has crossed my mind, I would most likely get another HHKB ( white with lettering this time) versus the realforce. I don't think I would like the different weighted keys. And the layout of the HHKB is a plus.
is it xmas yet?
Offline bigpook
« Reply #87 on: Thu, 10 December 2009, 17:58:38 »
ripster, you are my enabler : )
Offline maxlugar
« Reply #88 on: Thu, 10 December 2009, 18:07:53 »
Quote from: bigpook;141078
Satan is also an enabler
Emperor of the IBM 84-key AT Model F Darkside
Offline bigpook
« Reply #89 on: Thu, 10 December 2009, 18:23:53 »
: ) I need to find a little red devil.
ripster made me do it. honest.
Offline bigpook
« Reply #90 on: Thu, 10 December 2009, 18:24:27 »
Quote from: maxlugar;141087
yeah, but I don't believe in satan, but I do believe in ripster.
  • Live long and prosper
« Reply #91 on: Thu, 10 December 2009, 18:27:44 »
Are you suggesting that Ripster can be comparable to Satan?
tp thread is tp thread
Offline Rajagra
« Reply #92 on: Thu, 10 December 2009, 18:28:43 »
I've never seen them in the same room.
Offline maxlugar
« Reply #93 on: Thu, 10 December 2009, 18:31:24 »
Quote from: bigpook;141098
They will both lead you down the path...to spend more and more and more on keyboards.
BTW, do you believe in webwit?   :)
« Reply #94 on: Thu, 10 December 2009, 19:02:23 »
I believe in Windows. It accomplishes my computing needs very well.
Offline bigpook
« Reply #95 on: Thu, 10 December 2009, 19:03:30 »
Quote from: maxlugar;141104
I will be silent when it comes to webwit. I don't want to incur his wrath.
Offline bigpook
« Reply #96 on: Thu, 10 December 2009, 19:04:39 »
Quote from: microsoft windows;141146
windows is truly evil. far surpassing ripster and even webwit.
Offline maxlugar
« Reply #97 on: Thu, 10 December 2009, 19:11:06 »
Quote from: bigpook;141151
Are you referring to Windows as in the OS or our friend microsoft windows?  :)
Offline ch_123
« Reply #98 on: Thu, 10 December 2009, 19:12:30 »
Both interpretations of that sentence are true.
Offline ch_123
« Reply #99 on: Thu, 10 December 2009, 19:27:43 »
We call them the same thing over here. You can tell how close you are to Dublin based on how fat the pigeons are...
