Author Topic: [ARTISANAL KEYBOARDS BY YOE] Keyboard builds and keycap dyeing services  (Read 7483 times)
Offline Yoe
  • Alps & ISO <3
You've probably seen my handcrafted keyboards before...
https://geekhack.org/index.php?topic=69841
https://geekhack.org/index.php?topic=76738.0
https://www.instagram.com/trasselfrisyr/
Now I want to keep building them even though I don't need more keyboards for my personal use. My solution is to build keyboards for other people :)
Message me for info. Also check out this spreadsheet thing I made for estimates. I keep a waiting list for my consignment builds, and the current waiting time is approximately 6 months.
* y62y63cost.xls (11 kB - downloaded 320 times.)
ATM I've got a bunch of M0116 in stock for donor boards, so US customers are very welcome.
« Last Edit: Wed, 24 February 2016, 07:43:17 by Yoe »
Offline Yoe
  • Alps & ISO <3
Re: [ARTISANAL KEYBOARDS BY YOE] Keyboard builds and keycap dyeing services
« Reply #1 on: Wed, 24 February 2016, 07:40:46 »
Product info and photos
The keyboards are 60% versions of vintage Apple M0116 and M0118 keyboards. They are built on plates either cut from original plates (black) or laser cut from 1mm stainless steel (oscillated steel look), and fitted into hand made wooden frames, usually from oil finished oak. I can make them carefully hand wired or with my own etched PCBs. As controller I use either a Teensy++ 2.0 soldered directly to the PCB or a Teensy 2.0 with wires and header connector to the PCB. USB jack is my own very sturdy mini USB board for both Teensy models, or a modified micro or mini USB adapter fitted into the back for the Teensy 2.0. Keycaps can be dyed in either my preset color ways or custom color ways (limited by available/tested dye colors).
colors
129411-0129413-1129415-2129417-3
129419-4129421-5129423-6129425-7
hand wiring examples
129427-8129429-9129433-10129443-11
pcb
129435-12129437-13129439-14129441-15
frames
129539-16129541-17129543-18129545-19
« Last Edit: Thu, 25 February 2016, 04:46:05 by Yoe »
