Author Topic: Help with stabiliser :(((((  (Read 1825 times)
Offline Numpy
  • The feels man
« on: Thu, 25 February 2016, 02:01:13 »
So I finally finished my keyboard after soldering in 61 LEDs and de-soldering them again...
and now...
one of my stabilisers is being a ***** :/
One side won't go down completely (as you can see here) and I've been wiggling it around for the past 20 minutes trying to fix it.
This keyboard has been an emotional roller coaster and I really want it finished :(
If anyone has any ideas that would be faaaantastic!
Thank you
EDIT: I fixed it. Had to desolder the switch below to get the stabiliser wire in the right place. I have no idea how it came out in the first place.
          I am now a master desolderer of LEDs and switches. All I have to do now is put it in the case and put the keycaps on. Hopefully nothing will go wrong there. :/
« Last Edit: Thu, 25 February 2016, 02:38:43 by Numpy »
Custom 60%: Cherry MX blues with 62g gold springs and PBT Black on Black dyesub keycaps.
Other Keyboards: Deck Hassium Pro (MX Browns), the underated Leopold FC660M (MX Browns)
Re: Help with stabiliser :(((((
« Reply #1 on: Thu, 25 February 2016, 02:39:39 »
Looks like the wire isn't in the slider correctly so you'll need to take the stab out and reassemble that side, hopefully the plate lets you do that without desoldering :)
Offline Numpy
  • The feels man
« Reply #2 on: Thu, 25 February 2016, 04:12:40 »
Yeah, had to desolder the switch below.
Thank so much for giving me an excuse for something to type to by the way ;)
This keyboard feels so goooooooood!
