Author Topic: 1800 layout Cherry WoB Doubleshot Keycaps $130  (Read 4773 times)
Offline fatb0y
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: 1800 layout Cherry WoB Doubleshot Keycaps $130
« Reply #1 on: Fri, 26 February 2016, 01:53:23 »
Nice find. :thumb:
|||My other keyboards :
x
« Reply #2 on: Fri, 26 February 2016, 06:55:45 »
That price seems awful high to me.
 Weren't there going for about half this much not that long ago?
Offline jerue
  • (Whenever that happens :P)
« Reply #3 on: Fri, 26 February 2016, 07:07:08 »
This should be much cheaper.
Will 7000 caps work on regular boards?
Honestly the only 1800 boards worth remotely this are the g80's w/good beige doubleshots.
Edit: this board's code indicates doubleshot caps as well (probably pad printed windows keys) and is $20: http://www.ebay.com/itm/CHERRY-MY7000-G81-7000HPUS-2-Keyboard-w-Credit-Card-Reader-8-Pin-/161980356974
« Last Edit: Fri, 26 February 2016, 07:10:15 by jerue »
« Reply #4 on: Fri, 26 February 2016, 07:09:06 »
This one has the same caps and is significantly cheaper: http://www.ebay.com/itm/CHERRY-MY7000-G81-7000HPUS-2-Keyboard-w-Credit-Card-Reader-8-Pin-/161980356974
Yup, that's where I got my WoB caps from. The mod row will be messed up but there's been countless GMK buys and vendors with a kit that will let you complete the set. For $130, I could get 3 sets of 7000 caps which are the same Cherry Doubleshot caps and buy a GMK ANSI mods. And maybe have some leftover cash.
Edit: I didn't click on the OP LOL. That's hilarious that the same G81-7XXX boards have drastically different prices. And yes, G81-XXXX keyboards with MY switches have the same MX mount as G80-XXXX boards so you can use the caps on your MX switches.
« Last Edit: Fri, 26 February 2016, 07:10:49 by CPTBadAss »
Offline alienman82
« Reply #5 on: Fri, 26 February 2016, 13:53:19 »
removed.
« Last Edit: Thu, 01 March 2018, 16:01:34 by alienman82 »
Offline jacobolus
« Reply #6 on: Mon, 29 February 2016, 16:06:20 »
$118 + shipping? Holy crap. There were a bunch of similar boards with WoB doubleshots and MX switches for like $20 two years ago.
