Author Topic: R.I.P. Cruzer Micro 2.0 GB  (Read 5994 times)
Offline 1839cc
« on: Sat, 05 December 2009, 22:15:11 »
My flash drive became corrupted and unusable a couple of months ago and tonight I confirmed it is non-recoverable.
Now I have to get another one. >:(
i have seen unix admins with john deere trucker hats, and even seen a man in a nascar shirt correct a passerby's klingon.
Offline cheater1034
« Reply #1 on: Sat, 05 December 2009, 22:38:10 »
They aren't too expensive, I bought an 8gb one not too long ago for pretty cheap, like $10
I love it, just make sure to get rid of that junk u3 firmware thing ;)
Linux Kernel for desktops: http://zen-kernel.org
IRC: irc.rizon.net #zen-sources
ML: http://groups.google.com/group/zen_kernel
Use it! Supported on any distribution, managed through git.
Current Keyboard: Filco FKBN87M/EB (Brown Cherry)
Offline PRISONER 24601
« Reply #2 on: Sun, 06 December 2009, 15:17:51 »
You don't hear about Cruzer micros failing often.
I have a 256mb stick from around 2003.. still works like a charm after going through the washing machine about a dozen times.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline ch_123
« Reply #3 on: Sun, 06 December 2009, 15:19:16 »
Get a Corsair... I had one for 3.5 years and the connector snapped off it. I sent it off to Corsair and they sent me out a new one for free (I had a 2GB one, but they didnt make that size any more, so they gave me a 8GB one)
Offline zwmalone
« Reply #4 on: Sun, 06 December 2009, 15:24:24 »
I've got 2 4GB flash drives... a PNY and a Cruzer...  The PNY drive seems to be much more solidly built than the cruzer, and costed about $3 less to boot.
Can't get enough of them ALPS
Offline 1839cc
« Reply #5 on: Sun, 06 December 2009, 15:40:15 »
I liked the retractable connector. I would lose the little caps that come with other ones.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Sun, 06 December 2009, 18:15:39 »
Been using a Cruzer Contour 8 gig for a while, now replaced by a 16 gigger (I tend to lug around my collection of service docs, almost 6 gigs alone, and then some other stuff). The only computer where I can use it at full speed (only USB 1.1 here) seems to have flaky ports, but other than that they've been working fine. Yeah, a 16 gigger on USB 1.1. Fortunately I never need to move a lot of data at a time.
Offline ironcoder
« Reply #7 on: Wed, 09 December 2009, 12:21:44 »
Depends on which cruzers you have I have a bunch and the old ones were brick ****houses while the new ones don't seem nearly as well built but I haven't had one go bad on me yet. Bummer. But prices are coming down alot and capacity is going up. Maybe send it back and see if Sandisk will replace it.
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #8 on: Wed, 09 December 2009, 13:13:21 »
Quote from: PRISONER 24601;139479
That happened to my 256mb flash drive too! All that happened was the cover broke so it now looks like a little PCB. Don't think that thing's going through airplane security...
  • Live long and prosper
« Reply #9 on: Wed, 09 December 2009, 13:33:00 »
I don't think they would let you through airport security...
Anyways, I have an 8g Cruzer Micro, and it works like a charm once you remove the extra software.
tp thread is tp thread
« Reply #10 on: Sat, 12 December 2009, 08:44:19 »
That's OK with me. I've never gone on an airplane and have no plans to.
Offline ricercar
  • mostly abides
« Reply #11 on: Sat, 12 December 2009, 10:15:01 »
Quote from: microsoft windows;141682
Luddite? :pound:
Offline iMav
  • geekhack creator/founder
« Reply #12 on: Sat, 12 December 2009, 11:02:49 »
I've got a few 32GB ones that are MicroCenter-branded (no clue who actually makes them).  Pretty inexpensive considering the storage capacity.
Offline skriefal
« Reply #13 on: Sat, 12 December 2009, 11:31:47 »
I can't stand the flash drives with retractable USB connectors.  They always seem to want to retract into the drive whenever I attempt to plug the drive into a USB port.  I then need to try to hold a small lever or similar in place while simultaneously plugging the drive into the USB port.  Ugh.
