Author Topic: [GB]LZ Alps pcb + plate and LZ-FE diffuser(Shipping)  (Read 104453 times)
Online henz
  • What?
« on: Mon, 29 February 2016, 02:50:22 »
We(Me and Bocahgundul) have spoken to Life Zone and Leeku and figured out a way to offer an alps solution for all Alu LZ TKL keyboards(with and exception of LZ-R).
We will offer a plate + PCB(a kit) you will be able to add in RGB leds and a acrylic diffuser.
For those who are not familiar with the Life Zones work, you can check out his many keyboards at :
 http://lzlife.tistory.com/
We need to achieve a MOQ of 18 pcbs+plates to get this to happen, so shout out to all your friends which has a LZ TKL board! We will not sell any diffusers or leds unless we hit MOQ of the plates and pcbs.
Order placed, 6 weeks approximately until the order fullfilment(Mid june)
Payment status 12/12
Offerings:
___________________________________________________________________________
PCB + Plate
The PCB is made by Leeku and is called L3 ALPhaS.
The pcb is programmed with JigOn firmware, can be found here: http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=2702787
here are some shots from kbdlab with the pcb sitting in a orion v2:
http://kbdlab.co.kr/index.php?document_srl=2381083&mid=board_Lsno50
The plate is made by lifezone, you will be able to choose one between 3 different layouts:
  • AEK II. Someone has to correct us if we are wrong but aek houses four 1.5, two 1,25 mods and a 6.5u spacebar. Only compatible with a LZ keyboards without winkey blockers
  • Dell at101 and SGI type plate, Standard WKL(ansi 84 key) layout originating from dell at101 and SGI keyboards.This is compatible with all LZ keyboards.
  • Dell at101W, this is a standard ANSI 87 key layout we all know from a standard tkl(filco, cmstorm quickfire, ducky etc) Only compatible with a LZ keyboards without winkey blockers.
80$ (43+37) Right now we only offer a pcb with a plate. So no plate or pcb only orders.
We are glad to introduce PCB only orders at 43$
the pcbs are of the same dimension as a a87, and should fit in most korean custom cases.
RGB Leds
Enough leds to fit a pcb 6$
Acryllic Diffuser (3mm thick) 7$ LZ-FE ONLY
You will also be able to use this if you have a MX pcb with some kind of side leds, like a Nerd or tx87 etc. Again ths only fits LZ-FE.
This diffuser has been prototyped by yuktsi. And reworked by LZ
image stolen from the “post your Korean keyboard” thread,thanks for the potato yuktsi!
Drawing by LZ:
Shipping
Shipping will be done from Life Zone himself, if your country does not fit into any of these groups Please send us a pm and we will try get a more accurate quote for you ,also if you plan to buy more than one kit. Please pm us. As this is pricing for 1 kit(plus leds and diffuser)
Shipping to Asia: 21$
Shipping to Europe 31,5$
Shipping to America 42$
All orders will be billed a gb handling fee of 2$
If you have any questions, feel free to ask them here in the thread. Q&A will be created along the way.
Submit your order here https://docs.google.com/forms/d/16oSZ63JR4ADgeOWZZTt15-goBVavyF5iX9ZrCS942Pw/viewform
We want to thank LZ, Leeku and yuktsi which made this possible.
Online henz
  • What?
Re: [GB]LZ Alps pcb + plate and LZ-FE diffuser
« Reply #1 on: Mon, 29 February 2016, 02:50:36 »
Q&A:
Current MOQ status?
18/10 Plates
18/18 Pcbs
Does at101 and at101W have stepped caps lock?
Yes
Are controller parts soldered on?
All controller parts are pre soldered, diodes and resistors are not(for switches).
Is the AEKII plate fully compatible with and aek keycaps(ie is the function row switches rotated)?
Yes
Lz tkl models:
LZ FE
LZ RE
LZ SE
LZ GH
LZ S
LZ F
Online henz
  • What?
« Reply #2 on: Tue, 01 March 2016, 14:00:18 »
Sweet, approved. Lets get this thing rolling. Feel free to ask any questions you might have.
Offline jbondeson
« Reply #3 on: Tue, 01 March 2016, 14:13:44 »
You'll want to call out whether the Caps Lock is stepped or not for the AT101/AT101W plates. If they are stepped then vintage caps will fit, however the Alpine Winter and any future SP caps will not.
I personally don't own an LZ board, but it's great to see more Alps custom love!  :thumb:
Edit:
Also AEK function rows are rotated, so you have the same dilemma there with vintage v. new caps.
« Last Edit: Tue, 01 March 2016, 14:26:51 by jbondeson »
Online henz
  • What?
« Reply #4 on: Tue, 01 March 2016, 15:06:01 »
They are the same  :thumb:
I guess i was unclear, both layouts have stepped caps lock. Added to the Q&A. You can see it on the pictures as well. caps and tab are located on the same horizontal coordinate
Offline bocahgundul
  • a seal
« Reply #5 on: Tue, 01 March 2016, 16:51:55 »
Sweet that this got approved  :thumb:
Let's spread the love
Offline WNovizar
« Reply #6 on: Tue, 01 March 2016, 16:59:26 »
If this GB only came with PCB and Plate only, then where can I get the case compatible with this PCB?
I like mechanical keyboards
Offline bocahgundul
  • a seal
« Reply #7 on: Tue, 01 March 2016, 17:02:06 »
You could search for LZ tkl board
I don't know where can you find 1 tho
but yeah a fellow Indonesian  :thumb:
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #8 on: Tue, 01 March 2016, 17:37:23 »
Does this support the LZ-SE 84?
Mmm... machined aluminum
Offline WNovizar
« Reply #9 on: Tue, 01 March 2016, 18:15:55 »
I don't think that's the problem. I just want to be clear about case compatibility, since OP mentioned that this PCB (and Plate) is compatible with all TKL cases, including Varmilo TKL Aluminium cases, TEX/Filco ONI TKL cases?
Offline Steezus
  • Keeper of Facts
« Reply #10 on: Tue, 01 March 2016, 18:27:15 »
It's compatible for LZ specific TKL boards, not just any TKL.
Offline Perish
    • Killscreen
« Reply #12 on: Tue, 01 March 2016, 23:48:42 »
For clarity, no LZ case is a part of the buy? That would need to be sourced separately by the buyer correct?
Offline bocahgundul
  • a seal
« Reply #13 on: Wed, 02 March 2016, 00:43:42 »
Yes, no case are being offered in this GB  :thumb:
It just fit LZ made keyboard in TKL design
Do you even read the post thoroughly bro?
« Last Edit: Wed, 02 March 2016, 00:58:44 by bocahgundul »
Offline Steezus
  • Keeper of Facts
« Reply #14 on: Wed, 02 March 2016, 01:14:23 »
Chill bocah, he's new and it doesn't say anywhere in the OP that a case is not included.
« Last Edit: Wed, 02 March 2016, 01:30:01 by Steezus »
Offline WinterIsle
« Reply #15 on: Wed, 02 March 2016, 02:16:02 »
One question: Are the controller parts came pre-soldered? Thanks.
Online henz
  • What?
« Reply #16 on: Wed, 02 March 2016, 02:17:50 »
Let me check, but im 90% sure controller parts come presoldered.
Offline WinterIsle
« Reply #17 on: Wed, 02 March 2016, 03:36:15 »
Nice  :thumb:
Online henz
  • What?
« Reply #18 on: Wed, 02 March 2016, 05:01:56 »
I also added a field and change one in the form. Guys who already submitted an entry please fill in the new field and changed on.
What i added is a forum name field, so i can contact you if there are some issues.
I also change the plate+pcb section so you can speficy which plate layout you want.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #19 on: Wed, 02 March 2016, 06:02:35 »
So I'm interested if I can get a case... Where does one source a case? Do you have to buy a used one from someone who already has one or will LZ make a new batch? If the latter then I'll join. The former and I'm not interested.
Online henz
  • What?
« Reply #20 on: Wed, 02 March 2016, 06:13:40 »
unfortuneatley you need a to buy a used one, or wait untill LZ starts making a new one(which i dont think is planned currently)
Online henz
  • What?
« Reply #21 on: Wed, 02 March 2016, 06:14:09 »
Nice  :thumb:
Controller parts are soldered, resistors and diodes are not.
Offline zennasyndroxx
  • It's good to be back!
« Reply #22 on: Wed, 02 March 2016, 06:27:07 »
Nice  :thumb:
buybuybuy
All the best with the GB :)
Online henz
  • What?
« Reply #23 on: Wed, 02 March 2016, 06:37:43 »
Nice  :thumb:
buybuybuy
:thumb:
Also, Everyone who has ordered, please update your response because i had to make a change to the form.
Online henz
  • What?
« Reply #24 on: Thu, 03 March 2016, 06:36:56 »
Lz has created a IC for some kind of ironman board. Looks pretty cool. Have to ask him if it will be compatible.
https://geekhack.org/index.php?topic=80196.0
« Reply #25 on: Thu, 03 March 2016, 11:00:28 »
:eek:  Just saw this buy now.  :eek:
Very intriguing.  :D  I'm certainly not the biggest Alps fan out there, but I've been rather disappointed with the feel of the MX Blues I have in my LZ-GH - having the option to swap out the PCB/plate with a drop-in solution like this is great, and will give me some motivation to try "high-end" Alps switches.  ;)
It looks like the PCB supports 90 degree rotated switches in the F-row to accommodate AEKII keycaps - correct?  If so, I will likely place an order.  :)
Offline alienman82
« Reply #26 on: Thu, 03 March 2016, 11:02:54 »
make sure you get more than one kit.  I had enough brown alps for my Duck Orion V2, but I used blue alps cause Hype.  Was a mistake.  I am now back to square one.  Try those switches if you can first!
« Reply #27 on: Thu, 03 March 2016, 11:07:51 »
I've tried enough switch types to get a good feel for them, thankfully.  I still don't buy all the hype with most of them, but after being relatively underwhelmed with Matias QuietClicks I'm ready to give some of the others a chance in a kustom board and see how that goes.  Just hoping I can find a semi-decent price.  :))
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #28 on: Thu, 03 March 2016, 11:15:33 »
How long will this GB be open for?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Online henz
  • What?
« Reply #29 on: Thu, 03 March 2016, 12:28:45 »
Let me check that.
28 march(this year :))
Offline vivalarevolución
« Reply #30 on: Thu, 03 March 2016, 21:25:38 »
Just saw this.  Might buy.  I'll have to think about it.
Offline alienman82
« Reply #31 on: Thu, 03 March 2016, 21:30:36 »
just do it TM
Offline bocahgundul
  • a seal
« Reply #32 on: Fri, 04 March 2016, 00:46:27 »
I'm gonna check that for you hoff!
28 march but we will let it open for more to meet the moq
Online henz
  • What?
« Reply #33 on: Fri, 04 March 2016, 01:42:00 »
PCB supports it atleast. get back to you on the plate.
Offline bocahgundul
  • a seal
« Reply #34 on: Fri, 04 March 2016, 04:23:26 »
[/quote
Confirmed that its rotated 90 degree
Online henz
  • What?
« Reply #35 on: Fri, 04 March 2016, 04:49:10 »
Im waiting for your order Hoff :D
Offline limitz
« Reply #36 on: Fri, 04 March 2016, 08:47:02 »
Joined, thanks for reminder  :thumb:
« Reply #37 on: Fri, 04 March 2016, 08:53:37 »
I ordered.  :D  I think I butchered the form though.   I put my entire address in the 'address' section, because I didn't see a section for 'city'.  It should be easy to figure out though.  Let me know if you have any questions or want to reprimand me for my stupidity.  :P
Online henz
  • What?
« Reply #38 on: Fri, 04 March 2016, 08:54:29 »
Its rather me who should add a city section. Ill fix
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #39 on: Fri, 04 March 2016, 08:56:22 »
great work
gl guys
Offline bocahgundul
  • a seal
« Reply #40 on: Fri, 04 March 2016, 08:59:45 »
great work
gl guys
Thank you bunny!
OuO hoff joining team alps yo
Yay thank you!
Online henz
  • What?
« Reply #41 on: Fri, 04 March 2016, 09:02:24 »
gais dont forget to add your layouts! otherwise ill have to send a bunch of pms.
« Reply #42 on: Fri, 04 March 2016, 09:17:56 »
I'm in. It's all about the Alps.
« Reply #43 on: Fri, 04 March 2016, 09:19:13 »
Oops.  :-[
Added.  But I also switched from 2 kits to 1 kit.  :(  Sorry, but after some more thought I just can't justify having three PCBs for the same board.  :|
Online henz
  • What?
« Reply #44 on: Fri, 04 March 2016, 09:25:04 »
Sweet!
great work
gl guys
Oops.  :-[
good! we are more than halfway if we are 1 behind at due date, ill hold you accountable! :P
Offline LifeZ
  • LifeZone
« Reply #45 on: Sun, 06 March 2016, 18:15:54 »
Hi all~!
alps plate 3 type for LZ tkl series(without LZ-R)
dell at101 new
dell at101 old
apple ext2
STS 1.2mm plate
LZ Limited
Offline limitz
« Reply #46 on: Sun, 06 March 2016, 19:19:11 »
I know very little about Alps, which of the above keyboards is easiest to source switches, keycaps from?
Offline bocahgundul
  • a seal
« Reply #47 on: Sun, 06 March 2016, 19:34:01 »
You mean the easiest alps switches to get right? Well, the easiest one is getting matias switches. Or if you want some OG stuff you could get salmon alps for tactile switches that can be sourced from AEK 2. I think that is the easiest alps SKCM switches to get and salmon alps is really good and some users said that they feel like an ergo clear with actuation points on top.
And keycaps. You could source ABS keycaps from matias. But if you want some good alps keycaps you could search in ebay for AEK 2 keyboard and SGI granite keyboard for their thick PBT dyesubs.
I hope that this post helps you and if not you could ask more bro!
Using tapatalk to post is damn hard
Hi all~!
dell at101 new
dell at101 old
apple ext2
STS 1.2mm plate
Thank you for all the work LZ!
Online henz
  • What?
« Reply #48 on: Mon, 07 March 2016, 06:25:52 »
Updated op with the new plate pictures.
Nice  :thumb:
gais where are your orders? :D
Dont make me buy the rest of the kits to meet the MOQ.
Online henz
  • What?
« Reply #49 on: Wed, 09 March 2016, 14:58:10 »
anyone have some LZ friends? i dont want to buy the rest of the kits :)
