Author Topic: [GB] Phantom-based "Skeleton" Keyboard Kits - GB COMPLETE  (Read 135067 times)
Offline rampantandroid
Re: [GB] Phantom-based "Skeleton" Keyboard Kits - ORDERING PARTS
« Reply #200 on: Tue, 26 April 2016, 21:17:05 »
all invoices have been reconciled. i will begin ordering parts tomorrow. build log will be up soon also!
My friend is still thinking things over - are the cancelled order slots still open until Friday?  :)
Someone apparently went up to the great philosopher Wittgenstein and said "What a lot of morons people back in the Middle Ages must have been to have looked, every morning, at the dawn and to have thought what they were seeing was the Sun going around the Earth, when every school kid knows that the Earth goes around the Sun", to which Wittgenstein replied "Yeah, but I wonder what it would have looked like if the Sun had been going around the Earth?"
Offline Niarbeht
« Reply #201 on: Tue, 26 April 2016, 21:17:53 »
Don't worry, we've already been talking.
Offline roostrc0gburn
  • its just plastic
« Reply #202 on: Tue, 26 April 2016, 23:31:56 »
yes, thanks guys. i will get your invoice out tomorrow, niarbeht
  • its just plastic
« Reply #203 on: Thu, 28 April 2016, 22:57:42 »
just placed the order with mechanicalkeyboards.com for the pcbs, switches, and switch tools. i will order the plates, hardware, teensys and electrical components over the next couple days
i will post the build log tomorrow - its nearly complete, except for the 7u stabilizer wire. i encourage you all to check that out, as i am going to ask for feedback on standoff length. i had to order longer standoffs in order to complete the build as i had designed, but that is not necessary for everyone. more details to come...
Offline Skysophrenic
« Reply #204 on: Thu, 28 April 2016, 23:59:06 »
D:
I'm too late :<
Why didn't I check out group buys earlier....
Offline duras
« Reply #205 on: Fri, 29 April 2016, 09:26:26 »
the shorter the better IMO
Offline TerryMathews
« Reply #206 on: Fri, 29 April 2016, 10:29:43 »
If someone wants out of this buy, I'd take over an ANSI 1.25 kit.
« Reply #207 on: Fri, 29 April 2016, 20:36:52 »
If anybody wants out, I too will be willing to buy in for an ANSI kit
  • its just plastic
« Reply #208 on: Fri, 29 April 2016, 21:56:13 »
i am purchasing a couple extras of everything. plates will be available from a vendor after the GB is finished
« Reply #209 on: Fri, 29 April 2016, 22:39:42 »
Well, if I can get hooked up with one I want to try to do something cool with it - RGB modded Phantom via QMK.
  • its just plastic
« Reply #210 on: Fri, 29 April 2016, 23:15:20 »
i would love to see that!
« Reply #211 on: Sat, 30 April 2016, 01:35:15 »
I've been mulling over sticking a couple of LEDs between the PCB and the bottom plate, and just feeding them off the USB +5V directly - probably blue to match the indicator LEDs on my board.
I haven't dug too far yet, but could I instead do this using the teensy? Can it control brightness with the Easy AVR firmware? It looks to have dedicated buttons for brightness, anyway...
What are you planning to do with the board - where will the LEDs go?
« Last Edit: Sat, 30 April 2016, 01:38:46 by rampantandroid »
Offline a-c
« Reply #212 on: Sat, 30 April 2016, 02:20:22 »
All pins on the Teensy are in use. You would have to give up Caps lock or Scroll lock LED to get at an io pin.
« Reply #213 on: Sat, 30 April 2016, 05:20:37 »
OK...that sounds fine to me - I see no real use for the scroll lock key to exist anymore - I already planned to make it into some other scan code. What voltage does the scroll lock LED put out right now, and how much power can I safely draw from it? I'm guessing a couple of LEDs in parallel would work fine?
« Reply #214 on: Sat, 30 April 2016, 05:35:47 »
PE2 on the ATmega32u4 is available. It's connected to ground via a 1k resistor but it's not a pin that has to be grounded.
« Reply #215 on: Sat, 30 April 2016, 05:37:41 »
WS2812B LED strip two-sided taped to the bottom of the PCB.
[/quote]
  • its just plastic
« Reply #216 on: Tue, 03 May 2016, 02:25:30 »
UPDATE
build log finally posted. forgive any errors, it is midnight... i'm sorry it took me longer than i promised to post this. if you see anything i missed, have questions, or anything else please comment or let me know
https://geekhack.org/index.php?topic=80118.msg2077558#msg2077558
please post your comments on preference for the standoffs. i dont want to send anyone parts they dont like or wont use!
Also, all parts are ordered except plates. i will get the invoice and pay for those tomorrow!
Offline K.Mak
« Reply #217 on: Tue, 03 May 2016, 14:34:32 »
Damn, starting to wish I hadn't hesitated because of the lack of 1u Winkey on the ANSI 1.5, it does look pretty sexy and lord knows when I'll find a another 7u plate that takes Costar.
Offline mrging
« Reply #218 on: Wed, 04 May 2016, 08:30:27 »
if there's round 2 , i would probably join it :(
look nice, so sad have to cancel last minute.....
will there be some sparing part ?
« Reply #219 on: Wed, 04 May 2016, 18:12:04 »
UPDATE
I guess I'll be the first - I'm not 100% on board with the idea of a taller keyboard, and I think I may go the route I was looking at earlier - a USB board from adafruit or similar. Drill 4 holes in the bottom plate and that way I'll have a USB plug at the back of the keyboard, easy to access while also keeping the keyboard as thin/short as possible.
I hadn't thought about your solution using an angle connector though - I like it for how simple it is :)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #220 on: Wed, 04 May 2016, 18:32:10 »
I like thin....
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #221 on: Wed, 04 May 2016, 18:43:14 »
I like thin....
Another option that occurs to me: what if we use shorter standoffs on the front than the back? The front then will be nice and low as it is limited by either the teensy or any USB ports. It's also a way to add a little bit of a angle to the keyboard as well. I'd want to file the standoffs to add an angle though (otherwise you'll bend the plate when you tighten the bolts) and might need to run a tap through to clean the threads up afterwards.
  • its just plastic
« Reply #222 on: Wed, 04 May 2016, 23:57:07 »
I like thin....
yes, i had considered this. you would have to get the angle of the standoffs within a few degrees of perfect. i would also consider puttting a rubber grommet between the standoff and both plates to make up for that, but it would probably wobble a bit. if you could make this idea work, though, you would end up with a nice angle without a need for feet.
i would still like some more feedback before ordering, as the standoffs are a bit pricey. i can't order a bunch and just ship people what they want. i either need to know now what each person wants with their kit, or we pick a length by popular vote. maybe i should start a new poll? these are the last pieces to order.
i transferred money from paypal to my bank account today, as the shop does not accept paypal. i will send payment tomorrow, and have them send me a confirmation email or some proof of purchase that i can post for you guys. everything else should be here tomorrow! i will post pictures of the stuff when it gets here.
here's the diodes and teensys:
plates should be done in a couple weeks
Offline duras
« Reply #223 on: Thu, 05 May 2016, 08:29:26 »
I would prefer not using the angle adaptor and using the shortest possible standoffs
  • its just plastic
« Reply #224 on: Thu, 05 May 2016, 13:29:10 »
i will break out the calipers tonight and measure what the minimum height of standoff will be.
do we need a poll? i dont see a lot of activity on the thread... idk if many people are even following this anymore
Offline 00zeRO
« Reply #225 on: Thu, 05 May 2016, 21:41:18 »
Thin is best. The beauty is that if someone wants longer then they can buy some later to customize what they want if they don't like the size you include with their order.
« Reply #226 on: Thu, 05 May 2016, 22:08:57 »
Well, about the standoffs and angle - I'd need to bend the actual standoff the more I think about it - even if the standoff has the right angle, the bolt will still go in at the wrong angle. I do wonder if a small angle (a mm or two difference between front and back ) would provide enough extra space to wedge a connector in, use a rubber grommet and not sacrifice how rigid it'll be.
Rubber could also help with noise, too - the KB will be sitting on rubber feet anyway.
Take the lack of replies as a vote of confidence  :D
  • its just plastic
« Reply #227 on: Thu, 05 May 2016, 23:23:59 »
ok, thanks for the feedback everyone. i am mostly hearing thin is the preference.
the distance between the bottom of the plate and the top of the USB plug (which is what protrudes the furthest from the pcb) is 9/16" if you opted to not use the standoffs for the teensy in your build, that would eliminate another 1/8", making the distance 7/16". i would recommend a minimum of 1/16" between any electrical components and the backplate (unless you were to insulate it somehow) making the absolute smallest standoff 1/2"
to recap: if you build the board like my build log, you should use 5/8" standoffs. if you opt to not use the standoffs on your teensy, you should use 1/2" standoffs. these are the lengths we should decide on.
i will offer longer standoffs for people who request them specifically. let me know by saturday - that is when i will order the hardware. as always, pm me or post your questions
Offline infamouslife7314
« Reply #228 on: Fri, 06 May 2016, 18:35:04 »
I would like enough room to use the teensy with standoffs but no 90 angle adapter please
« Reply #229 on: Fri, 06 May 2016, 18:52:14 »
How much space between the bottom of the phantom PCB and bottom plate is there when using the 1/2" standoffs? If there's enough room for me to mount the sparkfun USB board (https://www.sparkfun.com/products/9966), I'm happy with 1/2".
« Reply #230 on: Fri, 06 May 2016, 21:03:32 »
How are you planning on mounting this?
  • its just plastic
« Reply #231 on: Fri, 06 May 2016, 23:15:57 »
I think he was going to drill the plate and bolt it on
Re: [GB] Phantom-based &quot;Skeleton&quot; Keyboard Kits - ORDERING PARTS
« Reply #232 on: Sat, 07 May 2016, 02:29:28 »
 Yeah -that was the idea. 4 holes, something to insulate the board from the case and probably a couple washers.
  • its just plastic
« Reply #233 on: Sun, 08 May 2016, 00:53:52 »
idk how wide the usb breakout is, but height should  not be a problem
  • its just plastic
« Reply #234 on: Wed, 11 May 2016, 21:39:01 »
update -
we got parts! pcbs, switches, teensys, diodes, leds are in
plates will be done in a couple weeks. i will be out of town next week, but i will have access to internet and email if anything comes up. i will go pick up the plates when i get back.
hardware will be ordered tomorrow. unless i hear some outcry otherwise, i will be ordering 5/8" standoffs. i was also playing around with the standoffs i have ordered on my own, and i wanted to show you this:
7/16" in the front, 3/4" in the back. the standoffs are beveled just enough for this to work. it's sturdy, and there is enough room in the back for a 90-degree adapter. if you want to do this, pm me immediately. you will need to source your own adapters, but i can order you the standoffs tomorrow with the rest.
here is an example adapter from ebay:
« Last Edit: Wed, 11 May 2016, 22:41:10 by roostrc0gburn »
« Reply #235 on: Thu, 12 May 2016, 14:49:56 »
It's alive.
And I do still want to take over a kit if anybody wants to sell.
« Last Edit: Thu, 12 May 2016, 14:51:57 by TerryMathews »
« Reply #236 on: Thu, 12 May 2016, 20:18:54 »
So those LEDs are just to provide light below the KB?
Roostr - I thought you were going to order 1/2" standoffs unless people wanted 5/8"? I like the idea of the slant, but on second glance, I see it's missing two standoffs on the edges. Does this affect the plate's rigidity at all?
  • its just plastic
« Reply #237 on: Thu, 12 May 2016, 20:24:53 »
imo, no it doesnt affect rigidity. this is 1/16" steel, and there are 10 secure standoffs holding it together. it's solid.
i just replied to your pm. let me know what length standoffs you want
Offline duras
« Reply #238 on: Thu, 12 May 2016, 21:35:52 »
I would also like the 1/2" standoffs please
« Reply #239 on: Fri, 13 May 2016, 11:51:11 »
Correct. RGB underglow.
It's a grown-up version of the Satan GH60 RGB mod.
  • its just plastic
« Reply #240 on: Fri, 13 May 2016, 16:11:30 »
got it.
« Reply #241 on: Tue, 24 May 2016, 17:26:49 »
Hey Roostr - any update on the plates?  :)
  • its just plastic
« Reply #242 on: Tue, 24 May 2016, 18:49:29 »
yes! i was going to post an update this evening, but i have time now. i am back from vacation, it was a blast. got an email from the shop and the plates are done and ready for pickup. I will not be able to pick them up until next wednesday, though. It is a 4hr+ round trip for me, and that is the only time that the shop will be open and i will have time to go.
I will try to have as many orders as i can packed up and ready to ship by then, so all I will have to do is slip the plates in and send them off. My intention is to have everything shipped by 6/4. Of course, I will post pictures of the progress along the way
Offline 00zeRO
« Reply #243 on: Tue, 24 May 2016, 18:59:58 »
Appreciate the update
Offline fendent
« Reply #244 on: Tue, 24 May 2016, 21:39:42 »
I'm glad your build is going well! I've built my own Phantom-based TKLs with some trials and tribulations. Made my own wood frame for it with an external USB port too. Let me know if you have any questions or ideas for it. :)
  • its just plastic
« Reply #245 on: Tue, 24 May 2016, 23:26:12 »
got a pic of that usb port?
Offline fendent
« Reply #246 on: Tue, 24 May 2016, 23:29:42 »
I'll take a pic when I get back to work tomorrow!
« Reply #247 on: Tue, 24 May 2016, 23:32:03 »
« Reply #248 on: Wed, 25 May 2016, 07:35:45 »
I'd love info on the wood. I've been thinking about doing something similar, but I wasn't sure how much space there was with the plates.
Terry - what case is that?
Offline 00zeRO
« Reply #249 on: Wed, 25 May 2016, 07:49:21 »
SPRiT if I had to guess
